Traffic Light Sensor
TheSmiler
PostPosted: 06:36 - 27 Sep 2012    Post subject: Traffic Light Sensor Reply with quote
Just wondering is there any way to set them off on the bike to change the lights, I've been in a few occasions where I've had to wait for another car or move the bike on foot just to carry on my journey Rolling Eyes
Really annoying so would be nice to hear if there is a solution out there Question
Fifteen15
PostPosted: 06:40 - 27 Sep 2012    Post subject: Reply with quote
Could use them laser things that emergency service vehicle have. In theory they sound awesome.
"Pain is weakness leaving the body, and blood makes the grass grow faster...but I'll wear my gear anyway"
Shinigami
PostPosted: 06:49 - 27 Sep 2012    Post subject: Reply with quote
stand up and wave your arms like a nob.
then sit back down and wait for a car to turn up
soforene This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Jersum
PostPosted: 07:03 - 27 Sep 2012    Post subject: Reply with quote
You could try riding over corner of the sensor, apparently it's able to pick up vehicles best from that point.
Full Licence acquired December 2011.
1st bike Honda CG125 '04 in silver, 2nd Suzuki Bandit 600S '96 Very Happy
JoeDougieDoug...
PostPosted: 08:14 - 27 Sep 2012    Post subject: Reply with quote
Traffic lights with the sensor on top of the lights can be triggered in the dark when you flash them with full beam. There is a set near me... I get a few meters from it, flash them, and they change which is nice. Smile Try it sometime.
Marmalade
PostPosted: 08:24 - 27 Sep 2012    Post subject: Reply with quote
I try to stop on top of the sensor to give me best chance of not getting bored and going on the red.
I don't get issues on the pan as being a huge lump of metal it gets picked up by the sensors easily,
weasley
PostPosted: 08:37 - 27 Sep 2012    Post subject: Reply with quote
Myth. Assuming the lights use an IR detector (rather than induction loop or simple timer) then 55W of headlight bulb isn't going to make a blind bit of difference when you are sat astride a 15/20/50/100 kW engine, which is a very effective waste heat generator. The effect you describe is called coincidence.
JoeDougieDoug...
PostPosted: 08:39 - 27 Sep 2012    Post subject: Reply with quote
No, it not coincidence, every single evening on my way home from work, I flash these lights and it changes... except if there is a car the other side. You can be waiting at the lights without them changing, as soon as you flash, they change. And FYI, my headlight is 35w.
Kierran
PostPosted: 10:06 - 27 Sep 2012    Post subject: Reply with quote
There are at least 3 different types of sensors that i know of. One is a camera which you can flash and pics up headlights. You can find these on some temp sets as well that are not timer only. Flashig from about 500m back will usually stimulate a change.
The next are new ones fitted round here to replace the light sensitive ones and consist of grey cones on top of both lights. Not sure if they are radar or ir but on roundabouts they dont pick the bick up at all due to smaller cross section/ angle of approach. Theres a red light on my way home from work i need to run every night as it crosses the primary route the lights are set for.
The last is a ground sensor which ive found i need to rock the bike over as one pass occasionally wont trigger it.
And finally sone lights are solely on a timer and continuosly cycle which on a 4 way junction with filters takes ages.
Im not driving too fast, Im flying too low!
Current Bike - GSXR 750 K5
Current Car - BMW 318i
PostPosted: 10:37 - 27 Sep 2012    Post subject: Reply with quote
If this happens to you on a regular route, then have a moan to the council's road department about it. If not you, then who?
Also, MTFU and treat dumb machines and signs as advisory, not as a replacement for human judgement.
If you're going to wait 5 minutes then ride through a red, why not just ride straight through it? It's the same "offence" either way, it's absolute, and there's no statutory defence of "couldn't be bothered waiting". It's only a case of how likely you are to be seen and prosecuted, which is "not very", either way.
Don't take it from me, I regularly see the local Plod drive through reds when they can't be arsed waiting.
The Artist
PostPosted: 10:41 - 27 Sep 2012    Post subject: Reply with quote
The ones on top of the lights that look like cameras are just IR sensors so flashing your light will have little effect. Just roll your bike back and forth with your feet.
Same goes for the sensors under the tarmac. Just roll about over them. It is the mass of your bike that sets them off, not waving your arms around.
Atomic Punk
PostPosted: 12:35 - 27 Sep 2012    Post subject: Reply with quote
I tend to do this at temporary traffic lights. If I can see the way is clear I'm not waiting untill a light changes
I may have lost my way but I'm way ahead of schedule.
Nick 50
PostPosted: 12:47 - 27 Sep 2012    Post subject: Reply with quote
There is one not too far from me that won't change.
My procedure generally goes like this:
Pull Up
Wait a bit
No change
Is it safe to go?
Yep, I go.
Obviously can't do this on a set of lights which is monitored though.
yaigi
PostPosted: 13:55 - 27 Sep 2012    Post subject: Reply with quote
This might be a really dumb question but how can you tell where the sensors are? Not come across this problem yet myself Confused
johnsmith222
PostPosted: 14:27 - 27 Sep 2012    Post subject: Reply with quote
It looks like a rectangular tar line cut into the ground normally. Don't know about the IR sensors exactly, but it's the box above the traffic light.,
https://www.transitboston.com/wp-content/uploads/2009/08/Red-Light-Sensor-in-Newton-300x225.jpg
I suspect thats an american picture, but it is the same sort of thing. If there's a regular looking shape cut into the ground and possibly tarred over then it's a traffic light sensor.
The last post was made 13 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 96.6 Kb
