| Ollossm |
 Ollossm Nova Slayer
 Posted: 21:55 - 25 Sep 2012 Post subject: how accurate is GPS in a phone |
I appreciate to a degree all GPS could be deemed as accurate to a degree but it is that degree I'm wondering about.
I know the speedo on a 125 can only be deemed as accurate up to X speed and then is best used as an indicated figure rather than an actual figure.
As I've been wondering how accurate (or not) the speedo is on the CBF I took myself out today with the phone on the tank and GPS turned on.
0-25 speedo and GPS tied in
at 30mph on speedo the GPS was giving between 26 & 29
at 35 on speedo GPS again appeared top tie in
At 40 on speedo GPS was reporting 35/36.
With the 40 on speedo and 35 on GPS I thought I'd increase speed by 5mph - which in theory would have brought speedo to 45 and GPS to 40....when the bike hit 45 on the clock the GPS also tied in at 45
At these speeds it probably doesn't matter as it is being under-reported on the clock, but it is puzzling.
At one point going through a village the clock was just on 30 and the GPS was on 28 but the 30mph speed reduction warning sign flashed on.
Are the GPS units in phone less accurate than a GPS unit? ____________________ _______________________________________________________________
current bike: 2012 Honda CBF 125
past bikes: 2004 Suzuki VanVan 125 - 1988 MZ/Simson 50cc |
| bikertomm |
 bikertomm World Chat Champion
 Posted: 21:57 - 25 Sep 2012 Post subject: |
I think they probably run off the same if not similar than what tomtom / garmin ect use..
I'm sure someone will be along soon to tell you for sure
But yes, generally your speedo will over-read. ____________________ 07' Honda Hornet now full powaah! My guide on performing an oil change! |
| janner_10 |
 janner_10 World Chat Champion
| Derivative |
 Derivative World Chat Champion
| Kickstart |
 Kickstart The Oracle
| Ollossm |
 Ollossm Nova Slayer
| Derivative |
| Ollossm |
 Ollossm Nova Slayer
| Frost |
 Frost World Chat Champion
| ocatoro |
 ocatoro World Chat Champion
| MarJay |
 MarJay But it's British!
| daemonoid |
 daemonoid World Chat Champion
 Posted: 10:13 - 26 Sep 2012 Post subject: |
| Frost wrote: | I've seen a huge difference between phones. I have a galaxy s2and the gps is pretty darn good for a single channel. A friend has an HTC sensation with isn't so good, but still not bad. Another friend has a galaxy Ace tat's all over the place! The position read will tell you you're 20 meters from where you actually are!
So long as the phone is reading lower than the speedo i'd say that was being acurate. Position skip on the phone would cause an over estimate of speed, going round corners will cause an underestimate as the software plays join the dots with the position fixes |
The position has nothing to do with how the speed is calculated.
The position is calculated using the relative positions of a number of satellites - something that is prone to errors due to many factors - incorrect time, weather, obstructions generally anything. Most nav chips require at least 4 satellite locks to get an accurate position and the more satellites the more accurate the position. They also use other tricks to zero in on you - like assuming you're on a road and compensating for position based on turns etc.
The speed on the other hand can be calculated using one satellite and is purely down to the Doppler effect. As you move through the satellite's signal it is distorted from your point of view, this distortion is measured to give an extremely accurate speed measurement. To hear the Doppler effect yourself, just go stand beside a fast road - the vehicles tone changes as they approach and then again after they've passed. It's what gives racing cars that neeeeeyooowww sound.
Oh, and most phones use the same groups of GPS chips, there is little between them, but the processor does have an impact on the number of satellites that can be tracked. Most of the difference you see between one phone and the next is likely to be due to the time and distance since the GPS was last used, and that's due to a little trick they do with keeping the satellites 'live' rather than locking onto them like days of old. ____________________ current: ducati monster 750
@thomasgarrard | www.straitjkt.com | www.racingseven.com |
| tahrey |
 tahrey World Chat Champion
 Posted: 11:18 - 26 Sep 2012 Post subject: |
Their -precision- can be pretty variable, however the -accuracy- is generally quite good.
IE it may only locate you with a certainty of +/- 5 metres (which would be enough to cause notable errors at low speed), which may include a degree of drift, but if you're moving, it's less a random error and more that you're a sort of fuzzy dot. If you plot how far the dot as a whole moves, even though you may not actually be central within it, the speed and direction is fairly close to reality.
Of course there are spikes and other artefacts, and the smaller and cheaper the receiver, the worse they get. My crappy £40 satnav locks on much faster and more reliably than my phone in identical conditions, locates me in a smaller area of certainty, and displays a much steadier speed when the signal is suboptimal.
But you can work around that if your idea is to see how accurate your speedo is, and work out what, for example, it shows you for a real-world speed of 32, 43, 54mph (so you can keep within the gatso trigger limits even if otherwise pushing on a bit). Just set it up and drive at as steady a speed as you can over a reasonably flat and straight course. Either take the average measured over that section, or go with what speed it displayed most often and for longest. Rinse and repeat for the other speeds. Memorise.
And if you have one of those light-up signs that tells you how fast you're going nearby, make good use of it. They operate off the same radar or laser detector hardware as a speed camera, so can be quite trustworthy, so long as they're aimed up properly and there isn't much other traffic about. I've even had them pick me up with pretty good accuracy whilst I was on my pushbike. Even though most of them top out at 45mph, it's enough to help you calibrate your speedo for 20/30/40 limits, and acts as a "second opinion" to check your GPS against (which you can then use for 50/60/70).
According to two different phones I've recorded tracks on, thrashing a CG down a slight hill, with a following wind and a bit of slipstream, an indicated 80 is actually "only" 75 (meaning the estimated just-under-80 Vmax thanks to the bizarrely slightly-too-low(?) 14/45 sprockets is almost spot on; it seems to hit the limiter at an indicated 84 on a serious downgrade). There was a lot of noise on those tracks, when they were downloaded and plonked into a GPS telemetry graphing / mapping thing, including some crazy things like alternating between 0 and 200mph whilst the signal faded in and out on a bit of the M5 with a lot of bridges, but the data was still clear enough to shove a regular trendline (and a heavily averaged second one) through and pick out the actual story. |
| daemonoid |
 Posted: 13:03 - 26 Sep 2012 Post subject: |
| tahrey wrote: | Their -precision- can be pretty variable, however the -accuracy- is generally quite good.
<snip> |
Sorry, but this is mostly tosh...
See my post above, and search for 'Doppler GPS' if you want to understand it more thoroughly than my one paragraph.
A GPS should be accurate to ~0.5mph which is far better than the accuracy of a speedo which will be incorrect from the factory and then still be off because of any changes in tyre pressure etc.
The light up speed signs are known to overestimate speed so don't go with those either.
The two biggest problems with GPSs as a speedo are the fact that most of them are calibrated to give a 2d speed so your speed up and down hills will not be accurately reflected and that they tell you the average speed you have been going since the last update rather than the current instantaneous speed. ____________________ current: ducati monster 750
| Timmeh |
 Timmeh World Chat Champion
| tahrey |
| Timmeh |
 Posted: 11:14 - 27 Sep 2012 Post subject: |
Somewhat OT, but I wouldn't worry about being sliced and diced by some big laser beam whilst riding, although some think tank has suggested equipping gatsos with missile launchers.
In any case, it would be using optical guidance rather than GPS.
Guided bombs that do use GPS have massive warheads to counteract any inaccuracy in their navigation, and even then they'd be using the encrypted P-channel signals which can get your fix down to 10cm, even on a bad day.
've used military GPS whilst out playing with the TA, and that was reporting an error of some 0.4m whilst trekking though woodland, so it just goes to show how amazing it can be when using the right kit.
5m accuracy using civvy receivers is nothing to be sniffed at, in the early days of GPS the US government used to wobble the signal using something called Selective Availability (SA) which used to knock the accuracy down 50-250m in most places. In some countries like Libya, Iran and other terrorist-harbouring countries GPS was practically useless, with errors as high as 1Km.
As use of marine and air nav-based GPS became more widespread, people like Garmin invested huge sums of money into the Differential add-on system. Basically a radio transmitter with an exact known position would get a 3D fix from the satellites using the wobbled signal. It would then work out what the difference was and then transmit the information over radio. A GPS with a differential receiver could then use the extra information to undo SA and give a wobble-free fix, usually down to 10m or less.
SA was disabled on 1st January 2000 after they decided that it wasn't worth the extra hassle. The new Block III satellites currently being put into service have no SA capability at all. Instead, however, they can just turn the civilian signals on or off, at any time, for any satellite. This means that they could, in theory, deny GPS reception over any area of the planet of their choosing, which is far more effective than SA as it knocks out DGPS as well.
 ____________________ GSXR400 x2 | '94 RVF400 | '93 TZR125 4DL (again)
20:48:18 Temeluchus: comp you hunk of smouldering homos3x you |
| Jim Mc |
 Jim Mc Nearly there...
| JP7 |
 JP7 World Chat Champion
| Dave70 |
 Dave70 World Chat Champion
| Ollossm |
 Ollossm Nova Slayer
| tahrey |
 Posted: 03:18 - 28 Sep 2012 Post subject: |
aaaaah.... I see...
It's entirely possible I was being mushroomed despite the seeming authority of my mate, like  |
| angryjonny |
 angryjonny World Chat Champion
| Kickstart |
| BG5067 |
 BG5067 Spanner Monkey
The last post was made 13 years, 142 days ago. Instead of replying here, would creating a new thread be more useful? |
