gears dont feel right on aprilia rs125? missing/sticky gears
jordey
PostPosted: 19:24 - 22 Sep 2012    Post subject: gears dont feel right on aprilia rs125? missing/sticky gears Reply with quote
on my project rs 125 (mechanically working though) the gears don't feel right. the bike is on the paddock stand, and i find it difficult getting it into neutral (tested by turning back wheel). also, the other gears feel difficult to get into, and i can't feel 6 gears, i can feel it going through 1,2, 3 then can't feel anymore gears after that. it just doesn't feel smooth, or like the gears are sitting in properly when selected. what could be the problem?
jimspeed
PostPosted: 20:35 - 22 Sep 2012    Post subject: Reply with quote
is this with the engine running? as if not you will struggle to select many gears due to the gear "dogs" not lining up without anything turning.
and yes neutral is sometimes hard to find on lots of bikes.
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
jordey
PostPosted: 20:40 - 22 Sep 2012    Post subject: Reply with quote
yep, i've done it with the bike off, and with it running
jimspeed
PostPosted: 20:45 - 22 Sep 2012    Post subject: Reply with quote
how's the chain? if its really slack it can make gear selection hard too.
or maybe something internal inside the box but I would be tempted to try it under load on a road before condemming it.
I bought a gpz400r as a project and we couldn't find neutral, as the muppet who I bought it off had put the gear rod on the wrong way round meaning you had to click down from 1st to 6th instead of up lol
jordey
PostPosted: 20:59 - 22 Sep 2012    Post subject: Reply with quote
well the bike has gp gearing so is reversed. it feels like it's missing the last 3 gears, strange. i also find it difficult to get the gears in properly. i dont think the chain is loose, but i will take a picture of it tomorrow. the bike is ex race if that means anything to this problem. could it be a clutch or gearbox problem?
jordey
PostPosted: 15:43 - 24 Sep 2012    Post subject: Reply with quote
this is the chain:
https://i50.tinypic.com/34ga3k3.jpg
Alpha-9
PostPosted: 15:51 - 24 Sep 2012    Post subject: Reply with quote
Measure it's slack, says it should be 25mm right there on the swing arm
Looks a lot slacker than that Thinking
Fzr-600 1999
DMCpro
PostPosted: 16:26 - 24 Sep 2012    Post subject: Reply with quote
subframes twisted too
Honda CB-1, TS125X
VW Golf Estate
Priliars125
PostPosted: 16:36 - 24 Sep 2012    Post subject: Reply with quote
Was it the chain in the end? It does look loose as fook lol
jordey
PostPosted: 17:06 - 24 Sep 2012    Post subject: Reply with quote
how?
jordey
PostPosted: 17:15 - 24 Sep 2012    Post subject: Reply with quote
https://www.youtube.com/watch?v=y0_0GfXjZFY
i used the method at 1:00 to check the chain tension with the bike in the paddock stand, and it measured at 63mm!
jordey
PostPosted: 18:01 - 24 Sep 2012    Post subject: Reply with quote
also, this probably sounds stupid, but how do iadjust the chain? ive looked it up, and most say to loosen the wheel nut, then adjust the allen bolts on either side evenly, but i cant see these...
PostPosted: 19:36 - 24 Sep 2012    Post subject: Reply with quote
No it doesn't. It doesn't look too bad. You need 3cm of play at the tightest part of the chain in the centre of the lower chain run. It might be a little loose but it isn't too bad.
I'd expect the gears to be stiff if the chain was too tight, but not too loose.
To adjust it, you take an open ended spanner and you turn the two bolts which press against the chain adjusters. The chain adjusters are the square things which the rear wheel axle goes through.
Obviously you turn both bolts the same way, which means you move the spanner up on one side, and down on the other depending on if you are tightening or loosening the chain.
jordey
PostPosted: 21:07 - 24 Sep 2012    Post subject: Reply with quote
yeah i realised i'd have to adjust those bolts after looking at it for a bit. theres two bolts though, would i first loosen the bolt furthest away from the axle, then adjust chain length with the bolt closest to the axle? and would an adjustable wrench be fine for it? its just that most places ive seen it talked about say to use fixed 10/11mm wrenches.
thanks mate though you've been really helpful. what do you think the problem could be with the gears? my explanation may not have been great
The last post was made 14 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 80.23 Kb
