Using crap oil to top up?
HD
PostPosted: 18:42 - 16 Sep 2012    Post subject: Using crap oil to top up? Reply with quote
My bike drinks and shits out oil (on the concrete and the exhaust) but that's another story.
It's mostly filled with Motul oil but can I buy some crappy halfords oil just to keep it topped up with? Money is tight til payday.
If so, do I need to use fully synth as well or will they mix fine if the cheaper stuff is semi?
jimspeed
PostPosted: 18:46 - 16 Sep 2012    Post subject: Reply with quote
any oil is better than none or too low mate, if its leaking that bad I would just cheapo oil until its fixed.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
kawakid
PostPosted: 18:47 - 16 Sep 2012    Post subject: Reply with quote
I'd fix the leak.
On the oil front I have used Halfords bike oil for 8 years with no problems.
I've a twin and a 4.
anthony_r6
PostPosted: 19:04 - 16 Sep 2012    Post subject: Reply with quote
If it's cheaper oil just change it more regularly and I doubt you'd have an issue.
pepperami
PostPosted: 19:19 - 16 Sep 2012    Post subject: Reply with quote
Hmmmm? methinks? If you need to ask that question then as a previous poster stated, you seriously need to address that oil leak!.
If it`s losing that much oil, where`s it going?
Out of the exhaust? = excessive smoke and fumes = a tug from plod Sad
or a possibility of all that oil catching fire in your exhaust Shocked .
Leaky engine gasket? = fking hell! your engine must look a state!
Hot engine + oil = plenty smoke/chance of fire/tug from pold Sad .
Leaking oil further down the engine/gearbox/clutch = how long till that oil finds it`s way to your rear tyre? = does`nt even bear thinking about Shocked .
I think you more than likely know all this already?
Maybe your bike is trying to tell you something?
Matt-
Cheap Oil is fine but as a rule of thumb keep away from mixing it to much.
Get the leak fixed cheaper and easier even if you have to spend a few quid.
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
PostPosted: 19:50 - 16 Sep 2012    Post subject: Reply with quote
The main difference between cheap and expensive oil as it comes out of the bottle is... Well, not much really other than price BUT the more expensive stuff generally lasts longer and will take more abuse before it needs to be changed.
Since your bike is essentially changing its own oil as it goes, cheap stuff should be fine.
HD
PostPosted: 20:28 - 16 Sep 2012    Post subject: Reply with quote
Okay thanks guys. What about semi and full synth mixing?
And yeah, when the bike is cold it smokes a bit. If I rev it hard it lets out a puff when warm. Otherwise there is a small leak on either engine case. I made a new gasket for either side and used a small bit of the blue gasket stuff on the lower edges of them. It is a very small amount though.
Drops from half to just under low in about two weeks. I will get it fixed when I get some cash though!
PostPosted: 21:09 - 16 Sep 2012    Post subject: Reply with quote
Likely will be fine.
Frost
PostPosted: 21:24 - 16 Sep 2012    Post subject: Reply with quote
There is an argument for only ever using shit oil, but changing it more regularly. Too many times i've known people run something on old oil for ages as they're not willing to pay for the fancy oil they put in it last time.
PostPosted: 21:28 - 16 Sep 2012    Post subject: Reply with quote
Or worse, they don't bother to top the oil up and trash something mechanical Wink
The last post was made 13 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.62 - MySQL Queries: 13 - Page Size: 70.23 Kb
