Sintered and Non Sintered pads - how do you know?
map
Mr Calendar
PostPosted: 23:36 - 01 Oct 2012    Post subject: Sintered and Non Sintered pads - how do you know? Reply with quote
After Kickstart's comment in this thread on sintered and non-sintered MOT failure depth my lad wondered how you tell the difference between the two types...
...and I had to admit I didn't know either Shocked
So quick question, how do you tell what's fitted to a bike, bearing in mind front and back may be different?
Confused
Matt-
PostPosted: 08:58 - 02 Oct 2012    Post subject: Reply with quote
A quick google search has brang up this pretty handy informative link:
https://www.ebcbrakes.com/motorcycle_brake/sintered_brake_pads/sintering.shtml
Hope this helps Smile
Matt
RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010
PostPosted: 09:38 - 02 Oct 2012    Post subject: Reply with quote
Between organic and sintered? This obviously isn't 100% guaranteed but in general organic are darker and of a more uniform colour and sintered are lighter with 'bits' in them. How they look once they have been in use and discoloured with heat though is competely different.
https://imageshack.us/a/img228/4029/10404764.jpg
Non sintered
https://imageshack.us/a/img40/4079/12560y.jpg
Sintered
Triumph Trophy Launch Edition
PostPosted: 11:18 - 02 Oct 2012    Post subject: Reply with quote
I notice a 'swish' sound when braking with sintered pads.
map
Mr Calendar
PostPosted: 11:32 - 02 Oct 2012    Post subject: Reply with quote
Thanks for the replies so far but none have really answered the query.
If you get a bike, say 2nd hand, and look at changing the brake pads how do you know what type has been fitted.
Come to that what magic pixie tells the MOT tester that it's a non-sintered pad so they can give you a fail if less than 1.5mm left Likewise how do they tell sintered is greater then 1mm but maybe less than 1.5mm (must have great training/eyesight as I've never seen them measure it). Or do they just assume all are non sintered and fail at less than 1.5mm for safety reasons?
Confused
sickpup
Old Timer
PostPosted: 11:41 - 02 Oct 2012    Post subject: Reply with quote
Polarbear did.
Colour of backing pate tells you what they are
Gold = HH Fren
Blue = GG Kyoto
Black = GG old stock EBC, Armstrong
Green = GG EBC
And the list will go on.
Metallic coloured backing generally denote HH rated in the after market. All pads are required to have the heat (yes I did mean heat as that is what the rating is for) rating stamped on the back of them as well as the manufacturers name..
Fizzer Thou
PostPosted: 16:18 - 02 Oct 2012    Post subject: Reply with quote
https://www.ehow.com/about_5333274_ebc-hh-pads-motorcycles.html
If the pads are that low that the MoT tester has decided that they may be fail worthy it would be best to replace them with some HH friction rated pads on the front and some GG rated pads on the rear.
I have some Armstrong pads fitted to my XR-SM.They have a green painted backing plate but they do have small particles impregnated into the pad material but are GG rated.But they do act more like HH friction rated pads and give a 'swishing ' sound when the brakes are applied.I put this down to the heavily drilled swept area than the pads themselves
Always have a 'Plan B'
PostPosted: 16:28 - 02 Oct 2012    Post subject: Reply with quote
And also if my pads were down to 1.5 mm I would have changed them already, irrespective of brake type. It's not unheard of for pad material to start lifting from the backing plate and that risks the disks, let alone your neck.
The last post was made 13 years, 271 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 2.03 - MySQL Queries: 13 - Page Size: 59.42 Kb
