| thepuma |
 thepuma World Chat Champion
| weasley |
 weasley World Chat Champion
 Posted: 07:33 - 17 Sep 2012 Post subject: |
Only if I want to rest my hands/wipe visor/adjust zip on my leathers or if I know they are a long interval. Mostly, I just wait in 1st with the clutch in. ____________________ a.k.a 'Geri'
| Efes123 |
 Efes123 World Chat Champion
| thepuma |
| gaffa |
 gaffa Renault 5 Driver
| janner_10 |
 janner_10 World Chat Champion
 Posted: 07:55 - 17 Sep 2012 Post subject: |
The examiner doesn't give a flying fuck if your bike is in neutral of first at a junction and how is he going to know?
Leave it in first with the clutch in, saves you faffing about trying to get it in neutral.
Focus on the important stuff, like speed limits of the potential route or unusually tricky areas you could be riding in on the test.
Don't lose sleep over guff like this.
Good luck for the test though  ____________________ Yamaha FZS600 (Now gone to heaven) > CBR600F4i (SOLD) > '99 YZF-R1 |
| Matt- |
 Matt- World Chat Champion
| doggone |
 doggone World Chat Champion
| Billo63 |
 Billo63 Crazy Courier
| map |
 map Mr Calendar
| Matt B |
 Matt B World Chat Champion
| dungbug |
 dungbug Could Be A Chat Bot
| Bomberman |
 Bomberman World Chat Champion
 Posted: 11:45 - 17 Sep 2012 Post subject: |
I was told not to go into neutral for my test. Can't get away as quick if you need to, and just something else to get wrong I guess  ____________________ 'Allo! My name is Inigo Montoya, you killed my father, prepare to die!
'89 TZR 125 - '94 GPZ500s - ZK3 GSXR600 Alstare  |
| Flatbadger |
 Flatbadger World Chat Champion
 Posted: 12:08 - 17 Sep 2012 Post subject: |
I had my mod 2 a couple of weeks back, this didn't come up at all. I failed, but not because of that  ____________________ If you can keep your head when all about you
You're in ISIS |
| Rogerborg |
 Rogerborg nimbA
 Posted: 12:26 - 17 Sep 2012 Post subject: |
Agreed to all the above, I can't be arsed with doing a Hendon Shuffle that was designed for lanky legged Plod.
On a practical matter, I stay in gear to give myself a fighting chance of escaping a rear end shunt. ____________________ Biking is 1/20th as dangerous as horse riding.
| map |
 map Mr Calendar
| Kradmelder |
 Kradmelder World Chat Champion
 Posted: 12:44 - 17 Sep 2012 Post subject: |
| map |
 map Mr Calendar
 Posted: 13:09 - 17 Sep 2012 Post subject: |
| Alpha-9 |
 Alpha-9 Super Spammer
 Posted: 13:17 - 17 Sep 2012 Post subject: |
Same as others, I only neutral if I know its a set of lights which is a PITA
and thats only so I can drum and ping my tank out of boredom
Today I accidentally clutched a wheely on my YBR, while pulling off the line between two cars, people were staring like I meant to do it...I wasn't aware it was even possible
Gonna try again later  ____________________ Fzr-600 1999 |
| Kradmelder |
 Posted: 13:40 - 17 Sep 2012 Post subject: |
| Ribenapigeon |
 Ribenapigeon Super Spammer
| Bomberman |
| Teflon-Mike |
 Posted: 16:39 - 17 Sep 2012 Post subject: |
You wont fail for not using neutral & holding it clutch in on test.
You might for attempting to do it 'By the book' and fucking it up!
By the book is something known as the "Cardington Clog Dance" or 'The Met Shuffle"
Saftey Possition? Remember that from CBT? Left foot down propping bike up, right foot up covering, but not necesserily applying rear brake, unless on a hill.
Slowing for the junction, you aporoach in 2nd gear, and clutch in JUST as you stop.... assume Safety Pos.
Now CCD/MS...
Reverse foot, covering front brake with right hand, Right foot down, left foot up, select Neutral, re-assume Safety possition, reverse footing again, left foot down, right foot up to cover brake.
You are now preparing to pull away....
Cover front brake, with right hand, reverse foot, right foot down to prop bike, left foot up to select 1st gear, reverse foot again, left foot down to prop bike, right foot up to cover brake, hand off the front brake....
And OH shit, the gap you were going for has gone....... back to neutral.. try again!
You'd be there for ever like a cat on a hot tin roof changing footing never moving!
CAN be done.... and there are riders, usually police riders, instructors or examiners to whome its so 'drilled' and they have such precission & smoothness that they CAN do it and do it so intuitively and swiftly that it doesn't hold them up.... but for mere mortals? Something that takes a LOT of practice and NOT expected of a two year newb!
For you?
Draw up to stop in 2nd, DONT risk a learner-lurch changing to 1st and getting excessive engine braking just before the stop, OR risk examiner spotting you snick first but hold it clutch in 'coasting' to the halt.
Roll to the line in 2nd, Using rear brake. assume safety possition, reverse foot straight away, find first...... reverse foot, back into safety possition, keep the clutch 'in' till you are ready to launch.
It is NOT, repeat NOT 'best form'. But iot works.
Its not good form, becouse it keeps tension on your clutch sprrings and clutch cable excessively, which means they will wear out faster.
But its the safety implication thats more critical. IF your clutch cable snaps while you are holding it in, OR your grip of the lever is relaxed for any reason; knock from a pedestrian weaving through stationary traffic crossing the road, car wing mirror from car forcing an extra lane, or you are other wise knocked distracted or just sneaze..... bike will launch... it wont 'fail-safe'.
IF its obviouse its going to be a long wait... worth using neutral. Cardington-Clog or Met-Shuffle may be a bit of a faff, but when you are on a bigger bike, with more 'oomph' to make getting intoi gaps easier.... using Neutral if not the full polava of teh Cardington-Clog can be useful..... if for no other reason than hanging onto the much heavier clutch of a big-bike can have your wrists and fingers aching like bludgery after a couple of hours of such stop start riding! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Ribenapigeon |
The last post was made 14 years, 19 days ago. Instead of replying here, would creating a new thread be more useful? |
