| U_W v2.0 |
 U_W v2.0 World Chat Champion
| J4mes |
 J4mes World Chat Champion
 Posted: 18:22 - 11 Oct 2012 Post subject: |
Heat, cold, penetrating fluid, try tightening it before loosening it, use a bigger lever  |
| Flatbadger |
 Flatbadger World Chat Champion
| J4mes |
 Posted: 18:30 - 11 Oct 2012 Post subject: |
If it's in a set then use a big spanner or a big adjustable on the end of the set in order to get more leverage on it. But remember to use your free hand to hold the driving end in the screw head so it doesn't slip and round it out
Or if as above it's a free allen key, then you can use the long end in the screw head and grab it with pipe grips or a smaller adjustable spanner on the flats of the allen key.
Pikey as you likey, but needs must and it works  |
| pinkyfloyd |
 pinkyfloyd Super Spammer
| leecook385 |
 leecook385 Two Stroke Sniffer
 Posted: 19:01 - 11 Oct 2012 Post subject: |
spray with penetrating oil ,have a brew, spray some more come back after 10/15 mins try it. put the allien key in using the short end and hit with a hammer a few times. If you have a ring spanner you can slide over the long bit of the allien key to make a longer lever.
try using a plumbers blow torch to give it some heat.
make sure you shout lots and if you want to kick some thing i recommend not kicking your bike off its stand  ____________________ cbr 600 f |
| U_W v2.0 |
The last post was made 14 years, 9 days ago. Instead of replying here, would creating a new thread be more useful? |
