| Dannylewis27 |
 Dannylewis27 Renault 5 Driver
 Posted: 20:22 - 05 Oct 2012 Post subject: Aprilia RS125 Extrema Problems and chat. |
[u]Hi there, i am new to the forum and would like to start up a chat about these bikes and help resolve some problems.
I have a 98 RS125 Extrema which tbh has been a nightmare until tonight when i had a stroke of luck.
I bought this bike about a week ago and it ran for about 5minutes before it broke lol
I got it into second gear and it went clunk clunk clunk quite rapidly so i pulled over and then it wouldnt start and the battery died
I charged up the battery only to find the relay had fused a constant connection because it was insufficient ampage and the battery wasnt earthed so the wiring to the rest of the bike was taking the hole of the current and it melted the wiring.
I swapped the wiring and relay and earthed the battery to the frame but it still wouldnt turn over, it just went start button... clunk, press start...clunk
i wasnt sure if it had seized or what. maybe the engine seized? (because i noticed it had no drain plug)
Yeah this guy was a real wanker....
Anyway i took the spark plug out today and sprayed in some penetrating fluid down the cylinder and on the clutch plates and HOORAY it turned over!
after a week of clunk clunk clunk the fookin thing started!!
buuuut then only to find a HORRIBLE rattling noise, this isnt a light rattle, this is something rattling around in the engine,
now it wont select 1st gear, i can select neutral, and go up to second, but not go into 1st, is it possible that the 1st gear has broke? or the slector fork?
what could this be?
and before anyone asks im not riding it, i havent ridden it since it first stoppeda week ago
Thanks guys
Danny [u][/u][/u] ____________________ Derbi senda R, 03
Aprilia RS 125 Extrema, 98 |
| Matt- |
 Matt- World Chat Champion
| Dannylewis27 |
| andy_uk |
 andy_uk World Chat Champion
| Dannylewis27 |
| thomp1983 |
 thomp1983 Crazy Courier
| andy_uk |
| Dannylewis27 |
| Ribenapigeon |
 Ribenapigeon Super Spammer
 Posted: 18:03 - 06 Oct 2012 Post subject: |
Whatever you have to do just console yourself with the fact your not having to do it on a car. good luck |
| Dannylewis27 |
| andy_uk |
 Posted: 18:23 - 06 Oct 2012 Post subject: |
This may help  ____________________ Aprilia Classic 125, GS500E, ER5-A1, ER5-C4, ER6 & an XJ6 project frame... |
| Dannylewis27 |
 Posted: 19:11 - 06 Oct 2012 Post subject: |
Any you are an absolute ledge!
Thanks for that, do you realise how many places I've looked for something like that? And no videos on YouTube !
Now I can take it apart and tell you guys what's wrong and it post pictures!
This is my bike (I have out mirrors on now :p)
https://i132.photobucket.com/albums/q28/joeymaybe/IMG_0877.jpg ____________________ Derbi senda R, 03
| thomp1983 |
 Posted: 19:16 - 06 Oct 2012 Post subject: |
no point buying anything for it until you've stripped it, it may be something simple like a small end bearing. it'll cost you nothing to strip it down now then you'll know what you need come payday, even if you send it to pjme you'll need to take it out the frame. removing it isn't difficult, 3 or 4 bolts actually hold the engine in the frame, apart from those it'll be remove exhaust, disconnect clutch cable, disconnect throttle cable (remove slide from top of carb and disconnect oil pump.), remove carb, remove front sprocket, remove airbox, disconnect any wiring connectors/wiring connected to engine, disconnect coolant hoses, drain fluids from engine then remove it should just about cover it, probably only need a socket set and some decent allen keys.
id rebuild it yourself personally, it's probably just the bearings and balance shaft gears that are shot, a bearing set can be had on ebay for £40 and it's about £25 for balance shaft gears, and you'll need a flywheel puller about £10 and an oven to heat the casing for removing/fitting the bearings
chris |
| Dannylewis27 |
There is a gap of 6 years, 32 days between these two posts... |
| lars lutzka |
This post is not being displayed because it has a low rating (Off Topic). Unhide this post / all posts.
 lars lutzka L Plate Warrior
| lars lutzka |
The last post was made 7 years, 353 days ago. Instead of replying here, would creating a new thread be more useful? |
