| marehamjoe |
 marehamjoe Derestricted Danger
 Posted: 23:26 - 01 Oct 2012 Post subject: MTX RamAir race pod filter |
Hi guys, just bought a RamAir race pod air filter for my 1991 Honda MTX 125 and was wondering if anyone could shed some light on appropriate jetting for this filter as im sure it will need more fuel, just not sure how much! i dont have a clue what the standard jet is but maybe someone here does! cheers guys!  ____________________ You should have got a 2 Stroke! |
| Matt- |
 Matt- World Chat Champion
 Posted: 00:15 - 02 Oct 2012 Post subject: |
Chuck the filter way, putting pod filters / foam jetting always puts the jetting off, your best way would be to use the standard air box, and drill maybe a couple of 8mm holes in the top, the MTX
Uses the same engine as a NSR and the NSR's can be air box modded.
If your looking for a cheap ish ish performance gain, I would look into buying carbon reeds, it's more throttle response than a speed increase.
If your still wanting to use the Pod filter I would go 5 up on your standard main jet, if that doesn't work go up 10 and start rich and work down towards lean, NEVER make a 2 stroke lean, do plug chops to determine if its rich / lean, warm bike up, go for a long run, hit the kill switch, roll to a stop, take Peter the plug out, then if its brownish, coffee color its good
If your still having trouble the needle notch may come into it.
Good luck !
Matt ____________________ RIP jack (wheelie king), you will never be forgotten.
Current Bike's - Road Legal TZR 125 Pitbike, Aprilia SR50R 2010 |
| marehamjoe |
| Matt- |
 Posted: 00:29 - 02 Oct 2012 Post subject: |
Right, on the side of your MTX carb their will be some numbers,
Should be PHBH something ...
https://www.dellorto.co.uk/merchandise/Carburetor_parts.asp?CategoryID=2
Then you will see links on the side, click your model carb, then look for main jet part, then buy 5 main jets then work your way down.
Their a very quick genuine service !
Good luck bud
| _Iain_ |
 _Iain_ Banned
 Posted: 01:33 - 02 Oct 2012 Post subject: |
It'll cause more greif than it's worth, and you'll probbably blow the engine to bits in the process of trying to get the jetting right.
Even if you do get the jetting right then expect little/no performance gains from it. Perhaps some noise, but not much else. Box it up, sell it to the next muppet on ebay.
Carbon reeds probbably will increase the throttle response, however the cost of the parts & paying a mechanic to fix it when it goes tits up just are not worth the hassle. De restrict it sure, sporty pipe, again why not - power to be had there from the 2T's but know when to stop, leave it & get a bigger bike!! ____________________ Please be aware that the above post may be full of complete nonsense.
| Blau Zedong |
 Blau Zedong Banned
 Posted: 07:55 - 02 Oct 2012 Post subject: |
Since when does an MTX have a Dellorto carb???
Jesus. ____________________ 18:54:48 Rob Fzs: jews don't give away stuff for free
18:54:59 Rob Fzs: unless its their clothes/ hair/ golden teeth |
| Matt- |
 Posted: 08:26 - 02 Oct 2012 Post subject: |
Sorry I must be mistaken, my friends Honda MTXR had a delorto but it must have been a upgrade on the standard set up.
I agree with Iain in some areas,
I would go with - de - restricting it if it hasn't been done, get some carbon membranes, £30 off eBay, easy to fit. Also I would go with the sporty pipe, something like a Arrow or something, maybe a bit hard locating a expansion chamber / downpipe as they've all gone rusty as people don't look after the buggers, a new one would set you back at £200 + for a full system.
Plus I wouldn't have a pod filter on MTX as its a off roading bike I would be temped to take it green Laining and get the bike soaked. If I did that with the pod filter on, the engine could be sucking in water.
Good luck
| marehamjoe |
 Posted: 08:44 - 02 Oct 2012 Post subject: |
Cheers for the replies and good advice, by the looks of it im better off not unpacking it when it arrives and selling it straight back on!! still got some nice red hand guards, sprockets and chain, brakes all round and piston etc so should be happy days!  ____________________ You should have got a 2 Stroke! |
| Matt- |
| 69chris |
 69chris Trackday Trickster
 Posted: 19:08 - 02 Oct 2012 Post subject: |
you sure bout that ?  |
| sickpup |
 sickpup Old Timer
The last post was made 13 years, 273 days ago. Instead of replying here, would creating a new thread be more useful? |
