Does bump starting damage anything? (Car)
EazyDuz
PostPosted: 21:35 - 12 Oct 2012    Post subject: Does bump starting damage anything? (Car) Reply with quote
My car fuel economy is piss poor at 35-40mpg.
There is an ongoing debate about which saves more fuel, coasting in neutral down a hill, or coasting in gear (in a modern car the fuel cuts off, using none supposedly).
Well i thought what about scrapping all that, and turning the ignition off down a hill, then, instead of wearing out the starter motor and drawing battery power, just whack it back in the appropriate gear to match your rolling speed and bump start it.
I was rolling with the engine off the other day in traffic, about 8mpg, then when i needed to, i put it in 2nd, and it cranked over and came back to life, seemed quite natural and undamaging...
Also in b4 safety nazi's, i only intend to do it when i deem it safe. Does it do any damage to the car?
EazyDuz
PostPosted: 21:36 - 12 Oct 2012    Post subject: Re: Does bump starting damage anything? (Car) Reply with quote
I was rolling with the engine off the other day in traffic, about 8mph, then when i needed to, i put it in 2nd, and it cranked over and came back to life, seemed quite natural and undamaging...
Islander
PostPosted: 21:38 - 12 Oct 2012    Post subject: Reply with quote
No, as long as you choose a gear appropriate for the road speed you're coasting at.
carvell
Scuttler
PostPosted: 21:40 - 12 Oct 2012    Post subject: Reply with quote
?! You're mental!
Anyway... I don't believe there is an ongoing debate about which saves more fuel, coasting or going down in gear.
Going down a hill in gear will use no fuel (on pretty much any fuel injected car in 10 years), coasting will use fuel to keep the engine idling.
With your engine off your brakes will lose a lot of their effectiveness, and you could accidently put your steering lock on. A bit of a bonkers idea in my opinion,
Yamaha TDM 850
EazyDuz
PostPosted: 21:52 - 12 Oct 2012    Post subject: Reply with quote
carvell wrote:
?! You're mental!
But to counteract that argument, say its a steep hill you are rolling down, then at the bottom the road is completely level.
Which uses more fuel:
Rolling down the hill in gear, then when you reach the bottom, add gas to maintain speed.
or
Rolling down the hill in neutral, actually gaining speed due to gravity (no engine braking holding you back) therefore once you reach the level road at the bottom, you will coast on it longer before you need to put it in gear and add gas.
carvell
Scuttler
PostPosted: 21:57 - 12 Oct 2012    Post subject: Reply with quote
If the car is in 5th then there will be almost no engine braking - your car will accelerate if going down a steep hill in 5th (I've managed this on the M5/A38 section of motorway), you'll find that there's no advantage to running it in neutral.
Give it a go!
Yamaha TDM 850
EazyDuz
PostPosted: 22:02 - 12 Oct 2012    Post subject: Reply with quote
Give it a go!
Must vary with each car, when im coasting in 5th down a hill and i push the clutch in, i can feel the car lurch forward and gain a lot more speed and distance.
PostPosted: 22:37 - 12 Oct 2012    Post subject: Reply with quote
Lose your power steering and brake servo to save a quid or two a month?
jimspeed
PostPosted: 23:00 - 12 Oct 2012    Post subject: Reply with quote
what car? bumping them can damage the cambelt and cause timing chains to jump teeth both resulting in a lot more expense than you would ever save in fuel. imagine there's your cambelt say nearing the end of its due service life and suddenly its having to go from standstill to >2000rpm in milliseconds Confused when you use the starter it spins the engine at >350rpm so relativly smooth transition to idle speeds.
most timing chain setups run a hydraulic tensioner which is tensioned by the oil pressure so again sudden high speeds from standstill can cause the chain to jump a tooth or 3.
some cars will also log a fault code to say the engine has started without the key being turned (older scoobs do this and will stick the MIL lamp on after a few goes).
basically no your not really going to save anything and the loss of power steering and servo brakes could be a deal breaker one day. Thumbs Up
Hyosung cruise 125(passed test on, sold) Kawasaki el 252 (better than expected but sold on) Kawasaki GPZ500S first "big"bike.(sold) ZZR600 E5..Z750 2007,ER5, currently on a 2008 Enfield bullet electra x and loving it..
,"Alpha-9: Is there any correlation between dyno rod and dyno kits?"
You might gain a bit more momentum coasting in neutral rather than top gear.
However engine off you loose power steering and ABS / brake servo, and if the key slips out likely land up with the steering lock coming on.
Bump starting will likely dump unburnt fuel down the exhaust, which the cat and lamba probe(s) won't appreciate.
i.p.phrealy
PostPosted: 23:07 - 12 Oct 2012    Post subject: Reply with quote
yep, unburnt fuel will get through and knacker your catalytic convertor and EGR sensor.
covent.gardens
World Clap Champion
PostPosted: 23:47 - 12 Oct 2012    Post subject: Reply with quote
Most people who meet me think I'm as tight as arseholes and it's true, I don't like to waste money...
but even I draw the line and I would never consider doing that.
It's pretty stupid really, all that effort for a few pence, if you were that bothered you should've got a more economical car in the first place!
Villers
PostPosted: 23:58 - 12 Oct 2012    Post subject: Reply with quote
Am I the only one who thinks thats not so bad? Laughing
Walloper
PostPosted: 00:14 - 13 Oct 2012    Post subject: Reply with quote
Dump the car if you are not very good at it and buy a pedal bike.
There is nothing wrong with knocking it out of gear on the downhill it will not damage anything.
Shocked
hellkat
PostPosted: 00:20 - 13 Oct 2012    Post subject: Reply with quote
When I was 22 I used to have an old Austin Maxi that never started unless I parked it on a slope and rolled it down the hill.
But it always started once I did that.
Cool Thumbs Up
PostPosted: 00:31 - 13 Oct 2012    Post subject: Reply with quote
Nope. With extreme restraint I can get into that range.
colin1
Captain Safety
PostPosted: 01:09 - 13 Oct 2012    Post subject: Reply with quote
You can turn the ignition off, then turn the ignition back on without starting up the engine. This way you have working power steering and brakes. You can then restart the engine when you want with the starter motor, to avoid the problems someone outlined.
I think turning off the engine at traffic lights makes more sense than on downhills. Some cars do this automatically and start again when you press the accelerator.
Walloper
PostPosted: 01:16 - 13 Oct 2012    Post subject: Reply with quote
The engine drives the brake vacuum unit and the steering pump.
So to have brake and steering assistance the engine must be at least turning.
If ignition on it would be in what is called 'over run' and would slow the vehicle. If ignition off it would still be in a state of 'over run' and slow the vehicle but with the added dimension of no brake lights or trafficators.
Villers
PostPosted: 01:19 - 13 Oct 2012    Post subject: Reply with quote
Mines admitting to a very geneous 26.4mpg today, and thats with a remap that suposedly increases mpg. No doubt some on here will have even more extreme cases lol.
As for the stop/start, I still find it weird to be sat next to a beemer (or similar, other cars are available) at the lights and then hear it start up when the lights go green!
Shaft
PostPosted: 01:31 - 13 Oct 2012    Post subject: Reply with quote
I dream of those sorts of numbers, but then the day I consider buying a car based solely on it's ability to get good fuel economy, I think I'll be giving up driving.
ashwin2936
PostPosted: 06:22 - 13 Oct 2012    Post subject: bump starting Reply with quote
be careful, i was in a car where the driver turned the ignition of while going down a hill, as a result of this the steering lock applied and the abs wasnt working, we skidded into the on coming traffic and were very lucky not to have an accident.
yq50, nsr-125, bandit-600, cbr-600 f2, zx6r g2, cbr929
daemonoid
PostPosted: 09:25 - 13 Oct 2012    Post subject: Reply with quote
50mpg when driving like a loon. Hyper milering can get 70mpg from my car*.
So normally about 50 Wink
*Smart roadster coupe
current: ducati monster 750
el_oso
PostPosted: 10:11 - 13 Oct 2012    Post subject: Reply with quote
even that would be ambitious
Duke 390
Car: Jeep Wrangler 4.0L
PostPosted: 12:39 - 13 Oct 2012    Post subject: Reply with quote
Villers wrote:
Mines admitting to a very geneous 26.4mpg today, and thats with a remap that suposedly increases mpg. No doubt some on here will have even more extreme cases lol.!
The 2 cars we have in normal use are the 156 and the Jaguar. The 156 in normal use will manage 31mpg. A long motorway journey driving gently sitting at 70 will see it manage 37mpg (manually calculated, no trip computer). The Jaguar has averaged 28mpg since we got it according to the trip computer, although not 100% happy with its accuracy(*). Sitting carefully at 70 it will do 35mpg, and on one journey when I sat at 56mph for about 100 miles (set off early and had loads of time) it managed to claim 39mpg.
The Maserati in daily use used to manage 18mpg.
(*) - Only time I have cross referenced it, the manual calculation worked out at about 2mpg worse than the trip computer. And in France earlier this year it managed to drink a tank of fuel while the trip computer gave a normal readout; trip computer said 33mpg which is about right for the speed we were doing, yet manually calculating it worked out at 22mpg.
The last post was made 13 years, 339 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.13 Sec - Server Load: 1.14 - MySQL Queries: 13 - Page Size: 135.84 Kb
