What's a good way of assessing changes in performance?
PostPosted: 19:02 - 22 Sep 2012    Post subject: What's a good way of assessing changes in performance? Reply with quote
So an easily done, objective and preferrably quantitative test of how a bike is performing relative to how it did previously.
So if I start doing a few engine modifications on my restricted VFR, a way of checking to see if they have increased the power output or not.
A dyno run is all well and good but it's an expense and a hassle (and is in iteslf pretty subjective anyway). Seat of the pants has been proven to be nowhere near.
0-60 times seem obvious but it's difficult to be consistant and measuring it isn't as easy as it seems.
Standing 1/4 miles are similar and so much is down to the launch.
I was considering something like crossing a fixed point on a road nearby at, say, 4,000rpm in third gear then snapping the throttle open and seeing how far I travel by the time it hits 11,000?
Or a 40mph top gear roll-on between two fixed points and see what the speed is by the second point?
Islander
PostPosted: 19:46 - 22 Sep 2012    Post subject: Re: What's a good way of assessing changes in performance? Reply with quote
I'd think either of these would be a good option, it should set the parameters the same for each run as long as you're careful. Thumbs Up
PostPosted: 21:03 - 22 Sep 2012    Post subject: Reply with quote
Datalog accelleration over a fixed time in a certain gear. I'd lend you the hardware but the last person who borrowed it fecked it up.
PostPosted: 19:03 - 23 Sep 2012    Post subject: Reply with quote
Find a clear road and record the performance along there accurately (ie, half decent high frequency GPS), highish gear roll on from low speed to silly speed (lower gear means you get to the red line, higher gear means it takes longer so you will have a more accurate graph). Do your mods and do it again (same weather conditions, same amount of fuel in the tank, same clothing, etc).
In theory you could work out a dyno curve from the results, but practically I would just make everything as consistent as possible to get comparable results.
PostPosted: 21:33 - 23 Sep 2012    Post subject: Re: What's a good way of assessing changes in performance? Reply with quote
I think there may be phone apps that can do this?
Though may be just for OBDII vehicles.
I have a veypor which can do this - if I can work out where it is (unlikely in the next few weeks to be honest), you're welcome to borrow it and have a play.
Better yet, take work on one of the basic formulas along the lines of:
Pub power = Money spent + (brands names * shinyness of parts).
PostPosted: 22:56 - 23 Sep 2012    Post subject: Reply with quote
Pardon the sidetrack gents...Just how much influence does atmospheric pressure play in this, if any? And air temperature? I ask as I get a noticeable power increase on cool days, mornings especially.
Not so much on the big twin, moreso the single 250.
PostPosted: 23:07 - 23 Sep 2012    Post subject: Reply with quote
A good point - dyno places will have things worked in to their figures to account for this.
The 125/250cc 2 stroke GP bikes would be seen doing plugs chops in the morning to see if they need to change jetting for the current conditions!
Islander
PostPosted: 23:10 - 23 Sep 2012    Post subject: Reply with quote
As long as the two (or more) test runs were done as immediately after each other as reasonably possible then not much really. If they were done on different days with different weather conditions then maybe a difference could be measured but then again that's a whole other experiment. Mr. Green
temeluchus
PostPosted: 00:41 - 24 Sep 2012    Post subject: Reply with quote
Dear but cool:
https://www.veypor.com/vr2.html
there are a few datalogger and speedo apps for android which may do what you want.
PostPosted: 08:18 - 24 Sep 2012    Post subject: Reply with quote
All good ideas.
I was thinking more along the lines of something I could do with either a stopwatch or (preferrably) measured points and/or the speedo.
I don't have any GPS compatable related electronic gizmos.
Thing is, with this new VFR being restricted, I DO have the CDI and carbs off the old one and I just got a set of UK market cams off ebay for much cheapness (there is no real second-hand market for VFR750 cams, they don't fail as a rule).
I'm concious that there is a real potential to make things worse by swapping parts off different models.
On a quick "seat of the pants" test last night (I put the old brakes back on, they are awful!), it appears to go like shit off a wet shovel compared to my old one. This might be because it was dark and I'm too used to riding the enfield but a dyno run might be in order to check some of this stuff hasn't already been done.
garth
PostPosted: 08:39 - 24 Sep 2012    Post subject: Reply with quote
Video the clocks and compare?
PostPosted: 12:33 - 24 Sep 2012    Post subject: Reply with quote
Going to be better than a stop watch certainly; if there's big differences, it should be fine. Small differences are going to be pretty hard to measure decently.
Walloper
PostPosted: 13:02 - 24 Sep 2012    Post subject: Reply with quote
Performance can easily be compared before and after by the methods listed.
The place you test must be the same.
Climatic conditions must be the same. i.e. Height of summer versus depths of winter when air densities are significant. (Dependant on how exacting your standards are.)
There is a simple performance test for Off Road equipment where each day the equipment has to freewheel down a known ramp (a bit of the quarry/mine measured out as a test site.) and apply full braking.
The equipment must stop within a measured distance or it must go to the shop for repair.
So your test area must be between McGinty's paper shop at the bottom of the hill and the bus stop outside Tesco at the top. 300-400 yds should be easy to time.
PostPosted: 18:09 - 24 Sep 2012    Post subject: Reply with quote
Normal GPS might be a bit slow. Most are only 1Hz. Probably overall give you an idea, but might not give you any real idea of where it has gained / lost speed. You can get high performance GPS systems (10Hz ones are not that expensive).
Temperature will have quite an effect.
The last post was made 14 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 86.21 Kb
