Wurth chain lube
Manuel
PostPosted: 20:49 - 01 Oct 2012    Post subject: Wurth chain lube Reply with quote
I have been using this for the past year but I am not sure if I am using it properly. I find after just a 100 miles that the chain links look shiny and not lubed. The O rings look fine but I am concerned about wear on the sprockets and chain. Am I applying enough?
Cucking Funt
PostPosted: 21:10 - 01 Oct 2012    Post subject: Re: Wurth chain lube Reply with quote
Wurth dry lube?
Ichy
PostPosted: 21:25 - 01 Oct 2012    Post subject: Reply with quote
If it is the dry stuff then that is how it is supposed to look. I like it a lot.
Richy CB1000
PostPosted: 21:41 - 01 Oct 2012    Post subject: Reply with quote
I've switched to this over the last say 2K miles. It hasn't needed a chain adjustment, stays quiet and seems fine.
I think I've sprayed it four times over that distance.
I know what you mean though it just looks like there's nothing on there.
If you touch a side plate after a run mine does feel tacky and it isn't shiny, more a mat dull colour on the side plates.
I do follow the instructions, shake for 3 minutes first then apply over 2 directions. I also leave it overnight before next using the bike. It appears to be doing the job only time will tell but at about £125 for a chain kit it could be an expensive mistake!
Raffles
PostPosted: 21:56 - 01 Oct 2012    Post subject: Reply with quote
I use Wurth Dry Lube. It is a low-build wax lubricant that doesn't attract dust or other shit/debris and as such it prolongs chain and sprocket life. Because it is ''dry'' it has the advantage of not dipping all over the floor of the garage/shed/kitchen. It penetrates and adheres to the chain best if you apply it after a run out whilst the chain is relatively warm. I give it a big Thumbs Up
janner_10
PostPosted: 23:10 - 01 Oct 2012    Post subject: Reply with quote
I started out using dry lube, but wasn't overly impressed, seemed to need applying quite often.
I got hold of a free can of Castrol chain wax and its pretty good. Makes the chain quite greasy though.
The last post was made 13 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.26 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 47.57 Kb
