No Coolant - what you say?
bikersupermot...
PostPosted: 14:24 - 17 Sep 2012    Post subject: No Coolant - what you say? Reply with quote
a friend of mine is using his 50cc gilera scooter to get to/from the local train station every day for his commute to work.
problem is on longer runs the coolant kept boiling/steaming and my friend got fed up trying to find out whats wrong and why its overheating so he stopped refilling the coolant as he only rides it 2 miles to the station and back now and nowehere else.
its downhill all the way to the station but uphill and quite steep all the way back.
he gave me a lift back to mine from the station other night on the back and it couldnt get up the steepest bit of the hill, but it could before the overheating probs ( although slowly coz it stuggled hard with 2 of us on it ) - i had to get off and walk up lol.
anyways - thats when he told me it had no water in it!!! Shocked Shocked Shocked
i told him he 's damaging the engine really bad doing that - but he says coz its only 2 miles it doesnt get hot enough to get damaged in only 2 miles and its only coz there was 2 of us on it that it couldnt make it up the other night.
what you guys think? whose right so i can tell him!!! Thumbs Up
tinybikes
symonh2000
PostPosted: 14:35 - 17 Sep 2012    Post subject: Reply with quote
You are right, running without coolant will soon cause hotspots and damage.
It could cause ther head to warp, the headgasket to fail or the engine to seize completely.
Four strokes is two strokes too many.
Matt-
PostPosted: 14:43 - 17 Sep 2012    Post subject: Reply with quote
It should be using coolant even on 2 mile's if warmed up correctly before ridden.
As it's a 2 Stroke it should be warmed up left idling for 5 Min's before ridden full throttle.
Could be a simple thing like a stat Thumbs Up
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
x alex x
PostPosted: 14:59 - 17 Sep 2012    Post subject: Reply with quote
doesn't take long for a small 2 stroke to get up to temperature, specially on the way back up a steep hill, head is probably warped now or at the very least the head gasket has probably went, i'd imagine the piston will probably heat seize in the cylinder soon.
Rides: Yamaha FZR 750 & KMX 200
Drives: 2007 Fiat grande Punto Sporting 1.9 Multijet, Remapped, 194BHP Smile
skatefreak
PostPosted: 15:08 - 17 Sep 2012    Post subject: Reply with quote
Yeah,
I'd say it'll be getting to the end of its life veerrryyy soon.
My NSR 125 2stroke is up to temp in < a mile of gentile 40mph riding from cold so I 2 miles on a smaller 2 stroke without coolant, it will be overheating.
It wont kill it straight away on short trips like that but the barrel/head will probably warp a little at a time, performance will deteriorate and eventually it will just die.
The temp gauge will be useless because without water to heat up it will never register the temperature (it measures the water temp...).
Tell him to throw some water in there and get on here if he wants the engine to last much longer...
*Shrugs*
-Jvr
dannymassive
PostPosted: 15:56 - 17 Sep 2012    Post subject: Reply with quote
How long has he been doing this for!? As has already been said, running without coolant will cause some damage. The engine was intended to run with coolant cooling it down hence why it was there in the first place! Yes, OP, you are correct in what you say; and to your friend - Good luck to him!
Previous Ride's - '01 Aprilia SR125 (Sold) '08 HONDA CBF600n (Sold) '96 CB500 (Sold) '01 FZS 1000 (Sold) '06 CB1300SA (Sold) '07 CB600F Hornet (Sold) - '93 Suzuki Savage LS400 (Sold) '98 Honda VTR1000 Firestorm (Sold) '05 CB600F Hornet (Sold) '01 FZS1000 Fazer (Sold) 2016 Harley Davidson Street Bob SE (Sold) '02 Kawasaki ZX9R (Sold) '98 CB600F Hornet (Sold) '04 Suzuki Bandit 1200s (Sold) '13 Yamaha FZ1-N
Matt-
PostPosted: 16:27 - 17 Sep 2012    Post subject: Reply with quote
If it was on a 4 Stroke engine i would of said keep it going it won't be much harm but it's a 2 stroke, 2 stroke's suffer from heat anyway, so i am guessing it's already taken it's toll on the barrel and warped it the cylinder, at the very most it will be a Top End Rebuild, as long as you don't heat seize it you everything should be fine for just a top end.
Walloper
PostPosted: 17:20 - 17 Sep 2012    Post subject: Reply with quote
Are you two a pair of fat bastarts????
Too much load can cause problems.
Maybe this is God letting you know that walking will save your soul.
symonh2000
PostPosted: 19:15 - 17 Sep 2012    Post subject: Reply with quote
Actually walking wears out your sole. Razz Laughing
PostPosted: 19:27 - 17 Sep 2012    Post subject: Reply with quote
I would expect it to be wrecking the engine fairly quickly. I do know of people running 2 stroke drag bikes with liquid cooled barrels but no coolant in them, but then they are only running for under 20 seconds rather than a couple of minutes.
No point leaving it idling. No load and it will barely warm up at all, but just means longer on choke with the petrol washing the oil from the bore. Start it and ride off pretty much ASAP, just take it easy until up to temp.
Will pretty much destroy either just as much.
Teflon-Mike
tl;dr
PostPosted: 22:59 - 17 Sep 2012    Post subject: Reply with quote
If it was overheating and boiling its block before.... something was wrong.
Whats the chances it was already fucked and in need of a rebuild?
Running without coolant, probably fucking it a bit more.... but it ent quite dead yet, by the sounds of it!
So at what point do you call it a day and do something about it?
Noxious89123
PostPosted: 23:17 - 17 Sep 2012    Post subject: Reply with quote
Next week, when it goes bang. Thumbs Up
symonh2000
PostPosted: 09:17 - 18 Sep 2012    Post subject: Reply with quote
Probably best to fix it before it goes bang. It could seize up and throw the rider off.
Walloper
PostPosted: 11:00 - 18 Sep 2012    Post subject: Reply with quote
Impossibru...
Too fat I think.
bikersupermot...
PostPosted: 20:03 - 18 Sep 2012    Post subject: Reply with quote
its been doing the overheating thing since about june - he rides it every mon - fri since then and its still going lol so mebe it doesnt get very hot on the 2 mile down hill run to the station an i dunno about the uphill all the way back
but the things still running ( not v fast uphill mind haha ) but no signs of it seizing up yet
an no we are not 2 fat bastids lol - weigh 11.5st and 10.5 st - but 22st is a lot for a 50cc scooter with no water in it an a steep hill to ty to get up - so thats why even at max throttle it just slowed down till it wudnt go any more an i hopped off. then it just about carried him to the top. lots light blue smoke coming from the pipe so its defo burning up i thinks.
but he just gonna keep riding it like that an then get another engine to stick in or rebuild the one thats in it depending on the cost.
just hope he puts coolant in the next one lol
tinybikes
bikersupermot...
PostPosted: 21:16 - 18 Sep 2012    Post subject: Reply with quote
coz its an auto scooter driven with a rubber belt - it ll prolly just coast to a stop if it seizes - but he said its gone this long doing the 2 mile there and back journey that he cant see why it wont go on lolol Shocked Shocked Shocked
i have my doubts - but its his scoot, i dont really care what he does with it but its kinda funny that its lasted this long an still going!.
but as iv said to him - its his money his wallet when / if it goes pop!
tinybikes
The last post was made 14 years, 19 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 99.88 Kb
