More fuel capacity?
Bike Chat Forums Index -> Touring & Exploration Goto page 1, 2  Next
stevew
PostPosted: 17:13 - 10 Oct 2012    Post subject: More fuel capacity? Reply with quote
My "touring " bike is an old 1997 Kawasaki VN1500-C2 (cruiser) fitted with a screen and some big Kappa panniers. Most things work for me so I'm happy with the bike, except for one thing.............the tank capacity, it's miniscule with a range if about 100 miles! I have seen the Tour Tank type thing from the USA but they are expensive and a pain to get here. So I'm thinking that there may be an answer here in the UK. Does anyone know, or have any ideas, what i can do to extend my range? I would like to roughly double the fuel storage so that would mean another 15L but anything would be good!
Maxsym 400i 2013, Sterling 125 2017, Honda Wave110i 2014,
Orpington
The opposite of bravery is not cowardice, but conformity. Robert Anthony
ToGGoT
PostPosted: 14:39 - 11 Oct 2012    Post subject: Reply with quote
Right,
As far as my understanding goes (And anyone feel free to correct me on this!) the law in the UK is that you can carry, in a vehicle, in addition to the fuel tank, either 2x10L metal fuel containers, OR, 2x5L plastic fuel containers.
So, potentially you could figure a way of carrying 2x extra 10L metal fuel containers (And i'd definitely want to try and balance the extra weight if possible - especially if the containers aren't baffled, and keep it away from the exhaust)
I don't know about the legalities of running a "fuel cell" as a second tank, but i cant imagine its straightforward.
ToGGoT
2005 BMW R1150R
RideLimousin
PostPosted: 19:48 - 12 Oct 2012    Post subject: Reply with quote
Could you wait for a 2nd hand fuel tank to come up on ebay USA and have it shipped over?
Might be the best bet....
Motorcycle Touring Holidays in France: Ridelimousin
See my ridelimousin renovation blog: https://ridelimousin.blogspot.fr
See my renovation thread: https://www.bikechatforums.com/viewtopic.php?t=244340
map
Mr Calendar
PostPosted: 21:31 - 12 Oct 2012    Post subject: Reply with quote
It might be worth looking through the American forums and sites as they often do the extra fuel tank thing.
Maybe more for the Ironbutts guys but you might find something for a cruiser.
Just a thought Thumbs Up
stevew
PostPosted: 08:37 - 13 Oct 2012    Post subject: Reply with quote
Thanks for your thoughts so far.
Found this on ebay
https://www.ebay.co.uk/itm/160733461315?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649
And it's size is 410mm long x 260mm wide x 210 mm high.
Might be the answer if I can fabricate a suitable rear rack, run a fuel line and fit a fuel tap.
I see it as a sort of "half way house" between just carrying a plastic 1 gal petrol container like you get in a garage and the full Tour Tank monty which will cost lots!
More thoughts are always welcome!
Orpington
Casper
PostPosted: 13:31 - 15 Oct 2012    Post subject: Reply with quote
If you are keeping the bike long term why not get a 2nd hand tank. Take it to a chop shop and get it split and extended. Work out your MPG and work out how many litres you need for around 200 miles and tell the chop shop what you want. You have room to extend the tank upwards at the seat end and possibly widen an inch at each side tapering to the front. It may not be cheap but if you tour a lot it may be worth it and when at home doing your normal riding you can revert back to the original tank.
stevew
PostPosted: 19:14 - 15 Oct 2012    Post subject: Reply with quote
Certainly a possibility but that means that if I do ever change the bike the bigger tank will be redundant. If I can get something that is an "add on" I should be able to use it on just about any bike.
That's the plan anyway!
I've has one UK supplier come back to me saying that he can fabricate an axillary tank for me similar to the TourTank one for me at about £140. That doesn't seem too bad.
Orpington
PostPosted: 19:25 - 15 Oct 2012    Post subject: Reply with quote
Remember to get the heights correct. Put that higher than the fuel tank and fuel will come out of the main tanks breather. Put that lower than the fuel tank and fuel will come out of that tanks breather.
stevew
PostPosted: 20:09 - 15 Oct 2012    Post subject: Reply with quote
But if I put a tap in the line I can leave the main tank turned off and use the aux one first as it will be higher than the original one. When the aux has dry I can open the main tank and close the aux tank. should work.......................I think !!
Orpington
PostPosted: 20:55 - 15 Oct 2012    Post subject: Reply with quote
Yes, if you want the hassle of that and don't forget to switch the tap at the right time.
stevew
PostPosted: 20:57 - 15 Oct 2012    Post subject: Reply with quote
I know it's a bit of a faff but it's only once in a very long ride!!
Orpington
parkmoy
PostPosted: 11:13 - 16 Oct 2012    Post subject: Reply with quote
I think you need to consider what might happen to the auxiliary tank in the event of being rear ended or any sort of accident which might split it. You don't want to end up with a fireball.
jetski
PostPosted: 11:32 - 16 Oct 2012    Post subject: Reply with quote
I would be more inclined to use a metal can. even if I had to manually top up the tank with it. having a plastic can sounds a little dangerous to me
bognorgaz
PostPosted: 11:32 - 17 Oct 2012    Post subject: Reply with quote
You could always start smoking, that way you wouldn;t mind stopping for fuel because you'll want a fag! Very Happy
map
Mr Calendar
PostPosted: 12:15 - 17 Oct 2012    Post subject: Reply with quote
bognorgaz wrote:
...you wouldn;t mind stopping for fuel because you'll want a fag! Very Happy
I see that opening for many gay (it's a cruiser right!), shag, roll your own, etc. jokes Wink
stevew
PostPosted: 14:44 - 17 Oct 2012    Post subject: Reply with quote
Sorry don't "do" fags...............of either type !!
But seriously it's not about stopping. I would be happy to stop if the petrol stations were there and open. In the Scottish highlands they are few and far between and often not open at the w/e.
Orpington
c-m
PostPosted: 08:47 - 18 Oct 2012    Post subject: Reply with quote
Stopping is all well and good, but when touring you could easily not be able to find the next fuel station, especially if you're not in a built up area, or western country.
a 200 mile tank range is probably the minimum for serious touring
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
Alpha-9
PostPosted: 10:06 - 18 Oct 2012    Post subject: Reply with quote
Jerry cans full of fuel in your boxes?
Fzr-600 1999
stevew
PostPosted: 19:36 - 18 Oct 2012    Post subject: Reply with quote
But where will I put the camping gear and all the paraphernalia that goes with me when touring??
Orpington
ToGGoT
PostPosted: 10:02 - 19 Oct 2012    Post subject: Reply with quote
I think you're going to have to make a decision here.
Either:
Shell out, and buy a 2nd hand tank that you can have enlarged (I agree with you, 12ltr capacity is very poor...), and put up with the fact that if you ever sell the bike you'll have to get another tank (Mind you, buy a bike with a bigger tank, and its less of an issue)
Or:
Fit some sort of secure mount for a 10l metal fuel can somewhere that allows you to pull over and top up your main tank when you hit reserve - Another 10l almost doubles your tank range anyway, and this way you dont need any complicated plumbing, etc.
Or:
Get someone to fit a separate reserve tank, plumb it all in with some sort of tap arrangement, and get good at tap switching. Be aware though, that your auxhiliary is unlikely to figure on your fuel gauge, and any alterations to the existing tank is going to limit resale potential on the bike, moreso if you aren't going to sell the auxhiliary tank with the bike.
I know having convenience is nice, but bar far the cheapest solution is to carry a fuel can like this one
ToGGoT
2005 BMW R1150R
PostPosted: 11:32 - 19 Oct 2012    Post subject: Reply with quote
Fit a tank from another bike with larger capacity. My mate fitted a VFR800 tank on his bros to double the range.
PostPosted: 11:43 - 19 Oct 2012    Post subject: Reply with quote
I would definitely go down the bigger tank route. There are just too many variables and risks involved in the second tank, plus you are taking up carrying capacity with the second tank.
You have 2 choices it seems to me, buy or have a larger tank made for your bike or buy a proper touring bike with a decent range.
Peirre oBollox
PostPosted: 15:21 - 19 Oct 2012    Post subject: Reply with quote
Just save the cash..........
he`ll just have to accept that hes gonna have to make more fuel stops and plan them accordingly.
I doubt the OP is going to make a RTW trip on a cruiser, so even if the OP is heading around Europe, I doubt hes never going to be more than 15-20 miles from a suitable fuel supply
stevew
PostPosted: 16:43 - 19 Oct 2012    Post subject: Reply with quote
RTW...no but:-
There is not much fuel in the Highlands of Scotland on the w/e!
Anyway why not RTW on a Cruiser? It's a motorbike 'aint it?
I don't think i fit in to the typical cruiser type as the bike was a good price and I like the characteristics of those big lazy V twins. It's comfy and it's whole persona stops me rushing about at speeds that I think I can handle ('cos I could when I was younger) when I really need to be traveling at realistic speeds for my age and ability!!
Never the less i an enjoying this thread and you have all been really helpful, loads of ideas to swill around the old head.
Cheers, keep it up!
Orpington
barrkel
PostPosted: 20:00 - 19 Oct 2012    Post subject: Reply with quote
Very true. I toured over the top and down the west side of Scotland on my SH300 scooter - tank range about 160 miles on the open road - and it was very tight at times. Gets to be that you want to top up any time you see a station 50 miles into the last tank.
Annoyingly, my GPS had petrol stations marked that had long since closed, even though I have a lifetime subscription and had the latest maps (Garmin).
The last post was made 14 years, 30 days ago. Instead of replying here, would creating a new thread be more useful?
Post new topic   Reply to topic    Bike Chat Forums Index -> Touring & Exploration All times are GMT
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 133.4 Kb
