Backfires and cut outs when restarting after brief stops
Newbe
PostPosted: 18:33 - 22 Sep 2012    Post subject: Backfires and cut outs when restarting after brief stops Reply with quote
I have just got a '99 SV650s and rode it back 35 miles after purchase, had a huge grin, got the Mrs to put on her leathers and grab her bike so we could go for a ride together and within a mile had a loss of power and as I approached a roundabout and changed down got a big backfire. Had to change down to 2nd due to traffic on the roundabout and it just cut out. Started again with a little choke but then cut out when changing down again. Limped home and left it for a few hours and took it out again, no probs, stopped again for 10 mins and when I got back on it again same thing, backfire's and cut outs , Ive checked the tank vents and they are all good - any ideas??
flumpy7
PostPosted: 21:58 - 22 Sep 2012    Post subject: Reply with quote
Has it got a manual choke? Is it on?
Simple checks first Thumbs Up
2012 Sinnis apache
Casper
PostPosted: 22:08 - 22 Sep 2012    Post subject: Reply with quote
Is this your first bike after passing your test?
Could you be making the mistake of using the choke every time you get on a bike?
Newbe
PostPosted: 22:56 - 22 Sep 2012    Post subject: Reply with quote
Yes first bike since passing my test, Very possible that I am making the basic error of leaving the choke on, ill give it a go tomorrow and see if it is the normal newbe error, I have text the bloke who I got the bike from who is a really genuine bloke and he never had the issue so more than likely me and not the bike. Thanks for the response as confidence is easily knocked when you first get started.
Casper
PostPosted: 23:17 - 22 Sep 2012    Post subject: Reply with quote
First ride of the day use the choke mate. If an hour stop you should not need it unless very cold day. The bike may not run at proper revs after an hour but once you get running its fine.
For the first start of the day i tend to start bike on choke. Put the helmet one, zip jacket and put gloves on. Push choke half way in and start to ride bike. 1-200 yards up the road turn off choke.
Yes if you side to work and bike sits for eight hours then do the same.
You will soon get the hang of it. Not every bike will be the same. Its just a case of getting used to what yours likes for start up.
Triumph1300
PostPosted: 06:00 - 23 Sep 2012    Post subject: Reply with quote
Just a silly thought, I had a F650 BMW with very similar symptons, and spent weeks cleaning carbs, airways, etc etc.
Turned out to be knackered spark plug caps.................
Just a thought, but your circumstances and symptons sound the same.
Running along, things a bit cooler - no problem.
Restart and ride off / traffic, things a bit hotter - problem
BWJ
Back on a BMW R80RT
Punctuation - the difference between knowing your shit, and knowing you're shit Smile
The last post was made 14 years, 55 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 47.98 Kb
