General Fuel Pump Question
MAR5H7
PostPosted: 17:58 - 22 Sep 2012    Post subject: General Fuel Pump Question Reply with quote
Ok, so I lifted my tank off my Thundercat this morning to change the air filter and must have caught the fuel tap in the process and switched it to off
But i was curious that if you turn the ignition to and and theres no fuel in the pump, will it buzz?? as this is what seemed to occur until fuel was in the pump :S
I tried riding the bike before this and 1/4 a mile up if shut down suddenly and was very unresponsive and near the end I could tell only air was getting in because pull the throttle was acting as a brake :S
Just making sure Iv corrected the mistake and not about to get stuck before work
Ex: CBR 125 R 06', ZXR 400 96' (RIP), Bandit 650 06'
Owned: SRAD 600 97'
Current: YZF Thundercat 600 96'
MAR5H7
PostPosted: 18:35 - 23 Sep 2012    Post subject: Reply with quote
_Iain_ wrote:
Fuel pump buzzes as its pumping with nothing in there. Its just the sound of it running.
That's all I needed to know Smile
It stopped when the tap went back on (obviously) But just was worried about being stranded miles away early hours on a Sunday morning because my bike wouldn't want to start cos of that
Numb nuts here will check that next time I'm fiddling round with the air filter Very Happy Thanks!
Owned: SRAD 600 97'
binge
Emo Kiddy
PostPosted: 18:59 - 23 Sep 2012    Post subject: Reply with quote
Vincent wrote:
'Useful to note that, if it packs up, you can sometimes get round by-passing the fuel pump, you may find that the fuel tank needs to be full or over a certain level for the gravity feed to work but it's got me home a couple of times when I've been stuck.
Laughing Funny you should say that.
My chaly has an in-frame fuel tank, and on a standard 72cc setup, it's probably okay, but with my 150cc engine and bigger carb, it wont gravity feed under 3/4 full tank, so I fitted an inline vac pump.
Works great, but I've got a small piece of hard fuel pipe to bypass the pump if it ever packs up, neatly tucked under the seat. Razz
The last post was made 14 years, 54 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 1.34 - MySQL Queries: 13 - Page Size: 47.26 Kb
