Brake fluid, coolant
Derivative
PostPosted: 02:39 - 11 Sep 2012    Post subject: Brake fluid, coolant Reply with quote
On buying the CB500 I changed the engine oil. Engines are expensive and oil is pretty mission critical. It's also very easy to do.
I've done 3k miles on it without issue.
Should I drain and replace the coolant and brake fluid? Or should I just top up as necessary?
Haynes states that coolant should be done every three years, and brake fluid every 18 months.
Changing the coolant requires removing the fuel tank. Replacing brake fluid seems like it'd best be done with a complete brake overhaul. Neither of which are particularly simple tasks.
I would trust the manual, but it also recommends changing hoses every three years, which I suspect few people actually do.
What say BCF?
TaiChi This post is not being displayed because the poster is banned. Unhide this post / all posts.
.Chris.
PostPosted: 09:57 - 11 Sep 2012    Post subject: Reply with quote
I'd always replace fluids like that straight away if I'd bought a secondhand bike without knowing when they were last done.
Brake fluid absorbs water over time, so will start to cause corrosion if it's just left. Although probably academic unless the fluid is really old, as it absorbs more water the boiling point will decrease, eventually reducing the effectiveness of the brakes when they're used hard.
Anti-freeze gradually loses its effectiveness in both stopping the water from freezing and stopping internal corrosion. I was always under the impression it should be changed every 2 years, and that's what I've done with my car.
Neither of these things are expensive, so personally I'd just do them for peace of mind.
Chris
1985 Kawasaki Z550F
PostPosted: 11:38 - 11 Sep 2012    Post subject: Reply with quote
Both simple jobs.
The coolant is as simple as undoing the drain screw and radiator cap, allowing it to drain, replacing the drain screw and filling it up again. A short run of the engine to remove any airlocks and top it up again.
Replacing brake fluid is simple too (providing the nipple isn't seized). The trickiest bit is removing the master cylinder lid without burring the heads off the screws.
Simply remove the lid off the master cylinder, fit a bit of plastic tubing to the end of the bleed nipple with the other end in a jar and crack open the nipple. Brake fluid will start to slowly run out. When the level in the master cylinder is nearly at the bottom, top it up with fresh brake fluid from a sealed container. Repeat this process until you see the fresh fluid coming out through the tube at the bottom (the old fluid will be a darker colour), nip up the nipple, top the reservoir off to the correct level and replace the lid.
Don't let the hole in the bottom of the master cylinder become uncovered or you'll let air into the system that needs bleeding out again.
As a final touch, tie the lever all the way down to the bars for a couple of hours then slowly release it to remove any tiny air bubbles that might have gone in.
PostPosted: 18:08 - 11 Sep 2012    Post subject: Reply with quote
I would be WAY more worried about the reduction in boiling point than any small amount of extra corrosion from water.
Bloggsy
PostPosted: 18:31 - 11 Sep 2012    Post subject: Reply with quote
I know it's probably over the top but I replace oil filter coolant and brake fluid once a year.the coolant and brake fluid I borrow from work so it's a cheap deal
Derivative
PostPosted: 23:37 - 16 Sep 2012    Post subject: Reply with quote
Okay, I have free time now to sort all of this out and the front pads need replacing anyway.
Coolant, it looks like I need three or four litres.
How much brake fluid do I need for a full flush? I can't really find any info on this specific to the CB. Would a litre do?
Derivative
PostPosted: 00:11 - 17 Sep 2012    Post subject: Reply with quote
_Iain_ wrote:
I used about 1/4 of a bottle of fluid for the GS if that Thumbs Up
Err, 1/4 of what sized bottle? Laughing
There is a site offering 250ml of DOT4 for free with my brake pads (and the pads are cheap).
I get the feeling that 250ml is going to be nowhere near enough though, the two reservoirs probably hold about that alone.
edit: What should I use to clean and regrease the brake calipers, pistons etc themselves? So far I've found when doing my own maintenance that the 'little things' seem to be the most expensive. £8 for a can of brake cleaner? Surely I can do better than that?
Derivative
PostPosted: 23:28 - 17 Sep 2012    Post subject: Reply with quote
Useful advice. Thanks. I have a Haynes manual, picked up for £6.
Bought pretty much everything from eBay. Not sure why I hadn't thought of that before.
500g tin of copper grease for £5.
18g tin of red rubber grease for £2.
Etcetera.
Likely going to get the coolant locally though, shipping costs make it a bit daft.
Is my shoe size relevant somehow? I'm a 9 Laughing
Derivative
PostPosted: 00:08 - 18 Sep 2012    Post subject: Reply with quote
stinkwheel wrote:
Both simple jobs.
Haynes manual is distinctly short on pictures, but it seems that you have to remove the tank to remove the pressure cap.
Seems a bit more involved than I'd like at the moment really!
Derivative
PostPosted: 15:32 - 19 Sep 2012    Post subject: Reply with quote
Done the front brake now, at least I think so. Cleaned out a lot of the crud in there - I could do more, but I'll wait until I don't need to use the bike for a while in case I knacker something up.
How firm should the lever be? I bled the system until I couldn't see any bubbles, and then a little bit more. It has a bit of freeplay, a small (<1cm) section of action and then is firm. Does that sound about right?
Rear brake is non functional because it chucked it down before I had time to finish it, had to screw everything up and stop. Quite funny to have a lever that's completely pointless. Very Happy
Is it worth leaving the lever tied back overnight with the diaphragm removed? Is there an equivalent for the rear brake pedal (hanging a weight from it, perhaps?)
PostPosted: 19:30 - 21 Sep 2012    Post subject: Reply with quote
Where is the 1cm of play? Which end of the lever.
Don't leave the cap / diaphragm off. Won't do any good but will allow moisture from the air to contaminate the fluid. The diaphragm is there to allow the air to take up the space vacated by the fluid being used without the air coming into contact with the fluid.
PostPosted: 20:35 - 21 Sep 2012    Post subject: Reply with quote
Aye, by 1cm by your index finger would be a pretty large amount, while on most bikes at the far end of the lever it would be a pretty minimal amount.
GREENI3
PostPosted: 20:46 - 21 Sep 2012    Post subject: Reply with quote
If you're replacing the brake fluid anyway, get yourself some braided lines.
It makes a massive difference.
Derivative
PostPosted: 21:48 - 21 Sep 2012    Post subject: Reply with quote
Already done now. I may look into it next time.
Left the lever tied back tonight. 1cm was at the end of the bar. It's much firmer than it was before, just not really as firm as I expect disc brakes to be.
Thanks for the input Kickstart. I did suspect it'd be fine with the diaphragm installed, but this stuff is a bit mysterious to me. I should read up a bit on hydraulic systems, will be studying fluids next year.
The last post was made 14 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.10 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 120.01 Kb
