| _Iain_ |
 _Iain_ Banned
 Posted: 00:32 - 19 Sep 2012 Post subject: Reading suzuki engine numbers. |
Trying to work out what year engine is actually in my bike now. Found road grime in the cracked front mount, so am assuming it's seen road use after being removed.
So far as i can work out;
M = 400-499cc
5 = 4 Stroke twin
01 = Engine phase. - However this is the same on both engines, although one is the low power silver version?
The rest of it is what im struggling to work out.
I.e M501 - XXXXXX (not posting engine numbers for obvious reasons..)
https://www.suzukicycles.org/_misc/identification.shtml
I've used the above site, but it's unclear as to engine identification. ____________________ Please be aware that the above post may be full of complete nonsense.
| Efes123 |
 Efes123 World Chat Champion
| orac |
 orac World Chat Champion
 Posted: 09:08 - 19 Sep 2012 Post subject: |
M501 would mean its 400-499cc in a 4 stroke motor and the 01 designates that its first generation, ie ut cold well be from an 89.
from the website you listed
m = 400 -499cc
5 = 4 stroke twin
01 = first sequence
| Quote: | Unlike type, the sequence number for engine uses a two-digit number starting with 01. Because of the late introduction of this code system, the engines used on several Suzuki models don't use this system. For example, the engine code of the GSX750S is the same as its frame type, GS75X.
Regarding R7** class, the GS750 is thought as the first version of the engine type, but it is not confirmed by Suzuki if they count it as 01. |
checking the haynes first design frames with unrestricted power went from 89 to 99 - seeing as that a first design motor it should be unrestricted (power restriction is most likely done through carbs and CDI), there is little mechanical differenfct between the engines ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| _Iain_ |
 _Iain_ Banned
 Posted: 11:20 - 19 Sep 2012 Post subject: |
Both engines are M501, ones a silver low power engine with some sort of blanked off ports on the barrels, the other a black high power which matches my V5 (i.e 1992)
I belive the 01 doesnt count for shit in this case
Need to translate the other 6 numbers. ____________________ Please be aware that the above post may be full of complete nonsense.
| P.addy |
 P.addy Red Rocket
 Posted: 11:29 - 19 Sep 2012 Post subject: |
PM me digits  |
| orac |
| orac |
 Posted: 11:54 - 19 Sep 2012 Post subject: |
also chech this out
https://www.suzukicycles.org/GS-series/GS500E.shtml
it appears that colour of the engine is no way to tell the power, here tehy quote an early rad machine with a silver engine as having 52 (which i doubt they ever produced no matter year or colour), a slightly later on with a silver engine with 47hp, the chances of noticing that smaller difference is unlikely.
with that in mind the later engines would most likely have m502 number of or 03 etc. the 01 give the design version, if the first design than you have the 52hp variation.
have you actaully riden it yet. if so does it feel as tho it has less grunt ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
The last post was made 14 years, 18 days ago. Instead of replying here, would creating a new thread be more useful? |
