Fitting chain / sprocket set
Marmalade
PostPosted: 14:50 - 24 Sep 2012    Post subject: Fitting chain / sprocket set Reply with quote
I've just got a new sprocket & chain set for gsxr but don't have a chain riveter.
Is there someone within a reasonable distance (50 miles) of salisbury who would lend me one / let me fit at theirs / come here with it to let me use it.
Whatever works is fine with me or can i just muller it with a hammer and a nail?
Or could I just put in a spring/split link joiner and take it to a shop to get them to sting me for the pleasure of joining it properly?
New Sarum
PostPosted: 14:53 - 24 Sep 2012    Post subject: Reply with quote
You could try VP Motorcycles up at Old Sarum - his charges are reasonable.
Alpha-9
PostPosted: 15:03 - 24 Sep 2012    Post subject: Reply with quote
I got my chain cut off with massive bolt cutters
and put the new one on with my fingers and some mole grips
chain riveter is unneccesary depending on the chain, mine was a DID set
you just push the bars through and push the clip thing over it, simples
been a few months, had no issues Thumbs Up
was this type thing
https://images.motorcycle-superstore.com/ProductImages/OG/0000-DID-ZVM-X-525-Gold-ZJ-Rivet-Link.jpg
Fzr-600 1999
Derivative
Funnily enough, I've just ordered a chain riveter. Unfortunately I'm a good distance from you.
I could potentially mail it after I fit my new chain, probably cost £5 each way though, I imagine it's going to be a heavy piece of kit.
truslack
PostPosted: 15:10 - 24 Sep 2012    Post subject: Reply with quote
Alpha-9 wrote:
Well obviously a riveter isn't needed for a feckin split link chain Laughing Laughing
Alpha-9
PostPosted: 15:18 - 24 Sep 2012    Post subject: Reply with quote
truslack wrote:
No idea, I just go with whatever works, didn't even occur to me it was a split link Dance!
I'm a moron Laughing
Fzr-600 1999
Derivative
PostPosted: 15:20 - 24 Sep 2012    Post subject: Reply with quote
Split link chains are generally fine for 125's.
They're not recommended on bigger bikes because the link is weaker than the rest.
kotachi
PostPosted: 15:21 - 24 Sep 2012    Post subject: Reply with quote
Quoted for posterity/just so I can say.... we know!
CBT done - 24/03/2012, theory test done - 03/04/2012.. Mod 1 done -26/06/2012, Mod 2 done - 29/06/2012. Current steed: Cage.
Suntan Sid said: "Look at it this way, your employer wants to pay you the minimum amount, it thinks it can get away with, and extract from you the maximum amount of graft. Ergo it's your responsibility to ensure that karma is restored and you do as little work as you think you can get away with, for the maximum amount of money."
truslack
PostPosted: 15:25 - 24 Sep 2012    Post subject: Reply with quote
Any evidence to support that? The link should be just as strong as a rivet link, I've used them on quite a few big bikes and never had one fail yet.
Alpha-9
PostPosted: 15:26 - 24 Sep 2012    Post subject: Reply with quote
It was actually a typo
mormon*
Shifty
Wouldn't have got a split link if i'd realised it was one beforehand, didn't trust it at first, seems legit though
Fzr-600 1999
DrDonnyBrago
PostPosted: 15:28 - 24 Sep 2012    Post subject: Reply with quote
Edit - sent as PM
PostPosted: 15:48 - 24 Sep 2012    Post subject: Reply with quote
If you were heading past Maidstone/Orpington any time soon you are welcome to borrow mine. Piece of cake Thumbs Up
Derivative
PostPosted: 16:24 - 24 Sep 2012    Post subject: Reply with quote
'Weaker' is probably bad terminology.
More susceptible to failure (if both are fitted correctly) would be more accurate.
Quote from my CB500 Haynes manual:
'Warning: NEVER install a drive chain which uses a clip-type split link.'
I wouldn't be surprised if they were fine, but a snapped chain is not really something I'd want to mess with.
garth
PostPosted: 16:35 - 24 Sep 2012    Post subject: Reply with quote
I just use a big lump of steel bar behind the chain, held by another person, then twat the soft links over with a hammer.
Paullec
PostPosted: 17:17 - 24 Sep 2012    Post subject: Reply with quote
was always told to use a rivet like on a bike with hp Laughing
file off and and use a round nosed hammer with a support to the back of chain. My riveter cost 30 off ebay but i snapped it in half Rolling Eyes
anthony_r6
PostPosted: 17:32 - 24 Sep 2012    Post subject: Reply with quote
I also read that Split Links weren't as safe as a rivet link, and generally not a good idea for anything over 125cc.
PostPosted: 17:37 - 24 Sep 2012    Post subject: Reply with quote
I used one on my GS500, but its not really the epitome of performance Laughing
Derivative
PostPosted: 17:40 - 24 Sep 2012    Post subject: Reply with quote
'The Internet' seem to feel that there is a 60hp limit on rivet links in some countries.
I can't seem to find any data to back this up, but the 500 twins are about on that boundary.
Eddie Hitler
PostPosted: 18:44 - 24 Sep 2012    Post subject: Reply with quote
Contrary to my opinions before having a split link, I think they are fine for anything 600cc or below. Although mine was an old FZR600 it still shifted, and I did 7,000 miles on a split link with no issues at all.
Like any chain, keep it oiled and adjusted correctly and you shouldn't have any problems. Wouldn't ever have a split on a thou though Laughing .
PostPosted: 19:12 - 24 Sep 2012    Post subject: Reply with quote
I've got one and I have to do 170 miles tomorrow (25th) cause my bike is booked in for its 500 mile service on wednesday. Want me to bring it down?
.Chris.
PostPosted: 19:13 - 24 Sep 2012    Post subject: Reply with quote
Not quite sure why a clip-type link would be more likely to fail due to excess power than a rivet link? Presumably all the clip does is stop the side plate coming off, which is exactly the same as what the rivet heads do in a rivet link. The clip itself won't be transmitting any power.
Chris
1985 Kawasaki Z550F
janner_10
PostPosted: 20:34 - 24 Sep 2012    Post subject: Reply with quote
Sounds like you have many offers - but more than happy to post mine down and post back when your done. Thumbs Up
Marmalade
PostPosted: 20:38 - 24 Sep 2012    Post subject: Reply with quote
That would be great if you could. Where are you heading for?
PostPosted: 21:02 - 24 Sep 2012    Post subject: Reply with quote
I'm not going anywhere in particular. PM me your address and I'll be there sometime tomorrow late morning.
Marmalade
PostPosted: 14:01 - 25 Sep 2012    Post subject: Reply with quote
I had a polarbear turn up here earlier with a rivet tool. Thumbs Up
Job completed just in time for the rain to start.
Thank you to all those that offered to help out. Thumbs Up
The last post was made 14 years, 7 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 128.52 Kb
