Frame number and engine number do not match.
Derivative
PostPosted: 20:53 - 16 Sep 2012    Post subject: Frame number and engine number do not match. Reply with quote
I'm a bit befuddled by this.
I've just noticed that the VIN on my CB's engine and frame don't match. The frame is PC32 (new model CB), the engine is PC26 (old model CB).
Definitely something I should have checked before - I simply checked the V5 against the frame.
Pretty much everything on the bike is in good condition for age.
I've had no issues in 4000 miles other than routine stuff (tyres, brake pads).
Why would someone swap the engine?
High mileage engine in a low mileage bike perhaps?
HD
PostPosted: 20:56 - 16 Sep 2012    Post subject: Re: Frame number and engine number do not match. Reply with quote
Probably knackered the engine through seizure or gearbox failure or something and would be better financially to replace than repair.
Derivative
PostPosted: 21:12 - 16 Sep 2012    Post subject: Re: Frame number and engine number do not match. Reply with quote
It has 7k miles, backed up by MoT's since purchase.
Unless the speedo has been disconnected.
How would you manage that? No oil?
PostPosted: 21:28 - 16 Sep 2012    Post subject: Reply with quote
Some Yamahas and Suzukis have matching engine frame numbers, like the RD series for example.
However, that is an exception rather than a rule IIRC so I wouldn't worry about it.
Derivative
PostPosted: 21:30 - 16 Sep 2012    Post subject: Reply with quote
Hmm. Not sure I understand what you're saying here.
That it's unusual for a bike to have matching numbers?
andys675
PostPosted: 21:33 - 16 Sep 2012    Post subject: Reply with quote
yamaha engine and frame numbers matched up until 1997, then they didn't, dunno why they stopped but RD freaks nirvana is matching engine and frame numbers when buying/selling
Zen Dog
PostPosted: 21:44 - 16 Sep 2012    Post subject: Reply with quote
Yes. They may not be similar or related in any way in some cases. The V5 for my VFR shows the VIN and Engine serials as similar, but not identical.
Don't worry about it.
Zen Dog
Derivative
PostPosted: 21:50 - 16 Sep 2012    Post subject: Reply with quote
Ah. I've just checked the V5 again, didn't notice that there were seperate entries for both before.
The VIN definitely matches, but the engine serial is different. V5 has a PC32 serial, bike has a PC26. So the engine has been swapped.
Interesting. All I can think of is that someone must have forgotten to oil the original engine and had to replace it, the 'new' (old) one has given me no problems.
Zen Dog
PostPosted: 22:03 - 16 Sep 2012    Post subject: Reply with quote
Are the PC32 serials for the VIN and Engine identical?
Bear in mind, this is the DVLA. Im pretty sure i've seen cases where the V5 shows the VIN and engine numbers as identical, but the actual serial number on the engine is in a completely different format. They've just copied the VIN in there to fill in the form, or they lost the engine number, or it wasnt supplied to them.
If the VIN and Engine numbers are both PC32 numbers, but they're different, you might be right about the engine swap. Is that a major problem?
Zen Dog
Derivative
PostPosted: 22:17 - 16 Sep 2012    Post subject: Reply with quote
No.
It doesn't bother me significantly, I'm just curious as to why the engine has been swapped, and how many miles this one has. The serial number suggests that it's from an older 1990's bike.
It means that my assumption (that I can put another 50-100k on the engine no problem) might be wrong.
The bike has given me no problems, so we'll see how things go.
Zen Dog
PostPosted: 22:36 - 16 Sep 2012    Post subject: Reply with quote
Even if the engine has 50k already, you probably still can, couriers use them so must be able to handle high mileages. If its running fine its all gravy.
Just make a mental note to check the engine number and ask more questions when buying your next bike. And possibly update your V5, although I'm not sure how hard that will be. I've changed the bike colour on the V5 when I had the MZ resprayed, and that was pretty easy, but I don't know if the engine number would be a more serious business.
Zen Dog
The last post was made 13 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.57 - MySQL Queries: 13 - Page Size: 70.49 Kb
