Shim kit owners... 7.48mm Possible help ASAP?
MaybeGuy
PostPosted: 19:57 - 25 Sep 2012    Post subject: Shim kit owners... 7.48mm Possible help ASAP? Reply with quote
I'm currently shimming my CRF 250, but there's a catch...
My inlets need doing, I need a 1.70 for one side, but the other can't get a gauge in. I've estimated it to need a 1.60 shim, but would also require a 1.55 and 1.50 just in case.
Here's the q...
Do any of you trusting fellows have these shims, and are willing to post them to me ASAP as I'm racing this saturday, but I get paid on friday... = not enough time to sort as we're camping down there friday nght. This month was literally that tight...
Any generous fellows will be rewarded with cost + interest, and/or a bike part that greatly exceeds the value of 4 shims, paid on the friday via paypal, or the item will be posted then.
PostPosted: 22:09 - 25 Sep 2012    Post subject: Re: Shim kit owners... 7.48mm Possible help ASAP? Reply with quote
Here's the q...
7.48mm diameter, at those thicknesses?
I don't have them but I could make some from silver steel I guess. Have to take a guess at the hardening though, and if it breaks up during the race it'll be your fault not mine Very Happy
But listen - you can adjust your shims with emery, if you really have to. Just drill a 7.5mm hole in something flat, about the same thickness and put the shim in the hole, weight on top and rub it on emery until the flat support is the same thickness as the shim then keep rubbing until the shim is thinner.
OR
If you have access to a lathe and surface grinder, turn a piece of steel with a shallow 7.5mm recess in it and place the shim in the recess, stick it on the mag chuck & grind it to suit. Can also use this trick for emery.
MaybeGuy
PostPosted: 22:30 - 25 Sep 2012    Post subject: Reply with quote
Cheers for the offer, but I'd prefer to go down the actual component route. I'm not after a temporary fix, even though I'm sure it wouldn't break up.
I have access to lathes, mills, surface grinders and the like, but anything like that would compromise the hardening.
Klause
PostPosted: 00:22 - 26 Sep 2012    Post subject: Reply with quote
If you only take a little bit off the hardened surface it shouldn't matter. In emergency I have used flat sharpening blocks and diamond stones. Some have been in engines for thousands of miles. Removing material then keep checking with the hardness tester?
I have a packet full of 7.5/7.48 shims somewhere, I have moved garage and can't find them. Sorry.
Current bikes: 1960 Triumph 5ta x2, TTR600RE, KTM200EXC, Cagiva Elephant 900ie.
mab
PostPosted: 11:55 - 26 Sep 2012    Post subject: Reply with quote
Sent me a pm with your address. I'll send you them tomorrow
The last post was made 13 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 46.81 Kb
