Front fork air pressure
stuartadair
PostPosted: 17:39 - 29 Sep 2012    Post subject: Front fork air pressure Reply with quote
This FZ400 I've just bought has got air valves on the top of each fork. It looks like you connect an air line to add pressure to the forks.
I've never seen that before - What sort of pressure should I add ?
Stu
DMCpro
PostPosted: 17:42 - 29 Sep 2012    Post subject: Reply with quote
Not exactly, they are filled with gas can't remember what the gas I'd called though! Someone will
Honda CB-1, TS125X
VW Golf Estate
stuartadair
PostPosted: 17:45 - 29 Sep 2012    Post subject: Reply with quote
Oh I'm not liking the sound of that. The fork seals are gone so I've got to strip them down and replace. Hope its not going to be complicated with having to get them filled with a gas Sad
jjdugen
PostPosted: 18:06 - 29 Sep 2012    Post subject: Reply with quote
Another 80's fad along with 16'' front wheels and hydraulic anti dive.
The pressure in them was circa 5 psi, you could only use a cyclepump on them, an air line would overpressure and blow the seals.
Its just air, so no special gas needed, in fact, ignore them entirely. You might put a few cc's more fork oil in, this has much the same effect.
DMCpro
PostPosted: 18:10 - 29 Sep 2012    Post subject: Reply with quote
There are some oil free forks filled with pure gas but you are probably right on this one
Honda CB-1, TS125X
VW Golf Estate
PostPosted: 19:04 - 29 Sep 2012    Post subject: Reply with quote
Varies depending on the model, but generally VERY little air pressure or none.
DMC, there were the Fournales air shocks but not sure about forks
stuartadair
PostPosted: 19:13 - 29 Sep 2012    Post subject: Reply with quote
Thanks for the replies
PostPosted: 08:10 - 30 Sep 2012    Post subject: Reply with quote
Not much air - last ones I had were 7psi. Don't try using a40 air line, use a foot pump.
sickpup
Old Timer
PostPosted: 08:38 - 30 Sep 2012    Post subject: Reply with quote
That'll be air then as opposed to rear shocks that are generally filled with Nitrogen.
caferacer
PostPosted: 19:59 - 01 Oct 2012    Post subject: Reply with quote
All cool bikes have air valves on the top of the forks - chicks dig them.
My 80s Honda CB125RS has them lol
Fill it with the standard oil cc then the idea is you can easily adjust for ride comfort - low pressure for light loads, soft ride and smooth roads and high pressure for heavy loads and rough roads.
Between 0 and 7psi is about right.
PostPosted: 12:07 - 02 Oct 2012    Post subject: Reply with quote
I always used to set them to zero with the forks totally unloaded (front wheel off the ground, stick key in valve).
This probably equates to somewhere in single figures of psi with them sagged.
It doesn't seem to make an iota of difference to the behaviour of the suspension anyway.
The last post was made 13 years, 270 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.41 - MySQL Queries: 13 - Page Size: 72.26 Kb
