My crashed 2011 Yamaha R6 project
catalin13
PostPosted: 19:53 - 21 Sep 2012    Post subject: My crashed 2011 Yamaha R6 project Reply with quote
Hi everyone, My name is Catalin, I'm 20, new on this forum and I want to show you my project with a 2011 Yamaha R6, crashed. I just bought her 2 days ago, the guy hit a car not at very high speed and dropped on the right side. The list is: forks, front fairing, headlight, speedometer and a rear fairing which is not very important. Now.. I tried to start it using jumpers from my car and I had no success. You can hear the gas pump when turning the contact and the engine is spinning but it's not starting. That's my main issue, does anyone know what I should do? Has it got an immobiliser or something that doesn't let the bike start after the crash? I wanna tell you that the bike is sitting in the garage since february and the battery is flat. I'll post some pictures as well. Thanks in advance!
https://imageshack.us/a/img694/8509/img3267hv.jpg
https://imageshack.us/a/img696/2916/img3272u.jpg
catalin13
PostPosted: 20:40 - 22 Sep 2012    Post subject: Reply with quote
checked some fuses today, found a small fuses box just near the radiator and the battery ones. where can the main fuse be? took all the fairing off and i'm waiting for the forks to come.. and i already ordered all the fairing, headlight, everything. it's too new to streetfight it, my opinion.. this bike is worth fixing
Alpha-9
PostPosted: 20:51 - 22 Sep 2012    Post subject: Reply with quote
https://yzfr6.net/manual/?PHPSESSID=494ed7f6f838f805e1abbcb046851783
Fzr-600 1999
Nick 50
PostPosted: 20:52 - 22 Sep 2012    Post subject: Reply with quote
Edit* for being dumb.
https://partsfinder.onlinemicrofiche.com/yamahagenuineparts/Yamaha_OEM/YamahaMC.asp?Type=13&A=701&B=12
catalin13
PostPosted: 22:23 - 22 Sep 2012    Post subject: Reply with quote
It's a 2011 r6 black and gold..And yes, i checked the small boxes with like 5-6 fuses, they're ok. I checked the 2 fuses from the battery but there was no point because the battery is working, with jumpers.
TUG
PostPosted: 18:28 - 23 Sep 2012    Post subject: Reply with quote
Main fuse is next to the battery under the seat. It's a block like connector red in colour if i remember correctly (haven't worked for yamaha for about 4 years now) is has plastic on the top that acts like a window so you can see clearly if the fuse has blown. If the bike is missing the clocks this might cause some issues as the thing is practically a computer that controlls everything from fuel ratios to diagnostics, its a serious bit of kit.
Haz ER-5, innit!
jeddy11
PostPosted: 18:36 - 23 Sep 2012    Post subject: Reply with quote
Has this bike not have a tilt switch some place ? usually to cut the fuel pump and other electronics in case of it going down ?
Fuelly My Z1000SX
cbt 06/08/11 mod1 (second go) 01/08/12 mod2 21/09/12
Varadero Viking YBR125>Varadero125>ER6F>Z1000SX !!!
stonesie
PostPosted: 20:18 - 23 Sep 2012    Post subject: Reply with quote
Good thought, find the tilt switch and give it a tap. It shouldn't stick but it might have done.
Saying that, when mine went faulty it didn't cut the bike out at all. It just put the engine management light on Confused
catalin13
PostPosted: 21:17 - 23 Sep 2012    Post subject: Reply with quote
Really good point here, the odometer is completely missing, i was thinking about this but curiosity just made me try to start it just like that. Now, anyone knows where that tilt switch could be? And, when i'm gonna mount the new speedo it's gonna need a resoft or something like that?
There are two fuses connected to the battery checked them but they are okay
salty21
PostPosted: 21:25 - 23 Sep 2012    Post subject: Reply with quote
If the clocks are missing it wont work at all. I know my 600rr wont do anything without the clocks plugged in
sidewinder
PostPosted: 18:26 - 25 Sep 2012    Post subject: Reply with quote
Clutch in and neutral to start it.The tilt switch should reset it self after about 5 mins Smile Or as above Thumbs Up
catalin13
PostPosted: 18:53 - 25 Sep 2012    Post subject: Reply with quote
nea, I tried everything.. with the clutch it won't start. first gear, clutch in, lifted the jack, same.. i believe that it needs the speedo to start.. and I searched the tilt switch but I can't find it.
catalin13
PostPosted: 18:43 - 19 Oct 2012    Post subject: Reply with quote
ok. starting the bike was not a problem, managed to start it with the new speedo. changed the forks, mounted the whole front end back, the bike is working properly. now, the problem that i have.. when i mounted the side pannels i saw that the wheel is still touching the fairing at the bottom. i think it could be the head of the forks, i am not sure.. so the bike is going next week to Yamaha in Woking. I will let them sort the forks out. I hope it won't be any major problem, I am 100% sure that the frame is ok. After this, the project is heading to the finish.. Smile
RideLimousin
PostPosted: 23:15 - 19 Oct 2012    Post subject: Reply with quote
Maybe the yokes are bent?
Motorcycle Touring Holidays in France: Ridelimousin
See my ridelimousin renovation blog: https://ridelimousin.blogspot.fr
See my renovation thread: https://www.bikechatforums.com/viewtopic.php?t=244340
catalin13
PostPosted: 23:19 - 19 Oct 2012    Post subject: Reply with quote
could be, one of the yokes or the pipe between them.. when the wheel is straight the yoke stands a bit to the right, it's not quite in his straight position..
grant965
PostPosted: 09:46 - 20 Oct 2012    Post subject: Reply with quote
just bypass everything and connect starter to the battery?
Ex bikes: 05 Suzuki En 125, '98 Yamaha Thundercat, '08 Honda cbr125, '05 Kawasaki z750, '03 Triumph Daytona 600, '91 Kawasaki ex250, '03 Hyosung Comet 125
Current Bike: '02 Suzuki TL1000R
Alpha-9
PostPosted: 12:17 - 20 Oct 2012    Post subject: Reply with quote
Hey its not a project if you pay a garage to do it!
Fzr-600 1999
catalin13
PostPosted: 14:14 - 21 Oct 2012    Post subject: Reply with quote
Have u got a problem with me or what? don't say nothing about someone until u met them. I didn't ofense anyone so don't you do it!
And scuze me that i will let yamaha do the forks for me properly in stead of me ruining it. i wouldn't want to ride a 2011 bike which is completely repaired by me. If you would, your problem.
BigDan1190
PostPosted: 15:00 - 21 Oct 2012    Post subject: Reply with quote
https://d24w6bsrhbeh9d.cloudfront.net/photo/4692900_460s.jpg
https://i.imgur.com/tHw0b.gif
catalin13
PostPosted: 19:45 - 21 Oct 2012    Post subject: Reply with quote
Ok, someone please delete this topic, i won't waste my time with creatures like these here.. thanks to the ones who really helped me. Wink
shereen
PostPosted: 20:03 - 21 Oct 2012    Post subject: Reply with quote
Do not take it there - they are rubbish. Take it to Fletchers Autos across the road from there. Kevin who runs the garage used to work for Yamaha and knows his stuff. And he will be a lot cheaper!
The last post was made 14 years, 4 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 131.38 Kb
