| Fladdem |
 Fladdem World Chat Champion
 Posted: 21:45 - 22 Aug 2012 Post subject: Honda MT50/H100 project |
I have recently passed my mod 2, like all teenagers with a full motorbike licence I couldn't wait to hop back on my old moped. Or should it have been onto a 250? Never mind. For reasons unknown, I am back on the MT5. Recently, I bought a H100 engine to throw in it. What else will I need to get it running nicely, I reckon a h100 carb and maybe get a Honda MT80 exhaust to cope with the bigger engine. I don't want to rush into this and muck it all up, any advice would be great.
Thanks in advance.
By the way, I am trying to do this legally so I will inform my insurers and change the logbook, would it be a honda mt100 now? ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
I'm having more fun than a well-oiled midget. |
| dangerousdave |
 dangerousdave Traffic Copper
 Posted: 00:29 - 23 Aug 2012 Post subject: |
hi - sounds like a fun project.
for performance you'd be better off using the h100 exhaust, the mt80 exhaust isn't going to work too well on the 100cc engine. its not a high-rise exhaust like the MT pipe but engine will go a lot better.
use the h100 carb like you say, although the airbox of the mt5 wont work well with the bigger engine. consider using a clamp on air filter, but be sure to check the jetting in the carb. These carbs can make the motor run a bit lean if the jetting isn't checked.
yes, you'll need to update the logbook and send back to DVLA for this to be logged. Let your insurer know when you make the change as the bike will no longer be standard & will be classed as modified. ____________________ 1988 Kawasaki KMX 200
Previous: Yamaha YZF1000, ZZR600, KMX200, DT50, KX80, CG125, PF50 |
| Fladdem |
 Posted: 12:41 - 23 Aug 2012 Post subject: |
Actually, at the moment the bike doesn't even have an air filter, I took the air box out to clean the air filter because I thought that a year of riding means he filter needs cleaning and I looked inside the airbox, nothing, put the lid back on and took it off again incase I was hallucinating, still nothing. So I am in the market for an air filter anyway. It runs perfectly, surprisingly, as instead of playing with jets when the exhaust was emptied of everything one of the 3,000,000 previous owners must have taken the air filter out to compensate for the lack of exhaust stuff.
I am hoping to use it on green lanes, so thats why I thought of the mt80 exhaust as 80cc is closer to 100cc than the standard 50cc pipe and still high up.
50cc.nl has pretty much everything I will need, would a clamp on airfilter be usable in muddy conditions? I was thinking of getting like a high performance foam one. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| cb1rocket |
 cb1rocket World Chat Champion
| dangerousdave |
| stevo as b4 |
| Fladdem |
 Posted: 11:51 - 27 Aug 2012 Post subject: |
Right then, cheers for that information.
Just to clarify, I wasn't the one who removed the air filter, when i discovered it was missing I stopped riding the bike but I fear the damage is already done, and it partly explains why it ran horribly.
I will have a look at the inner diameters of the exhaust port and exhaust and see what it is like.
On my MT50, the exhaust is rusted to the studs and the studs are rusted to the cylinder, I tried penetrating oil and i went to undo it, it is an allen key style stud, I put the allen key in and turned and now its a circle. How do I get the exhaust off now? ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| moonzoomer |
 moonzoomer World Chat Champion
| Fladdem |
 Posted: 13:02 - 23 Sep 2012 Post subject: |
hi, does anyone know what the jetting is for a honda h100a? I have got the carb but none of the jets have come with it and I don't know how I would go about getting the right stuff.
Any help would be fantastic. ____________________ Current:1991 Honda MT50 (Soon to be a H100/MTX/MT5 hybrid), 1976 Honda Cub C70, 2005 Honda Varadero 125, 1993 Yamaha TTR250 Open Enduro , 2010 Road Legal Stomp YX140, 1994 Honda CRM 250 MK III, 1999 Cagiva Mito 125, 1992 Honda CB400 Super Four, Stomp T4 230, 1984 Honda H100s, 2009 Sym XS125K
| bladerunner |
 bladerunner World Chat Champion
 Posted: 22:49 - 24 Sep 2012 Post subject: |
On the plus side the mt50 frame is loads stronger than the original H100 item and it is worth trying an 80 exhaust as tbh the std h100 one is crap with zero expansion chamber effect....maybe even Bodge on a dt100 or km/ke100 to try if you can find them. Having bolted on a ar80 micron to a yb100 motor years ago I didn't expect it to do anything due to very poor transfer ports..4 speed box and very low tune porting as std but with a bit of header length shortening....it fair flew to 70 and for what it was quite shockingly quick! Would be worth doing the same with the h100 engine it was after all aimed at the same market back in the day, half the fun is in experimenting with these things  ____________________ Current bikes...cbr929, KDX200's, Rd125lc mk2, RGV250's |
The last post was made 13 years, 355 days ago. Instead of replying here, would creating a new thread be more useful? |
