Blipping the throttle between gears while changing down?
Ribenapigeon
PostPosted: 13:07 - 24 Sep 2012    Post subject: Blipping the throttle between gears while changing down? Reply with quote
I do this all th time. But would be viewed as being too sporty during a test?
goto10
PostPosted: 13:11 - 24 Sep 2012    Post subject: Re: Blipping the throttle between gears while changing down? Reply with quote
I do it too, conserves clutch life and makes a smoother downshift. Unless you've got a particularly noisy exhaust I doubt they'd notice or care.
Matt-
PostPosted: 13:12 - 24 Sep 2012    Post subject: Reply with quote
Know need for it, only when showing off ...
Just change down as normal.
Then go back to personal preference after passed.
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
goto10
PostPosted: 13:17 - 24 Sep 2012    Post subject: Reply with quote
Matt
Utter rubbish, it's not showing off at all! It balances the bike when slowing down quickly and down-shifting.
Doing it in a car requires more finesse (heel & toe) but it's still worth learning. But it's easy on a bike, so why not do it?
I did this on my test with no issues what-so-ever, mainly because I was firmly in the habit of doing it.
weasley
PostPosted: 13:32 - 24 Sep 2012    Post subject: Reply with quote
Smoother downshifts maintain rear wheel traction and bike stability.
The clutch also gets an easier life.
Not really showing off (unless you can't do it, in which case maybe.... Wink).
Alpha-9
PostPosted: 13:38 - 24 Sep 2012    Post subject: Reply with quote
I do that!
Didn't realise it was a 'thing'
Dunno what the principal of it is, spinning the engine so it's the same speed as the clutch plates when you disengage the clutch?
Makes for smoother shifting
any other useful 'things' like that?
Definitely keeps stabilility and traction even on a crappy 125, if you dump down the gear your back wheel soon tells you about it
Fzr-600 1999
ScaredyCat
PostPosted: 13:39 - 24 Sep 2012    Post subject: Reply with quote
I do it when changing down to match the revs, unless I want to use engine braking...
Andy
Honda CBF125 ➝ NC700X
Honda CBF125 ↳ Speed Triple
dogwafter
PostPosted: 15:39 - 24 Sep 2012    Post subject: Reply with quote
I do it all the time, it definitely makes for a smoother ride and is safer too so I imagine they won't care.
WillOdling
PostPosted: 18:12 - 24 Sep 2012    Post subject: Reply with quote
I do it too
2002 GSX R600
WillOdling
I do it too
2002 GSX R600
Ribenapigeon
PostPosted: 18:30 - 24 Sep 2012    Post subject: Reply with quote
Wooeee we all do it!
I do it because its smoother and it means you keep your velocity and have power immediatly available for powering away after the down shift (say through and out of a corner). Is easier on the clutch plates as well. Sounds great to boot Smile
My first proper job was driving a 7.5 tonne delivery lorry which had an old gearbox that didn't have synchromesh so I had to do a proper double de-clutch so learning to do a single de-clutch with a throtle blip on a car was easy and its no harder on a bike.
PostPosted: 19:03 - 24 Sep 2012    Post subject: Reply with quote
I do it all the time. Pretty much impossible to change down smoothly without doing it (unless you want to spend ages slipping the clutch when you change down).
RichieZX6R
PostPosted: 19:16 - 24 Sep 2012    Post subject: Reply with quote
Alpha-9 wrote:
I do that!
I do it as well and also didnt realise it was a done thing. Just seems to making changing down gears when slowing down easier.
Current: Kawazaki ZX6R 51
Past: Kawazaki ZX6R 96 - Honda CBR 600F4 05 - Dragstar 125 02 - Honda CB 400 SF 94 - Honda NSR 125 51 - Gilera Runner XV125 04
bikertomm
PostPosted: 19:33 - 24 Sep 2012    Post subject: Reply with quote
+1 do it all the time
Nothing more satisfying... (that I've learnt yet)
than a nice blip of the throttle as she cries into a lower gear Wub
You can just tell it's so much better for the bike and balance ect.. not showing off at all!
woodall57
PostPosted: 19:46 - 24 Sep 2012    Post subject: Reply with quote
https://www.youtube.com/watch?annotation_id=annotation_526751&feature=iv&src_vid=0u9R3h9iHwM&v=MIhycth8msU
https://www.youtube.com/watch?v=0u9R3h9iHwM&feature=plcp
russ aka roadcraft nottingham has a nice vid about it
i like doing it because for some reason i find it satisfying having the bike go down a gear nice lol
cbt:4/7/12 theory:16/7/12 module 1:12/8/12 module 2: ?
JoeDougieDoug...
PostPosted: 20:47 - 24 Sep 2012    Post subject: Reply with quote
I do it, have done since the day I started riding... (well, close to!), I did it on my mod 2 and I never got a minor for it, I dont think they noticed / cared. As others have said, it does indeed make the clutches life easier and makes for a smoother change.
psychodame
PostPosted: 22:53 - 24 Sep 2012    Post subject: Reply with quote
I also do it as a matter of habit. You'll find it makes a slowing bike less jerky and the sound of doing it is nice too. I know it's a shallow thing to say, but I don't care.. so there! Tut Tut
Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence or stupidity.
-Anonymous
Ayrton
PostPosted: 23:01 - 24 Sep 2012    Post subject: Reply with quote
I do it and will do it on my test. It makes everything smooth and easier.
PostPosted: 23:18 - 24 Sep 2012    Post subject: Reply with quote
I don't know if anyone has already said but you are bringing up the engine speed to roughly match the speed it will be doing when you let out the clutch.
Other wise you would have the engine going at idle speed and when you let the clutch out the engine revs will be increased very quickly and jerkily from being driven by the rear wheel.
edit: Alpha-9 mentioned it Thumbs Up
Flatbadger
PostPosted: 00:26 - 25 Sep 2012    Post subject: Reply with quote
Funny how I've grown to understand what you all mean by reading through the thread!
If it don't work right, find a way to sort it out with technique - comes to us all naturally I suppose.
I've seen the gear-changing vids before, if I remember he recommends a bit of pressure on the gear lever before pulling in the clutch as well, I've tried it a few times but it's more of a conscious effort. Makes for a smoother transition still.
You're in ISIS
ocatoro
PostPosted: 01:43 - 25 Sep 2012    Post subject: Reply with quote
i've always done this in a car too, and never ever had to change a clutch. so i think it is a lot easier on the clutch than just dumping an idling engine onto the clutch.
i even started doing it on my cbt after quite a short time, felt pretty natural to be fair.
the whole clutch slipping thing though is going to take some getting used to. i feel so guilty doing it
CBT - 17/09/12 * Theory - 23/10/12 * Mod1 - 05/03/13 * Mod2 - 25/03/13 * BOSH!
Current - None Sad but shed project H100 (first bike Smile )
Past - ER5, '93 ZZR600, '92 CB400 SF, ZZR600 (again), yellow Monster 620, Blackbird - black Monster 620ie - '96 ZZR600
thepuma
PostPosted: 06:33 - 25 Sep 2012    Post subject: Reply with quote
Don't know what it is or if I do it. Neutral
765 RS
DrSnoosnoo
PostPosted: 09:31 - 25 Sep 2012    Post subject: Reply with quote
When you're slowing or changing down a gear. The revs you're in in 4th are lower than what they would be if you were doing the same speed in 3rd.
When you change down, and release the clutch, the back wheel then drives your engine to make it get to the revs it should be.
So when the clutch is in, give the throttle a twist (or a blip) and your revs will increase because there's no drive engaged and then release the clutch.
At least that's how I understand it
thepuma
PostPosted: 11:00 - 25 Sep 2012    Post subject: Reply with quote
In that situation I would go down another gear I think if I though I was going too slow for 3rd gear or if I felt it would labour the engine only knocking it down 1 gear. Then let the clutch out slowly.
765 RS
Shinigami
PostPosted: 12:24 - 25 Sep 2012    Post subject: Reply with quote
never done this, never tried..
heard bikes going past do it though, by the description it sounds like they were anyway.
I've never had any issues with stopping safely or lowering gears though...
The last post was made 14 years, 17 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 4.43 - MySQL Queries: 13 - Page Size: 128.52 Kb
