 Posted: 18:38 - 20 Sep 2012 Post subject: Mystery electronic device on my VFR750 |
No idea what it is and it's not on the wiring diagram.
So it's a 1992 Honda VFR750 FN.
I found a bug lump of self amalgamating tape wrapped in PVC tape hanging off the loom at the front of the VFR. Pretty much just flapping about on the end of its wires.
I ALWAYS investigate big lumps of PVC tape, I don't trust them, especially with the horriffic degree of bodgery that has already been carried out on this bike.
SO. It's got a small PCB inside it. It's attached to the loom with a very original looking connector block and has a green earth wire, a black on brown live wire and an orange wire with a blue tracer. The orange wire comes off the loom at a bullet connector then attaches into the connector block and is about five times as long as the other two wires (possibly as if it is meant to go somewhere else first?).
I can't find an orange and blue wire anywhere on the wiring diagram, nor any mention of this PCB. It looks like it's designed to screw down to something, but it isn't.
I want to know what it is, because if it's something like a restrictor, I want it off and if it's a rev limiter modifier or ignition advancer, I need to know because I habitually bounce them of the limiter.
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0824_zps3f0e4e3f.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0825_zpsfbce85e5.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0826_zpsd1d6f04f.jpg
https://i48.photobucket.com/albums/f216/stinkwheel/CIMG0827_zpsde92efba.jpg
Any ideas? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Fizzer Thou |
| Frost |
 Frost World Chat Champion
 Posted: 19:21 - 20 Sep 2012 Post subject: |
Looks like one of the 180kph speed limit removal boxes you fit to a VFR 400. Same size, plug type, wire could, colour and location. It might also bee a speedo healer?
Unplug it and go for a ride  |
| Knightsy |
 Knightsy World Chat Champion
 Posted: 19:38 - 20 Sep 2012 Post subject: |
It's the MI5 tracker. Expect a visit soon  ____________________ 09' Versys 650 | 07' FJR1300A |
| Islander |
 Islander World Chat Champion
| The Artist |
 The Artist Super Spammer
| The Artist |
| Islander |
 Posted: 19:57 - 20 Sep 2012 Post subject: |
The brown on black wire is a switched live and reads "IGN"
The green wire is an earth and reads "GND"
The blue on orange has a low 0.15VDC voltage which increases with revs up to about 0.6VDC.
The speedo is (mechanical) cable operated.
So putting something between those black bits would alter whatever it does? Like on an optical ignition? Weird. It was all wrapped up in black tape and I'ver been over the main parts of the ignition system when I removed the generator cover and subframe to repaint them. They seemed totally unmolested.
EDIT: What would one of these things be doing on a 20 year old Honda? ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Islander |
| Suntan Sid |
 Posted: 20:12 - 20 Sep 2012 Post subject: |
Has the CDI unit been replaced? ____________________ "Everybody needs money, that's why they call it money!"  |
| Islander |
 Posted: 20:30 - 20 Sep 2012 Post subject: |
Yep, 'Fraid so.  |
| map |
 map Mr Calendar
 Posted: 20:32 - 20 Sep 2012 Post subject: |
This may be teaching you to suck eggs but have you asked on the VFR or Honda owner sites?
I am intrigued now and want you to find what it is  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| The Artist |
| Martay |
 Martay World Chat Champion
 Posted: 20:48 - 20 Sep 2012 Post subject: |
Its the speed limiter iirc. Fitted in the clocks, theres a little panel which blocks the signal passing between the 2 black 'towers' at the relivant speed. This triggers the limiter.
By removing it from the clocks, it effectivly doesnt know its doing over the limit.
Saw this done also on Billings VFR400 thingy.
EDIT: When blocking the signal, it cuts the spark to 2 of the cylinders. ____________________ Eat well, poo hard
Drives: Cavalier 2.0 16v
Rides: Slightly ratted Honda City Express  |
| Islander |
| Spudly |
 Spudly World Chat Champion
 Posted: 22:09 - 20 Sep 2012 Post subject: |
That's fascinating, I hope you find out what it does. ____________________ The Old Apprentice |
 Posted: 00:35 - 21 Sep 2012 Post subject: |
Errr.
I've removed the front brakes in anticipation of my totally kick-arse pretech brake callipers being delivered.
As such, checking for a maximum speed restriction may be a trifle hazardous at this stage...
I'm going to have to peel the loom back and follow the wire. It's too anoying not knowing what it's for. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| _Iain_ |
 _Iain_ Banned
 Posted: 00:47 - 21 Sep 2012 Post subject: |
Could you not put it on paddock stand or whatever & run it up to that wheel speed? Then whack something across the blocks & see if it misfires? ____________________ Please be aware that the above post may be full of complete nonsense.
 Posted: 08:07 - 21 Sep 2012 Post subject: |
I'll pull the speedo out tonight to have a look if there's somewhere for it to go but I can find no reference anywhere to the 750 models having a top speed restrictor.
I've got the official workshop manual too and it's not mentioned in there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| sickpup |
 sickpup Old Timer
The last post was made 14 years, 57 days ago. Instead of replying here, would creating a new thread be more useful? |
