| ped87 |
 ped87 L Plate Warrior
| Alpha-9 |
 Alpha-9 Super Spammer
| ped87 |
| Alpha-9 |
| _Iain_ |
 _Iain_ Banned
 Posted: 14:48 - 04 Oct 2012 Post subject: |
The issue lies in getting a spark.
If the spark on the efi engine is ECU controlled and not standalone then it wont work.
If you're okay knowing that you MAY have to swap the generator/rotor assembly etc over then it should work. More than happy to check my efi bike & see what the wirings like compared to yours if you can tell me where to look and what plugs you want photo's of? ____________________ Please be aware that the above post may be full of complete nonsense.
| ped87 |
| ruck bodgers2 |
 ruck bodgers2 Scooby Slapper
 Posted: 15:55 - 04 Oct 2012 Post subject: |
no need to map it out really . easiest way is change the loom its the cdi that does the mapping depending on your exhaust altering the flow through which probably would not be significant enough to encorperate a new map or a fuel commander to trick your lambda censor if u wanted to in order to send more or less fuel throughout the entire range problems may arise before the map hits its walled limits . the throttle body needs to hold the jet to spray the fuel. the throttle body will also need a censor . between the 02 censor and the others information is feeded from the cdi which negotiates and dictates there performance in an ask and tell kind of way . also no need for a special sort of fuel tank even a thermos flask with a tap on and a hole in the lid would work as long as it holds fuel and can send it to the pump via gravity. unless you wanted to use a tank that has the fuel sender/pump built into it . or whatever other sort of concept you would like to encorperate . automatic choke need not apply just keep yours closed .
complete loom to suit the throttle body you wanted to add and cdi. unless you study components hard and compare voltages,wiring,sizes,bore size, and everything else relative enabling you to
( fit this jet to that throttle body and wire that jet to that loom and then find a ecu that is mapped well enough to your engine specifics ) OR u could just buy the correct unit
and then wiring it all together.most people would probably take the easy route which would be to buy a complete loom and matching ECU along with the throttle body and pump for the same engine .which is what i have done in the past as a oppertunity that was cheap was available to me.
but by trawling information comparing studying and a lot of head scratching it is achievable to mish mash odd components together and make them work as they were intended to . this is a longer road to take and usually costs less in cash but costs more in headaches. people tend to pay a lott out to take the easy route for whatever reasons they may have .
you could convert a normal carb to a throttle body if you really wanted to . you could even make one from a piece of stainless pipe and a drill copper pipe and a box of broken electrical components ......... christmas lights flasher relay
if time is an issue for you just cough up .
if you have no money make it yourself ?thats usually the only option i have . if your in that boat to ill try and help because i know where your coming from
and as they say Necessity is the mother of invention. and all that balls
.forget all of the above im mumbling .
in answer to your question . no. but dont give up on the idea im just a novice and probably wrong  ____________________ throw it up the wall |
| Alpha-9 |
 Posted: 16:13 - 04 Oct 2012 Post subject: |
^ I wish you used punctuation and more line breaks, that post looks like it could have useful info in it
Also, confusing OP, is it a YBR injection engine you're trying to put into it? ____________________ Fzr-600 1999 |
| ped87 |
| YBR Ric |
 YBR Ric Spanner Monkey
| Matt- |
 Matt- World Chat Champion
| YBR Ric |
 Posted: 11:44 - 05 Oct 2012 Post subject: |
First thing that comes to mind is you can't run a 180cc bore kit with EFI  |
| ped87 |
| hunterman1200... |
 hunterman1200... L Plate Warrior
The last post was made 13 years, 317 days ago. Instead of replying here, would creating a new thread be more useful? |
