PCB printing
U_W v2.0
PostPosted: 00:31 - 22 Sep 2012    Post subject: PCB printing Reply with quote
does anyone on here have the facilities to make some basic PCB's?
single layer, through hole (i'll happily drill out 0.75mm holes myself) basic circuit layouts like various 555 timer circuits?
i had some copper clad board and ferric acid but my printer sucks and i couldnt get the schematics to transfer to the boards.
im needing 2 different circuit boards and 2 of each board made at the moment. and in the nearish future probably be needing some different ones made up too
Im-a-Ridah
PostPosted: 11:08 - 22 Sep 2012    Post subject: Reply with quote
why?
and where are the files?
Codemonkey
PostPosted: 11:50 - 22 Sep 2012    Post subject: Reply with quote
Try some photoresist covered copper clad board, that way you just print your layout onto some transparency sheet and expose it onto the board with some UV lamps. Develop it with a teaspoon of caustic soda in a pint of lukewarm water, rinse then etch as usual. Used to do loads like that in my previous job including double sided boards.
Failing that, just use stripboard/veroboard if you've not got many to make.
Test Passed 10/05/2011 Current bike: XJ6-N
U_W v2.0
PostPosted: 12:49 - 22 Sep 2012    Post subject: Reply with quote
i've got to make up the schematic files again.
i need these as printed circuit boards for the cleanliness and size.
they're being used in models and need to be kept small enough and tucked out of the way.
stripboard and vero board. i used those on the voyager model and is a pain in the backside.
i dont have the resources to do this myself. otherwise i would
lihp
PostPosted: 17:22 - 22 Sep 2012    Post subject: Reply with quote
use inkjet to print then press it onto the copper with an iron, simple Wink
chrisw
PostPosted: 19:32 - 22 Sep 2012    Post subject: Reply with quote
Inkjet? Never seen it done with one of those.
HP Laser printer (I've got a Dell as well but that doesn't work, the toner is different), magazine paper (pick a page with as much white on as possible), a normal clothes iron and a tupperware tub filled with acid (Ferric chloride from memory).
I've made some relatively complex ones with that method and it works well.
lihp
PostPosted: 21:54 - 22 Sep 2012    Post subject: Reply with quote
Have to be a bit more careful but can get a very good transfer from it
Ariel Badger
PostPosted: 23:06 - 22 Sep 2012    Post subject: Reply with quote
Let me look at the artwork and I will quote for you.
Alpha-9
PostPosted: 23:21 - 22 Sep 2012    Post subject: Reply with quote
www.yenka.com can do it
Fzr-600 1999
U_W v2.0
PostPosted: 02:24 - 23 Sep 2012    Post subject: Reply with quote
ariel i'll get the schematics to you as soon as i get them done.
just changed over to ubuntu (frigging mint13 was driving me nuts) so sorting that out.
i have a samsung laser printer but the toner is crap for the iron method.
you are correct in the acid. ferric acid. i have a 500ml bottle sitting around doing nothing.
Charlie
PostPosted: 08:52 - 23 Sep 2012    Post subject: Reply with quote
PCB train do a fast prototyping service which I've used in the past.
The last post was made 13 years, 322 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.37 - MySQL Queries: 13 - Page Size: 65.73 Kb
