CBR929RR-Y Digital Display Not working
Nick280
PostPosted: 19:59 - 23 Sep 2012    Post subject: CBR929RR-Y Digital Display Not working Reply with quote
Hi,
I went for a ride on my 2002 CBR 929 RR-Y today but when switching the ignition on, the LCD Displays, main and temp, did not work. When started, neither did the rev counter.
The Turn indicators, neutral light, main beam light and back lighting all work but no LCD or Rev counter.
I went out on it anyway but still didn't work when i got back. Tried disconnecting the battery for a couple of hours, tried removing the clocks but still blank.
I read a bit about this on the Internet but nothing about how to fix it. There is a guy on ebay offering to fix them for £125.00 but as my KTM just shreaded a main bearing, I have very little spare funds at the moment.
Does anybody know how to fix the fault?
Thanks,
Paddy Blake
PostPosted: 20:27 - 23 Sep 2012    Post subject: Reply with quote
You will need a manual to check this out.
I worked on one theses a few times and in the manual it says there is a wire connector under the seat I believe that you short.
There is a light at the clocks that flashes to tell you what is wrong.
You count how many times it flashes and there is a code in the manual that will say what is wrong.
I think the connector has blue and a white wires and is not connected to anything.
Nick280
PostPosted: 20:32 - 23 Sep 2012    Post subject: Reply with quote
I know the wires you talk of but didn't know what they did. Are these the fault code reader pins?
I'm not familiar with bike diagnostics but I know quite a bit about car diagnostics.
So just short the 2 pins out and switch ignition on yeah?
Count the flashes from the ECU light?
Paddy Blake
PostPosted: 20:54 - 23 Sep 2012    Post subject: Reply with quote
I cant remember that well but you short it with a paper clip/ turn on the ignition with the kill switch turned to run I think.
You should be able to download a manual easy enough.
Noxious89123
PostPosted: 23:19 - 23 Sep 2012    Post subject: Reply with quote
Here's a download link for a workshop manual.
https://www.cbrextreme.com/downloads/manuals/honda_cbr929rr_repair_manual-10.html
Take a look at section 5-8, it goes into detail about the self-diagnostics and reading the error codes.
Section 5-12 tells you what the error codes mean.
There's also information in there about checking voltages for the tachometer/speedometer, to find out which component is faulty. Ie. ECU / speedo / tacho / speed sensor etc.
Fireblades.org says that the speed sensor is the usual culprit, but that wouldn't explain why you've lost the rev counter too. Would be worthwhile to check all the fuses, as that's quick and easy to do first.
Thumbs Up Smile
janner_10
PostPosted: 03:20 - 24 Sep 2012    Post subject: Reply with quote
If its anything like the 600, there is a connector on the LHS underneath the front headlight fairings. My digital speedo was playing up, I had the correct voltage and pulsing from the sensor.
The cable was routed very badly to this connector so every time I rode it would pull the speedo pin out slightly. Cleaned the connectors and re-routed - all is well now.
I would check this connector, could be loose if none of your display is working.
Nick280
PostPosted: 19:44 - 24 Sep 2012    Post subject: Reply with quote
Thanks all for help.
I tried to read the codes but it would appear that the red LED doesn't work either.
I checked the voltages and earths, connections etc and all appear to be ok, leading me to think it is a fault with the unit itself.
Anybody had a similar fault?
Matt-
PostPosted: 19:48 - 24 Sep 2012    Post subject: Reply with quote
You will be lucky to find someone with the same fault on the same model,
Best bet mate is to go in a main dealer and speak to a technician and see what they say...
then if they say it's a common problem with the unit it self, you can buy a second hand unit online...
Good luck...
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
janner_10
PostPosted: 20:06 - 24 Sep 2012    Post subject: Reply with quote
Try having a dig around here Nick: https://cbrforum.com/forum/
I would avoid the dealer, when I phoned about my problem, they were trying to sell me a new display!
Nick280
PostPosted: 20:11 - 24 Sep 2012    Post subject: Reply with quote
Cheers Janner,
I'll have a look and see if I can find anything useful.
I cant afford a new unit, I've read they're £600+
My KTM has just absorbed £700 of my money and I'm not done yet Sad
The last post was made 14 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 65.65 Kb
