Run it in or thrash it?
california_rookie
PostPosted: 01:37 - 25 Oct 2004    Post subject: Run it in or thrash it? Reply with quote
Recently, a friend of mine was regailing me with a tale of two identical bike, one of which had been properly run-in, the other of which had been thrashed to within an inch of it's life. The results of which, supposedly scientifically obtained, were as follows:
Bike #1 - which was run in porperly - ran exactly as anticipated.
Bike #2 - the unlucky thrashing victim - made more total horsepower but developed an internal oil leak.
Anyone heard of anything of the sort or have any evidence as to how this story might be confirmed/disproven?
https://www.bikepics.com/members/californiarookie/04gsxr600/
https://www.myspace.com/spapadillion
https://steamcommunity.com/id/spapadillion
Frost
PostPosted: 02:38 - 25 Oct 2004    Post subject: Reply with quote
There are sites which detail a thrashing style of running in this normally envolves putting the bike on a dyno and opening upt he throttle to various positions and holding it there. It is said to give a better seal, but the argument against it is that it overstresses the engine expecially if it has new components. Personally i would adopt an aproach of try and ride the thing normally, but Don't thrash it untill you have a couple of hundred miles under your belt.
I really can't see the harm of revving a bike to 6000rpm rather than a recommended 5000, or thrashing it 50 miles earlier than the manual says
california_rookie
PostPosted: 03:36 - 25 Oct 2004    Post subject: Reply with quote
Agreed. For the first 1000 miles I just kept creaping slowly up on the redline, phasing in a little more of the throttle day by day. Now the damned thing's making clicking sounds from the top end and has already been to the shop once. What the hell'd I do wrong? Embarassed
divuk83
PostPosted: 08:21 - 25 Oct 2004    Post subject: Reply with quote
Just warm the bike up properly then ride it however you want!
Dave
TheShaggyDA
Repost Police
PostPosted: 09:01 - 25 Oct 2004    Post subject: Reply with quote
Might be referring to one of the articles here :-
https://www.mototuneusa.com/
tintin
PostPosted: 09:04 - 25 Oct 2004    Post subject: Reply with quote
This is the article:
https://www.mototuneusa.com/break_in_secrets.htm
The older I get the better I was
iCraig
PostPosted: 09:09 - 25 Oct 2004    Post subject: Reply with quote
Some do say thrashing it from new gives you a better seal round the piston rings and the bore etc, and if you leave a it a few hundred miles the honing on the cylinder bores has been worn off so they don't create a proper seal.
In my opinion that is rubbish, because thrashing it from new means it will wear quicker as there are little particales of metal in the engine as its new etc, and it will also overstress the engine too.
instigator
PostPosted: 09:12 - 25 Oct 2004    Post subject: Reply with quote
I'd do my own breaking in period, probably about half or quarter of what the manufacturer says, just ensuring that WHENEVER I ride the bike, I warm it up completely.
Having said that, I tried to ride with the choke on the other day, no wonder I was going so slowly Wink
CBRPETER
PostPosted: 09:23 - 25 Oct 2004    Post subject: Reply with quote
lol. I wouldn't thrash it early just for the reason that i payed a shit load for it and i really don't want to wreck it, then on the other hand all this talk about clicks and unsealed pistons and bore have made me confused. Confused
Shes my life, shes so rad and shes the best ride i ever had!!
Rory
PostPosted: 12:50 - 25 Oct 2004    Post subject: Reply with quote
The one you really want to read is this one;
https://www.mototuneusa.com/circular_logic.htm
My Old CBR400RR | Bike Oil FAQ | Petrol FAQ
PostPosted: 12:58 - 25 Oct 2004    Post subject: Reply with quote
New bike or new bearings, serious top/bottom end work I would take it easy for the first bit.
A simple case of new rings and a quick hone or a rebore (on alloy engine) and new piston without a bearing change for a previously run-in motor. I would consider the high-rev running in technique using mineral oil and changing it + filter after 20 miles or so.
sickpup
Old Timer
PostPosted: 13:25 - 26 Oct 2004    Post subject: Re: Run it in or thrash it? Reply with quote
Sorry but can you explain this internal oil leak. It's been a while since 2 strokes were sold in the states and I really can't work out how you could have an internal oil leak on a 4 stroke since pretty much the whole internal engine space is a great pool for oil. Unless of course you mean the seal between the head-cylinder or cylinder-crankcase in which case this has nothing to do with running in as it's not a moving part.
Not trying to demean your post just don't understand it.
iCraig
PostPosted: 15:01 - 26 Oct 2004    Post subject: Re: Run it in or thrash it? Reply with quote
He probably means the piston/oil seals aren't sealing against the bore and its burning oil, or it could be that the head gasket has gone and water and oil is leaking in and out?
sickpup
Old Timer
PostPosted: 15:41 - 26 Oct 2004    Post subject: Re: Run it in or thrash it? Reply with quote
Thing is thats what I thought of. The problem with this is the head gasket won't be affected by running in unless its a duff one or the bike was overheated and if its burning oil chances are it wasn't warmed up to operating temp before thrashing or was bored to large. Both of the above make the scenario listed above worthless as an example as its to ambiguous.
The last post was made 22 years, 27 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 83.66 Kb
