Need help, changing fork seals. Manchester area.
Hokum
PostPosted: 14:28 - 23 Sep 2012    Post subject: Need help, changing fork seals. Manchester area. Reply with quote
I've taken my front right fork off the yoke and I've got the dust seal off, i've released the damper bolt, but I can't undo the fork cap.
The bolt is the width of the chrome stanchion. I simply don't have anything big enough to get it off.
Anyone able to help? I need a hand getting the damn thing a part.
Sane: To know when you are doing something crazy.
Hokum
PostPosted: 18:24 - 23 Sep 2012    Post subject: Reply with quote
I'd guess at least 30mm I can take a measurement.
Islander
PostPosted: 18:32 - 23 Sep 2012    Post subject: Reply with quote
Once you've found the right size socket, stick the fork back in the clamps and retighten them, loosen the cap and then remove the fork again.
If you do decide to use a vice then use something to protect the stanchion from the rough vice jaws. Thumbs Up
Hokum
PostPosted: 19:37 - 23 Sep 2012    Post subject: Reply with quote
It is a Cagiva roadster.
https://www.bikechatforums.com/viewtopic.php?p=3322500&highlight=#3322500
Thanks for the offer.
I've got the seals, oil, just not the equipment!
Hokum
PostPosted: 09:40 - 24 Sep 2012    Post subject: Reply with quote
I picked up a head, but I don't have a vice to fit it in!
Islander
PostPosted: 09:46 - 24 Sep 2012    Post subject: Reply with quote
Stick it back in the fork clamps, tighten them and then loosen the nut off.
Hokum
PostPosted: 10:33 - 24 Sep 2012    Post subject: Reply with quote
The bolt is flush with the stop of the yoke Sad it isn't raised like the Honda ones. I'll work something out.
I'll get a portable work bench to use as a vice.
Islander
PostPosted: 10:47 - 24 Sep 2012    Post subject: Reply with quote
If the leg can't be pushed higher in the yoke then how about just using the bottom clamp?
Hokum
PostPosted: 10:57 - 24 Sep 2012    Post subject: Reply with quote
I could try that, just don't want to bend the yoke. But it's worth a try.
Hokum
PostPosted: 11:06 - 24 Sep 2012    Post subject: Reply with quote
Yeh got a 32mm one.
PostPosted: 11:08 - 24 Sep 2012    Post subject: Reply with quote
Put it back in the yoke and undo it, far less chance of fucking it compared to if you use a vice. Thumbs Up
The last post was made 14 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.28 - MySQL Queries: 13 - Page Size: 82.27 Kb
