Batterry fire ish
WannaBeDude
PostPosted: 23:19 - 08 Oct 2012    Post subject: Batterry fire ish Reply with quote
Sparks and flames were had, cups of water followed by hose saved bike ish.
Now, afaik ignition was off, batt charger was attached and on.
Batterry now is v low on dist water, which it was not low pre summer, thinking heat did the water.
Damage unknown to electrical components, or if damage is v likely i dont know.
Only proberble cause, a ciggy lighter attachment somehow resting on batterry, poss cause. Was doing work on rear light, earlier in day.
Confusing at mo, poss costly, could of been worse, suspect retardation was the cause, but leave it to BCF to reafirm.
Pics moro. Thumbs Down
PostPosted: 23:34 - 08 Oct 2012    Post subject: Reply with quote
^^^You're a fiddler messer aren't you.
Something shorted out? Or battery was low when set to charge? Was it a motobatt. Laughing
That bike could tell some tales.
Last edited by Howling TerrorOutOfOffice on 00:05 - 09 Oct 2012; edited 1 time in total
Simple
PostPosted: 23:38 - 08 Oct 2012    Post subject: Reply with quote
Bike telling you to let it die.
Take hint and pass test.
Insta - FemFeral
WannaBeDude
PostPosted: 23:55 - 08 Oct 2012    Post subject: Reply with quote
Fiddler where im from is not v nice, less you be on a roof.
Normal batt, have ideas, pics will help peeps decide.
One hand if nor my fault then dangerous, 2nd hand is dude tardation, either way .. mildly annoyed, not withstanding it could of been worse, even ifelectrics are fucked.
Simple, you got rabbits n your farm ?
covent.gardens
World Clap Champion
PostPosted: 00:02 - 09 Oct 2012    Post subject: Reply with quote
Could've caused a big fire, could've required a fire engine at the same time someone else needed a fire engine, you could have cost someone their LIFE.
Serious comment though, get a small powder fire extinguisher, I had to use mine once, and it probably saved me the house Very Happy
Simple
PostPosted: 00:05 - 09 Oct 2012    Post subject: Reply with quote
No because i'm good at my job.
I have various rabbit permissions that have rabbits bigger than troll face to deal with. Whey?
Insta - FemFeral
WannaBeDude
PostPosted: 00:08 - 09 Oct 2012    Post subject: Reply with quote
Let my borother kill your rabbits, hes not like me one bit, hes the white sheep Thumbs Up While you at it train his dog, he can jcb your field for you Cool
WannaBeDude
PostPosted: 00:10 - 09 Oct 2012    Post subject: Reply with quote
My retardation and CT PAyments are as good as any other fuckers.
Makes you not want to leave batt on charge this does, was is a ctek x8 decent charger aswell.
Pics moro ..
Simple
PostPosted: 00:11 - 09 Oct 2012    Post subject: Reply with quote
Er no, see previous post. i have no rabits and i get paid to remove them from other places, i'll train his dog but he will have to pay like everyone else does. No freebies. The fields do not need JCB'ing, whatever that means and if they did I would use the JCB myself.
Odd boy Confused
Insta - FemFeral
WannaBeDude
PostPosted: 00:13 - 09 Oct 2012    Post subject: Reply with quote
Well, i doubt you could jcb as quick as he could, just as he cant train dogs as quick as you do .
Odd girl.
WannaBeDude
PostPosted: 00:14 - 09 Oct 2012    Post subject: Reply with quote
edit i thought you had to jcb a field once a year ?
kernow24
PostPosted: 00:47 - 09 Oct 2012    Post subject: Reply with quote
*opens door* witnesses retards attempting to have a conversation *closes door*
WannaBeDude This post is not being displayed because it has a low rating (Spam). Unhide this post / all posts.
WannaBeDude
PostPosted: 10:15 - 09 Oct 2012    Post subject: Reply with quote
https://i37.photobucket.com/albums/e53/covdude/2012-10-09102928.jpg
https://i37.photobucket.com/albums/e53/covdude/2012-10-09103018.jpg
https://i37.photobucket.com/albums/e53/covdude/2012-10-09103320.jpg
https://i37.photobucket.com/albums/e53/covdude/2012-10-09103404.jpg
SamWise72
PostPosted: 10:20 - 09 Oct 2012    Post subject: Reply with quote
So you dealt with an electrical fire using a cup of water? Excellent......
WannaBeDude
PostPosted: 10:26 - 09 Oct 2012    Post subject: Reply with quote
And a hose, this was after failing to retrieve a bs 429s pink powder extinguisher out of my ass mind, and without said water, the bike would of burnt to the ground.
But thanks for the fire lesson, i'd almost forgot training to put out imense fires on warships, glad i've got some condescending cunt here to point out my fire failings.
I'd be more inclined to point out if my retardation in leaving the ciggy lighter too close to the batt, if that was indeed the cause. Middle Finger
PostPosted: 10:27 - 09 Oct 2012    Post subject: Reply with quote
What would you have done then? Assuming he doesn't have a CO2 or powder extinguisher like most of the population.
It is a 12v power-supply I'd take the risk of a mild electrical shock over sitting there and watching it burn.
SamWise72
PostPosted: 11:01 - 09 Oct 2012    Post subject: Reply with quote
Happy to be of service Smile And sorry. Wasn't intending to be a dick, but reading it back, I was. (as it happens, I do have a powder extinguisher)
WannaBeDude
PostPosted: 11:27 - 09 Oct 2012    Post subject: Reply with quote
Yes Sam, and your post would of been double FAIL, had you not been in the possession of one.
They need testing and checking regular, you go to use one thats been stored for a few years, and chances are it fails, wasting you time where water would of at least prevented total loss.
SamWise72
PostPosted: 11:51 - 09 Oct 2012    Post subject: Reply with quote
Is there a smiley for "I'm holding my hands up on this one"?
WannaBeDude
PostPosted: 12:02 - 09 Oct 2012    Post subject: Reply with quote
Yes - its called the rarity of thumbs up karma Karma for the dude ! Cool
WannaBeDude
PostPosted: 15:02 - 09 Oct 2012    Post subject: Reply with quote
All ' seems ' to be working - not ridden her yet - but better than expected Smile
Islander
PostPosted: 15:16 - 09 Oct 2012    Post subject: Reply with quote
Water isn't that good a conductor of electricity and there's only 12 volts of electrical pressure available so it isn't a shock risk either. It would have quenched the flames and cooled things down.
SamWise72
PostPosted: 15:26 - 09 Oct 2012    Post subject: Reply with quote
Yes, that makes sense. Just triggered my automatic "That's a bad idea" response, rather than my "think it through" circuit.
Islander
PostPosted: 15:28 - 09 Oct 2012    Post subject: Reply with quote
I wouldn't advocate throwing a cup of water over a domestic consumer unit though Wink
The last post was made 13 years, 106 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.71 - MySQL Queries: 13 - Page Size: 128.23 Kb
