| Benman |
 Benman Renault 5 Driver
| Matt- |
 Matt- World Chat Champion
 Posted: 16:39 - 29 Sep 2012 Post subject: |
Brake's need bleeding - their is air in the braking system, simple solution is gravity bleed - crack the bleed nipple on your front caliper, while putting tissue under the nipple so brake fluid does not go everywhere.
while fluid is coming out keep topping up the brake res on your handle bars, also check you have got the brake hose on correct and not kinked, once you see fluid coming out you should see air bubbles coming out, keep topping it up until you see just fluid coming out.
If this doesn't work you will have to manually bleed it up
Good Luck.
Matt ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| Benman |
| Matt- |
 Posted: 17:07 - 29 Sep 2012 Post subject: |
If you ave moved the caliper / caliper pistons air may have entered the system or you may have a knackered seal on the caliper.
Other thing i would also try is cleaning your disc down with water, reason being if anything other than water hit's it, brakes become useless
Good Luck
| Benman |
The last post was made 13 years, 274 days ago. Instead of replying here, would creating a new thread be more useful? |
