whats best for winter riding in scotland gloves or mitts?
bobsma
PostPosted: 20:00 - 18 Sep 2012    Post subject: whats best for winter riding in scotland gloves or mitts? Reply with quote
new to winter riding, doing an hour commute either way and wondering whats the best for keeping my hands warm. Any clean suggestions greatfully received... cheers bobsma
Bendy
Mrs Sensible
PostPosted: 20:18 - 18 Sep 2012    Post subject: Reply with quote
Bar muffs and heated grips.
Recluso
PostPosted: 20:28 - 18 Sep 2012    Post subject: Reply with quote
Gonna agree with Bendy on this as this is the exact same suggestion I have been given by others as I have to do an hour long motorway commute through winter.
'Just erotic. Nothing kinky. It's the difference between using a feather and using a chicken.'
Honda PS125i > Yamaha YBR125 > Yamaha XJ6 Diversion > Yamaha Tracer 900
Spangle2k4
PostPosted: 20:41 - 18 Sep 2012    Post subject: Reply with quote
I was riding at -3 last winter and you simply can't keep warm at those temperatures. I had Hein Gericke Pathan Gloves with the seamless bonding over-gloves that were new for last year and it wasn't enough (I also have hand guards). It was fine when setting off from somewhere warm but if you put the gloves on cold hands you don't get any heat back. The coldness on your fingertips takes a long time to get over at the other end.
As such, you need something to put heat back into your hands. Heated grips are good, especially if they go good and hot, but they only heat the palms of your hands. The backs of your hands and your thumb will still get very cold. Wear super-thick gloves to combat this and the heat from the grips won't get through so well...
The only real solution is thick, heated gloves. These are very expensive but they will keep your hands warm. The pricier ones heat all over the fingers and the back of the hand.
Another school of thought is that keeping the torso warm results in warmer blood and so the hands, feet etc stay warmer too.
FWIW I have bought a Keis heated vest for this year and will again be wheeling out the big gloves. I'm going to see what difference it makes keeping the core warm. Ideally I'd like heated gloves or heated liner gloves as well but it isn't proving easy to find some that are a good fit (seemingly very long fingers). I fully anticipate still struggling on the very worst days in January and February but my commute is only 45 mins.
Muffs are meant to be good and I think will probably help a lot in keeping the wind off (and thus stopping the back of your hand and your thumb freezing); I would consider giving these a go myself if I was going to take a longer journey. You will still need something to get the heat back in, though (heated grips). The only reservation I have with muffs is how things will pan out in the rain. Your gloves will get soaking wet while you're faffing with the bike and then you'll be putting wet gloves into the muffs. Will they go mouldy? Will the water all just hang around? Not sure on that one.
TL;DR: What Bendy said, heated grips and muffs are a good bet for your first winter.
scorps
PostPosted: 21:25 - 18 Sep 2012    Post subject: , Reply with quote
warm in Scotland? in the winter??????? Shocked
Do not presume that I am male.
salty21
PostPosted: 21:32 - 18 Sep 2012    Post subject: Reply with quote
I am confused as to how you think your hands will get wet when using muffs. most, if not all bar muffs are fully waterproof. I've used the heated grips/muffs combination for the last few years in temps as cold as -15 using just summer gloves. My hands stay toasty warm with the added bonus of being able to feel what i'm doing due to not having to wear great big clumsy gloves and not once did my gloves get wet.
LordShaftesbu...
PostPosted: 21:36 - 18 Sep 2012    Post subject: Reply with quote
As long as you have really thick gloves or mitts or muffs, heated grips don't just warm the inner surface of your hands, they warm the air inside whatever it is you're wearing. Just ramp them up to max if your gloves are that thick.
defblade
PostPosted: 22:54 - 18 Sep 2012    Post subject: Reply with quote
Heated grips and handguards to keep the wind off the back of your hands (bit like muffs, but less ghey Wink ). Then normal sort of thickness winter gloves (preferably gore-tex still) are fine down well into minus temps.
Derivative
PostPosted: 23:01 - 18 Sep 2012    Post subject: Reply with quote
I've been reading about muffs quite a bit recently.
It seems that people have problems with them being pushed back into levers at speed due to air resistance.
Does anyone here have any experience with brands that, err, don't do this?
I'd be interested in getting some for the CB5.
PostPosted: 23:53 - 18 Sep 2012    Post subject: Reply with quote
https://i47.tinypic.com/2vm66f9.jpg
+ hand guards / muffs / heated grips.
Spangle2k4
PostPosted: 06:31 - 19 Sep 2012    Post subject: Reply with quote
Poorly-worded point on my part. What I was trying to say is if your gloves are already wet (from faffing about with the bike etc before heading off in torrential rain) and you then place them in the muffs, they'll make the inside of the muffs all wet and horrid. Will that then turn into a build-up of mould and smelly/uncomfortable nastiness or does it just evaporate away and nothing comes of it? It's one of my reservations about giving muffs a go (and it sounds like you can answer!).
One thing that is very tricky about the topic of gloves/keeping hands warm is that it seems people's tolerance of cold varies so much from one person to another. I think I am in the more intolerant category, my hands get pretty cold quite early on in the year. With hand-guards, heated grips AND 2-layered thick gloves I still get very cold hands after more than half an hour. I am probably therefore more reluctant than most to recommend any particular solution as being adequate (short of heated gloves).
I must say, if you're comfy and warm at -15 with muffs and heated grips then that sounds like a good recommendation to me!!!
Peirre oBollox
PostPosted: 06:51 - 19 Sep 2012    Post subject: Reply with quote
Before anyone else mentions it
https://www.tucanourbano.com/Catalogo/item/manopole-en-US?categoryFullPath=termoscud_e_coprimanopole
Though a quick search will bring up similar results
Serendipity
PostPosted: 07:08 - 19 Sep 2012    Post subject: Reply with quote
Indeed. Search for CB500 Muffs and you'll find Donnybrago's review thread. You'll see details of the large furry variety and the slimmer neoprene ones. I have the neoprene ones and they're brilliant.
So, if you're man enough to handle the ghey, get some muffs and stick a couple of (warm) fingers up to the fashion victims.
2016 CBF1000F - Commuter heaven | 1994 CBR600FR - Awaiting defibrillation
Bendy
Mrs Sensible
PostPosted: 08:40 - 19 Sep 2012    Post subject: Reply with quote
I have never found that to be an issue. If you have that much faffing to do that your gloves would get soaked, don't put your gloves on yet! And when I've put damp gloves in muffs, the heated grips dry it all out.
I get cold hands very easily and have never found a pair of gloves that keep me adequately warm in winter, even with the heated grips. The Tucano Urbano muffs have removed this problem entirely - I wear my normal summer gloves, stick the heated grips on and remain warm and dry even in the depths of winter. And I truely couldn't give a flying one whether it looks cool or not.
DrDonnyBrago
Muffs are simply fantastic bits of kit. It is surprising how much windblast cools your hands, especially if your gloves are wet. My muffs were completely waterproof, windproof and made a cold winter commute tolerable. This year, I'll actually bother fit my heated grips.
My review (innuendo ahoy):
https://www.bikechatforums.com/viewtopic.php?t=231946&postdays=0&postorder=asc&start=0
Amreet
PostPosted: 12:45 - 19 Sep 2012    Post subject: Reply with quote
heated gloves and hand guards.
Spangle2k4
PostPosted: 13:15 - 19 Sep 2012    Post subject: Reply with quote
Consider me convinced! Have ordered a pair Smile
salty21
PostPosted: 16:31 - 19 Sep 2012    Post subject: Reply with quote
I also have the tucano urbano neoprene muffs and couldnt imagine winter without them now. They do look a bit ghey but you will not care once you have experienced the awesomeness.
bobsma
PostPosted: 20:50 - 26 Sep 2012    Post subject: winter riding with warm hands Reply with quote
Thanks for all the tips guys...we've gone for oxford muffs - the cheapest we could find...first ride out today, they definately keep the wind n rain off and I think we'll get heated grips for the depths of winter too... happy riding Very Happy
The last post was made 13 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 105.86 Kb
