oil pre mix
rizzla
PostPosted: 10:44 - 24 Oct 2004    Post subject: oil pre mix Reply with quote
can anyone tell me the pre mix ratio for oil/petrol for a nsr 125 2001?
PostPosted: 10:56 - 24 Oct 2004    Post subject: Reply with quote
There is no fixed amount. The oil pump should do it fine. When bleeding the oil pump through they say to use premixed fuel at 25~50 parts petrol to one part oil.
What is wrong with the oil pump?
rizzla
PostPosted: 11:02 - 24 Oct 2004    Post subject: Reply with quote
rubber hose split leaking oil so i would like to run it on pre mix untill get new hose thanks for help
Guest
PostPosted: 11:22 - 24 Oct 2004    Post subject: Reply with quote
Can you block the hose off in some way as you don't want to be sucking air in.
rizzla
PostPosted: 13:57 - 24 Oct 2004    Post subject: Reply with quote
i have i clamped it so that no air is being sucked through the pipe thanks for any help or suggestions
lee
PostPosted: 23:01 - 24 Oct 2004    Post subject: Reply with quote
I would think that you stand some chance of damaging the pump by running it without any oil going through it.
Which pipe is it that is split? The one from the oil tank to the pump, or the one from the pump to the carb? The first should be quite easy to get from any bike shop, the second is a pain to get.
pipnet11
PostPosted: 00:43 - 25 Oct 2004    Post subject: Reply with quote
Oil pump + no oil = dead pump
Oil pumps need oil in them all the time or the get quite upset!
Phill
I love the girls that do, I hate the girls that dont, I hate the girls who say they will and then they say they wont, but the girl I like most of all and I think youll say Im right, is the girl who says she never has but looks as though she might. - Max Bygraves
divuk83
PostPosted: 09:34 - 25 Oct 2004    Post subject: Reply with quote
Bin the oil pump and switch to pre-mix. I run 3% premix on my bike but you could probably run 2.5% and still be safe. I'm not sure what a NSR runs on, but I imagine it would be similar. I changed to reduce overall weight and more importantly to protect the engine from being killed if the oil pump fails. Only thing to watch out for is when you shut off the throttle at speed, as the oil will pretty much stop coming though which it wouldn't with a pump. Not caused me any trouble so far though.
Dave
PostPosted: 09:58 - 25 Oct 2004    Post subject: Reply with quote
Quite a few problems ditching the oil pump, along with the inconvenience. The oil and petrol will seperate when left to stand so you need to shake the bike before running it. Run out of petrol and you also run out of oil. Oil usage will be higher, and is likely to be wrong in most rev ranges (so more chance of fouled plugs, etc).
And to be honest a 2 stroke oil pump failing is a very rare occurance.
Also if you run with premix you will need to up the jetting to compensate.
Keit
mchaggis
PostPosted: 21:17 - 25 Oct 2004    Post subject: Synthetic or Mineral? Reply with quote
Okay, I haven't been able to find an answer to this by searching, so I thought I'd ask it here...
What are the differences between and advantages of synthetic and mineral 2 stroke oils, and would running mineral in a 100cc 2 smoke scooter be fine?
(Brother's Sym Jet 100 in this case.)
PostPosted: 22:25 - 25 Oct 2004    Post subject: Reply with quote
A 100cc scooter (or indeed any 2 stroke in a low state of tune) should be fine on normal mineral 2 stroke oil.
The last post was made 21 years, 357 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.38 - MySQL Queries: 13 - Page Size: 68.94 Kb
