carburettor stutter
RogueCarl
PostPosted: 08:25 - 18 Sep 2012    Post subject: carburettor stutter Reply with quote
Hey all, I'm back with my CG125 from 1980...
Okay so after the previous carb's butterfly valve snapped in half i bought a new one (save myself some hassle). I've fitted it fine, and set it up mostly alright, but no matter how much i fiddle i can't seem to get rid of the stutter it has when accelerating! If i accelerate slowly then i can control it, but then i'm just a hazard so that's not best.
The amount of stuttering also varies with the amount of fuel in the tank - more fuel= less stuttering.
Can anyone share their thoughts as to what i should do to eliminate this problem?
I've had a quick look online for the specific settings but to no avail (all parts are standard), and the old one went straight in the bin so i can't refer back to it Sad
Thanks guys, Carl
Matt B
PostPosted: 09:32 - 18 Sep 2012    Post subject: Reply with quote
Well it sounds like fuel starvation.
Is the new carb NEW? Have you checked the fuel filter, jets, floats, needle etc? Have you stripped it and given it a blast of carb cleaner?
RogueCarl
PostPosted: 09:35 - 18 Sep 2012    Post subject: Reply with quote
'Tis indeed new. I checked the floats for the height and they were fine, the needle seemed fine, but i haven't done the rest. Is carb cleaner advised for new ones then?
Cheers Smile
temeluchus
PostPosted: 10:03 - 18 Sep 2012    Post subject: Reply with quote
fuel tap clagged up?
RogueCarl
PostPosted: 10:05 - 18 Sep 2012    Post subject: fuel tap Reply with quote
nope, the fuel tap is just fine :/
tomh
PostPosted: 10:33 - 18 Sep 2012    Post subject: Reply with quote
Check what size jets are in the new carb compared to your original carb? There's been quite a few jet size changes over the years.
Also does both of the carbs have the extra fuel pump (Can't think of the name of it) on the side of the carb
Srengam
PostPosted: 11:54 - 18 Sep 2012    Post subject: Reply with quote
I had this recently, between 6k-7k revs bike would stutter, more noticable in higher gears.
In my case it was crap in the fuel tank blocking up the bottom section of the fuel filter. More fuel equals more surface area of the filter for fuel to pass through, less fuel equals less surface area for fuel to pass through. Not enough fuel to pass over the top of the crap blocking the filter and the bike stops as if it's run out of petrol (in my case my bike needed more than 5 litres to run at all).
I took the tank off, steam cleaned it in work, cleaned the filter and the tap with wd40 and then compressed air (hold the filter to your mouth and blow through it afterwards to check, I found that wd-40 actually sealed the filter up like a clear gum, so give it a good blast with air, then check with your mouth).
Put it back together and bike was fine. A couple of hours and no cost other than car petrol to take the tank to work solved it (you may want to use local garage with a jet wash, but if possible try and pick one with a variable pressure dial so you can lower the pressure a bit).
It might not be the case for your bike, but it won't do any harm, it certainly sounds similar to my problem.
Suzuki GSX600F Katana (1997)
RogueCarl
PostPosted: 14:00 - 18 Sep 2012    Post subject: Reply with quote
TomH - it's exactly the same model of carburetor, just this one is new, they both have dual inputs too.
Srengam - definitely sounds like a positive move even if it doesn't work for me! do you think the steam cleaning is totally necessary? as i don't really have access to one :/ but the rest sounds easy enough, i'll have to give that a shot! thanks! Very Happy
*to do - clean filter and tap thoroughly*
Casper
PostPosted: 16:03 - 18 Sep 2012    Post subject: Reply with quote
Just take the tank to a garage mate and use a very hot jet wash. Spray the inside when done with WD40.
RogueCarl
PostPosted: 16:06 - 18 Sep 2012    Post subject: Reply with quote
awesome, cheers!
anything else i might need to check if that's not the problem? thanks!
Casper
PostPosted: 16:15 - 18 Sep 2012    Post subject: Reply with quote
RogueCarl wrote:
awesome, cheers!
Just now no. Deal with the easy cheap stuff first. Clean tank, clean tap and a clean fuel line. If you still have a problem then start to look into the carb. You may have filled it with shite from a dirty tank. But as i say, easy jobs first.
Lord Percy
PostPosted: 21:34 - 18 Sep 2012    Post subject: Reply with quote
I have the exact same problem. I thought it was to do with the carb but it seems to come and go, no matter what settings I stick it on.
But fuck I can't just go and clean my fuel tank, it's fucking full of rust and even has two big wads of hard plastic in it (WTF?!). Special thanks to Vince Candelin, E two Motorcycles, Vincan Motorcycles (or whatever the hell he's changed his trade name now), who sold me the bike.
SEEMINGLY NICE GUY, AWFUL BIKES. Spread the word.
So for me it's looking to be new fuel tank time.... £80 for a hollow metal lump, yaaaaay. And if that doesn't fix it.... well... I've tried EVERYTHING!
tomh
PostPosted: 07:02 - 19 Sep 2012    Post subject: Reply with quote
Sorry to hear he got another BCF member. He sold me my CG although thankfully nothing to major wrong on mine. Just signs of overspray on various plastic where he resprayed the bike with all the panels and tank STILL on the bike and mileage on the clock was around 10000 miles out from the last MOT. A basic service fixed most issues.
Lord Percy
PostPosted: 12:27 - 21 Sep 2012    Post subject: Reply with quote
Mine needed/needs the following:
new diaphragm, leading to whole new carburettor.
new carb-to-head rubber
new speedo
new tacho drive
new fuel tank
new fuel tap
full oil change (bit's of metal in oil........)
It's finally all ok now. At near wide open throttle the engine sometimes comes to a slight chug and wants to die a bit. I put that down to bits of shit from the tank (because I haven't replaced it) getting into the float bowl. Or maybe the carburettor still isn't set right, but there's no way I'm touching it again after the amount of times I've had it off! It's good enough for me! But really, it should have been in the good nick he promised it to be in in the first place... Total cowboy. Hope his business fails, genuinely. Absolute disregard for the general content of his customers, as long as his bikes appear ok at first and his money keeps coming in. 100 years ago he would have been one of those quacks going from town to town selling bullshit potions and things Laughing
abc123321
PostPosted: 13:40 - 21 Sep 2012    Post subject: Reply with quote
What goes around comes around mate he/they will get it back.
I got my bike and was running ok for 2 days then kick start broke of then well the list goes on to eventualy cracking the case open to find bearings and conrod going.
So at least I know what I have changed has made it a refurbed engine.
In this day and age you cant trust many people with what they say cos most sput bullshit as everyday language.
Roll on my bike back on the road Smile
You get what you give in life.
RogueCarl
PostPosted: 16:18 - 24 Sep 2012    Post subject: not worked :/ Reply with quote
Hey all, over the weekend i did as instructed: cleared out the tank and cleaned the fuel filter (although it wasn't actually clogged up at all?).
So after taking it to work and back in the same condition as before, i've concluded that that wasn't the problem - it was all for a good cause anyway though.
so does that just leave it down to the Carburetor settings?
Carl
Matt-
PostPosted: 16:20 - 24 Sep 2012    Post subject: Re: not worked :/ Reply with quote
Carl
Yes, Ignition air and fuel are the basics you want,
If you have spark, Air that leave's fuel...
Check settings to manual Thumbs Up
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
RogueCarl
PostPosted: 16:26 - 24 Sep 2012    Post subject: Reply with quote
yeah the spark is fine, i don't believe there's anything wrong with the air intakes at all, so Carburetor here i come.
Also, i have to start it with the choke (i can turn it off immediately though), so does this mean i'll need to take it off and adjust the main jet? or can i do it all from the Pilot Jet (the one on the bottom, i may have named it wrongly)
Carl
The last post was made 14 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.09 Sec - Server Load: 0.59 - MySQL Queries: 13 - Page Size: 100 Kb
