| loply |
 loply World Chat Champion
 Posted: 00:20 - 26 Oct 2004 Post subject: |
I would have thought it should have a fuel tap, but I am not sure where. Normally where the fuel line leaves the tank (and it definatley has a fuel line leaving the tank whatever, it comes off on the left side on an XTZ which has the same engine I think). Look harder, follow the fuel line up from the T-piece where it goes into the carbs, use a torch not a match
I am a fan of dipping my finger in mystery bike haemorrhages and tasting them. Petrol will make your lips sting and is slightly bitter, oil is tasteless. Be warned that I got caught out badly one time doing this with battery acid which is a distinctly unplesant tasting chemical (a lot worse than petrol).
On consideration, it is probably best not to do this
EDIT: Having just looked at some pictures of your bike, I can't see one either. It SHOULDN'T be able to leak fuel from out of the tap even if the fuel line has become detached as a vaccuum fuel tap is undoubtedly fitted.
You mentioned it being in the same room as a gas boiler. So it has just come from the cold into a warm room. Probably just the petrol vapour in the tank expanding and coming out of the breather. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| tgabber |
 tgabber Crazy Courier
 Posted: 00:25 - 26 Oct 2004 Post subject: Re: Leaking Petrol? New bike |
| mchaggis |
 mchaggis World Chat Champion
 Posted: 00:31 - 26 Oct 2004 Post subject: |
Unsafe? Um, petrol vapour is what goes bang inside engines. Now imagine your garage as the cylinder, and think bang!
It's very unsafe to have clouds of petrol vapour around, you might be wanting to open the windows and doors, and see if you can get a breeze through the garage to disperse it a bit and blow it out. (So long as the wind isn't just going to blow it further into the house.)
Avoiding lightswitches and things which make sparks is probably a good idea as well. I should think the risks are somewhat similar to a gas leak, except I doubt Transco would be impressed if you called them.  ____________________ I must not be a troll...
Mmmm, Guinness
| loply |
| Frost |
 Frost World Chat Champion
| JonB |
 JonB Afraid of Mileage
| PsychoHippy |
 PsychoHippy Jammy Git
| stryker |
 stryker Brolly Dolly
 Posted: 08:33 - 26 Oct 2004 Post subject: |
The petrol won't ignite until you get just the right balance of air vs petrol in the garage. I mean look in the workshop forum for all those threads about getting the mix right, its harder than you think.
Just open a window.
BTW, does your bike have a switch marked "RES" on the right handle bar? I ask as it has a warning light so may have an electronic res function. ____________________ Now what? |
 Posted: 12:54 - 26 Oct 2004 Post subject: |
It might not have an easily reached fuel tap. Some bikes just have a connector on the tank that you do up / undo to turn the petrol on / off (and sometimes these leak if you undo them all the way.
Normally they do have an external switch though, even if it is bolted to the frame well away from the tank. Lift the tank up again and follow the fuel pipe.
| loply |
The last post was made 22 years, 27 days ago. Instead of replying here, would creating a new thread be more useful? |
