Builder/chimney advice
ash t
PostPosted: 20:07 - 27 Sep 2012    Post subject: Builder/chimney advice Reply with quote
Hi all...having somebody in this weekend to reinstate our fireplace. Dom has been to pull the gas fire out and set off a smoke bomb in the chimney. It was going dark but it appeared that smoke was coming from both chimney pots....does this mean it needs lining?? Need an idea how much lining will cost including fitting...anybody on here have any ideas??
When You're Starting To Choke, Take Some Pills With Your Coke, Its Hyserical
Raffles
PostPosted: 21:06 - 27 Sep 2012    Post subject: Reply with quote
It may just be that the chimney's mid-feathers have failed. If you don't mind heights then you may get away with just the cost of a bucket of mortar.
Islander
PostPosted: 21:11 - 27 Sep 2012    Post subject: Reply with quote
It means that there's a leak between the flues which casts doubt on the integrity of the masonry. It'll need lining.
It's not a massive job nor should it be particularly expensive. There are a couple of ways of doing it, one involves removing the pot, dropping the liner, fitting a top clamp and plate and reinstating the pot. The other is to use a suspending cowl which involves dropping the liner through the pot and fitting a special cowl that clamps the liner and is in turn clamped to the top of the pot. The second is obviously less work than the first. The bottom will either need a register plate fitted (the bottom of the liner clamps to this) if you're fitting a stove, or a gather if it's going to be an open fire.
If you're in England or Wales, it has to be reported to Building Control and has to comply with building regs or has to be fitted by a HETAS registered installer and an installation plate fitted in plain sight - it'll affect household insurance if it isn't done this way. In Scotland you can crack on and do it yourself if you're confident of your skills (I did when we installed a multifuel stove) or get a builder to do it. Self install isn't hard but wrestling several metres of stainless steel liner at height isn't a trivial thing.
Whichever path you choose, buy and fit an CO alarm. Thumbs Up
Edited to add:
There are three types of multifuel liner available made of three stainless steel grades. 316/316 has the cheapest type of steel on both sections (inner and outer) and typically has a 10 year guarantee. 316/904 has the cheaper steel on the outer section and a higher quality (acid resistant) on the inner and is typically guaranteed for 15-20 years. 904/904 uses the higher grade acid resistant steel on the inner and the outer and is typically guaranteed for 25-30 years. The price per metre reflects the quality.
ash t
Cool. I've asked a mate if he can come have a look at it....
Ariel Badger
PostPosted: 21:19 - 27 Sep 2012    Post subject: Reply with quote
In Birmingham we pronounce chimney "chimberly".
ash t
PostPosted: 21:24 - 27 Sep 2012    Post subject: Reply with quote
Now to find a reputable hetas installer!!
Islander
PostPosted: 21:25 - 27 Sep 2012    Post subject: Reply with quote
In Scotland we pronounce chimney 'lum' Laughing
Lang may yer lum reek Thumbs Up
The last post was made 13 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 53.62 Kb
