Why is this happening!!!!
Priliars125
PostPosted: 15:57 - 01 Oct 2012    Post subject: Why is this happening!!!! Reply with quote
Ok so I'm getting this weird thing happen I changed my throttle and ever since when I pull off (only on pull off) the bike revs the bollocks off the bike like its sticking but the throttles on correct if I rev in idle it's fine all day hard,fast however but put in 1st to pull off and it goes crazy until I pick up a little speed what is this I'm thinking could somebody show me how there cable is routed please (even though it happens when pulling off straight so I'm stumped didnt do this before new throttle and cable lol any helpbe great pics even better Haynes manual bag of shite tbh
Thanks
Alpha-9
PostPosted: 16:05 - 01 Oct 2012    Post subject: Reply with quote
Bike make model and year.
Changed the throttle? Whole cable or just the grips? Or just adjusted the play?
did you lube it up?
Fzr-600 1999
Priliars125
PostPosted: 17:13 - 01 Oct 2012    Post subject: Reply with quote
Hi thanks for reply 2003 extreme ( although I know it's not an extreme but it's on the v5 as that lol) I changed the whole throttle and twist as the cable snapped and the twist grip had broken I never lubed up was aware was needed as never done that before and been ok :s its dusted all the way ( as in I can't get anymore extra wire this it another thing that makes me think it's routed incorrect?? It's just strange only on pull off and no other time
P.s it's ok in the carb as The slide is opening and closing freely
Thanks
Walloper
PostPosted: 18:36 - 01 Oct 2012    Post subject: Reply with quote
Make sure the outer cable is not snagging on the frame somewhere. When you 'pull away' it's posible that is what's giving it the juice.
There may be a little steering input as you correct the direction as you move off.
Priliars125
PostPosted: 18:56 - 01 Oct 2012    Post subject: Reply with quote
Hi it's not snagged its free its either routed crud or I'm going to try lube as cable may be sticking on the throttle side if that doesn't work I give up lol
Regards
Robby
Dirty Old Man
PostPosted: 19:01 - 01 Oct 2012    Post subject: Reply with quote
I'm assuming this is some kind of small two stroke.
First off, did you have to take the slide out of the throttle to change the cable? If so, you may have put it in back to front.
You may have also neglected the spring above the slide.
If you remove and refitted the throttle grip, it should be totally clean underneath, no oil or grease. That just picks up crud and goes sticky in no time.
If the cable is routed correctly and you're rolling it shut at the bar, then the problem is going to be at the carb end.
Priliars125
PostPosted: 19:26 - 01 Oct 2012    Post subject: Reply with quote
The slide cannot be put back to front mate although I did put a little grease under the throttle il clean this off lube the cable and rerout the cable if that don't work then il have to grim and bare it lol
Thanks
P.s and yeah it's a little rs125 Very Happy
Matt-
PostPosted: 19:33 - 01 Oct 2012    Post subject: Reply with quote
Of course look at your speedo cable & throttle.
Make sure cable is correctly routed to your throttle as it says in a Haynes manual, make sure it's in the top of the carburettor.
The issue I had recently is, the float height was incorrectly adjusted so it was allowing more fuel in on start up, even sometimes at the lights the bike would rev higher. Plus if I left the fuel on / reserve, off was the only way it would stop leaking out the overflow and air filter side of te carb.
Maybe worth taking into account.
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
Priliars125
PostPosted: 19:45 - 01 Oct 2012    Post subject: Reply with quote
100% not a carb issue I'm going to try what suggested above I'm sure it's 1 of these small issues
Thanks for replys
Matt-
PostPosted: 20:08 - 01 Oct 2012    Post subject: Reply with quote
100% ? That's high given its a RS Laughing
Check where it's routed, as I read before recently putting paraffin in the cable clean it nicely, and oil it after cab work wonders.
Matt
Timmeh
PostPosted: 21:58 - 02 Oct 2012    Post subject: Reply with quote
Don't forget that the throttle cable splits in two as it also goes to the oil pump.
The stickiness is usually found in the junction box as it gets filled up with shit.
The last post was made 13 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.94 - MySQL Queries: 13 - Page Size: 67.17 Kb
