Dt 125 playing up in the rain
rhys1005
PostPosted: 18:45 - 25 Sep 2012    Post subject: Dt 125 playing up in the rain Reply with quote
Hi, had my dt for about 3/4 months now and i've noticed that whenever it rains heavily my bike will lose a lot of it's power and splutter in the low/mid range revs it can be dangerous tbh because i will be WOT only going about 20mph because of it playing up then all of a sudden the spluttering would stop for a few seconds and id get a burst of power.
Any idea to what could cause this?
Thanks.
Matt-
PostPosted: 18:51 - 25 Sep 2012    Post subject: Reply with quote
Sounds like your getting water into the cylinder causing spluttering.
Check the air filter, clean it...
Good luck
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Matt-
PostPosted: 18:53 - 25 Sep 2012    Post subject: Reply with quote
Even water on the coil can effect the running,
When raining and it's running poorly, running at 20mph , hit killseiych take the plug out and see if its overly wet...
Matt
rhys1005
PostPosted: 19:00 - 25 Sep 2012    Post subject: Reply with quote
Ok thanks matt, does the air filter need to be oiled? I was thinking it could be dry, would a dry airfilter have anything to do with this?
Il check eveything you suggested now Smile
Matt-
PostPosted: 19:15 - 25 Sep 2012    Post subject: Reply with quote
if i am correct it's a light gear oil however, it would not make a difference the engine would still run fine.
let us know how you get on, also make sure their is no crack's or anything in inlet manifold for water to get in Thumbs Up
Good Luck
Matt
Casper
PostPosted: 19:34 - 25 Sep 2012    Post subject: Reply with quote
I had a DT new years ago. Yamaha had put a metal spark plug cap on. When in rain it would cut out and die. New cap sorted the problem.
Matt-
PostPosted: 20:07 - 25 Sep 2012    Post subject: Reply with quote
yeah that would sound right,
Water going into the cap causing disruption to the ignition.
Something like this would also work because it has rubber sock that protects the HT lead entry from water.
https://www.ebay.co.uk/itm/WATERPROOF-SPARK-PLUG-CAP-for-YAMAHA-DT125-X-04-07-/160474652294?pt=UK_Motorcycle_Parts&hash=item255d08de86
Good Luck Mr. Green
Matt
carvell
Scuttler
PostPosted: 20:30 - 25 Sep 2012    Post subject: Reply with quote
I wouldn't have thought so.
The whole thing sounds like a simple HT lead/cap problem.
Check the HT leads and cap. Use a spray bottle of water at night and spray it on the leads, see if you see arcing.
Yamaha TDM 850
woll
PostPosted: 21:04 - 25 Sep 2012    Post subject: Reply with quote
I had this problem with my dt. New cap for the spark plug, cut the ht lead back a few mm on both ends. screw it back in. spray with holts damp start
The last post was made 13 years, 196 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 59.71 Kb
