Bike won' start in cold, via bump or electric
Eas85
PostPosted: 07:39 - 15 Oct 2012    Post subject: Bike won' start in cold, via bump or electric Reply with quote
(bike is a Yam XJ 600 1992, 23k miles.)
Got major problems with my bike not starting in the cold, it happened earlier in the year but got it serviced and carbs balanced and seemed to sort it for a while.
Now, after sitting all weekend it won't start on mondays, by bumping or by electric start. after its bee ridden once it does tend to start on the following days, it just seems to be when its been sitting for a while.
The bike is kept outdoors on the driveway, under a blanket and rain cover.
Really don't know what to do, I'm sitting here penning this post when I should be at work already, no other way to get there as it's 25 miles away.
Have been thinking about building an insulated box to store it in at night, but unsure whether I should just buy a new(er) bike on finance, bearing in mind that I will be commuting all through winter. What bike would be best suited for all year riding?
Currently riding a Honda Deauville NT650
GREENI3
PostPosted: 07:57 - 15 Oct 2012    Post subject: Reply with quote
Is the choke functioning correctly?
Eas85
PostPosted: 08:04 - 15 Oct 2012    Post subject: Reply with quote
yeah it seems to be, at least it seems to when the bike is running normally.
fatjames
PostPosted: 09:30 - 15 Oct 2012    Post subject: Reply with quote
How's the battery? I know you said about bump starting, but it's something to check.
Might be worth checking the fuel filter too, quite an easy thing to eliminate.
HTH
jetski
PostPosted: 09:34 - 15 Oct 2012    Post subject: Reply with quote
are you getting a strong spark? even a mild spark will work when warm but it needs to be a good one to start from cold
Eas85
PostPosted: 09:49 - 15 Oct 2012    Post subject: Reply with quote
Bike noob here, how do I check these things, RAC just been out they said it was probably battery
andym
PostPosted: 10:08 - 15 Oct 2012    Post subject: Reply with quote
My '95 Diversion would do the same thing, I never tried to sort the problem though as it would always start eventually.
I don't know if they have a problem with petrol draining out the carbs or something, but maybe try having the tap turned to pri. for a minute or two before starting.
As for the battery, how long does it turn over before going flat?
As a quick work around (won't fix the problem), maybe start the bike every day and run it up to temperature... Just a thought
jetski
PostPosted: 12:13 - 15 Oct 2012    Post subject: Reply with quote
to check the spark take the lead off the spark plug, then take the plug out, put the lead back on the plug and place it on the engine. make sure the metal casing of the plug is firmly touching a metal part of the engine. if you have to hold it in place use a pair of insulated pliers. I'm not sure if you can get a shock but its not worth the risk. anyway turn the engine over, it should turn very easily because there will be no pressure in the cylinder due to the spark plug missing and a gaping hole where it used to me. at the two terminals of the plug you should see a spark jump across. if its in direct sunlight you may not see it but you should be able to notice in the day time, certainly at night or dim light
as you won't know what a strong spark and a week spark a actually looks like you may need to do the same with another engine to compare. it may just be easier to buy a spark plug and fit it so you can rule that posability out without any faffing about
weasley
PostPosted: 12:25 - 15 Oct 2012    Post subject: Reply with quote
Check the battery connections - are they tight?
Then check the regulator/rectifier as mine got all messed up with corrosion, leading to a weak battery, which led to poor starting and eventually saw off the CDI unit.
Eas85
PostPosted: 13:59 - 15 Oct 2012    Post subject: Reply with quote
The plugs were all changed when I got it serviced about 8 weeks ago, the rectifier is also new as the old one blew up a few weeks ago.
The battery goes flat after about 6 depressions of the starter, I put it on charges this morning then at midday I tried it after the sun had been on it for a and it started first time, annoying. It's just the cold, it really hates it
Islander
PostPosted: 14:04 - 15 Oct 2012    Post subject: Reply with quote
That's nature's way of telling you it's time for a new battery Thumbs Up
kernow24
PostPosted: 18:36 - 15 Oct 2012    Post subject: Reply with quote
had the same a few weeks ago.. and it was a completely buggered battery, you should get more than 6 tries of the starter from a healthy battery.
The fact your reg/rec 'blew up' would suggest your battery wasn't receiving a good charge over some time.. im guessing you've needed to charge it up multiple times recently? constant charging and discharging will completely knacker a small battery relatively quickly.
The cold will sap the energy from a dying battery faster than it will from a healthy battery, so a weekend of being laid up will drain the battery if its knackered, but it will seem to be the cold weather causing the starting problems.
Id charge it, go for a ride, be able to stop and start multiple times throughout the day, then by the next morning it would have gone flat, despite the charging system being in working order.
Fitted a new battery and its all fine now.
Noxious89123
PostPosted: 19:36 - 15 Oct 2012    Post subject: Reply with quote
Does sound like that battery is stuffed, even more likely seeing as your reg/rec went bang.
sidewinder
PostPosted: 20:47 - 15 Oct 2012    Post subject: Reply with quote
Had similar things happen with my divvy when i first purchased.New battery on been good ever since Thumbs Up
covent.gardens
World Clap Champion
PostPosted: 00:15 - 16 Oct 2012    Post subject: Reply with quote
It does prove you need a new battery if your using a charger to charge it and it still only has 6 starts in it. As you need it for work and had trouble bump starting I'd get something good like a Motobatt.
And you should probably get a booster pack so you can jump start in future. Or, if you want a booster pack on the cheap, keep your old battery fully charged with a smartcharger and you can use that to jump with, as it still has enough life left to start a bike a few times; just need some leads.
andym
PostPosted: 04:03 - 16 Oct 2012    Post subject: Reply with quote
Not disagreeing about needing a new battery, but surely as long as there is enough power for ignition lights then you should be able to bump start the bike?
Eas85
PostPosted: 09:35 - 16 Oct 2012    Post subject: Reply with quote
I will get a new battery to today, I assume they're pretty easy to fit? And see how that goes
Islander
PostPosted: 09:47 - 16 Oct 2012    Post subject: Reply with quote
Remove the black lead first and tuck it out of the way - that way if you ground the spanner while you're taking the red off you wont get a short circuit and much amusing sparking and arcing. Remove the old battery. Fit the new battery and attach the red lead first for the same reasons. Make sure the terminals are nice and tight but don't go overboard. Job done. Thumbs Up
Eas85
PostPosted: 17:43 - 16 Oct 2012    Post subject: Reply with quote
First off, attached is a pic of my current battery that's in the bike...(if it works)
went halfords and got a M6 010, YTX 9-BS (link below). It says on the side of the box Yamaha XJ series 01/92-01/96, so naturally I assume it's for my bike....completely different shape to the one in my bike, the current one is tall, this new one is short and wide.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_264063_langId_-1_categoryId_246903
although if you click on the fitment guide on the halfords site as per link below it says: XJ 600 diversion (92-02) YT12B-BS M6 019, I was gonna get this one but on the box it doesn't say XJ 600 at all.
https://www.halfords.com/wcsstore/libraries/document/motorcyclebatterycrl2010.pdf
So really unsure what to do now, obsiously need to take this one back, should I get the one I was originally gonna get, or get one similar to what's already in there?
weasley
PostPosted: 17:54 - 16 Oct 2012    Post subject: Reply with quote
Do you have a Diversion or the pre-Diversion XJ600 (aka "Seca II", but not in the UK)?
Islander
PostPosted: 18:51 - 16 Oct 2012    Post subject: Reply with quote
The battery type you need is a CB12A-A or a YB12A-A equivalent Thumbs Up
Eas85
PostPosted: 21:09 - 16 Oct 2012    Post subject: Reply with quote
I'm pretty sure it's pre-diversion
Eas85
PostPosted: 21:29 - 16 Oct 2012    Post subject: Reply with quote
Unsure whether I should just get an exact copy of the one that's currently in the machine,
https://www.ebay.co.uk/itm/Yamaha-XJ-600-1989-1992-12N12-4A-1-CB12A-A-Lead-Acid-MF-Battery-/140651385586?pt=UK_Motorcycle_Parts&hash=item20bf79d2f2
Or should I try and find a decent one by motobatt for instance like Covent.garden said, The info on the motobatt website don't make much sense, in their guide it says mbt9xu is the correct model for XJ600 Seca II but I looked at it and again is the wrong dimenions.
Edit:
On the same ebay store, I think this is the motobatt model that would fit my bike...
https://www.ebay.co.uk/itm/MotoBatt-QuadFlex-MB12U-Battery-Yamaha-XJ-600-1984-1992-/180910328327?pt=UK_Motorcycle_Parts&hash=item2a1f188a07
Islander
PostPosted: 22:06 - 16 Oct 2012    Post subject: Reply with quote
"This particular MotoBatt QuadFlexâ„¢ battery is a MB12U to fit a Yamaha XJ 600 (1984-1992), replacing the convential battery part numbers CB12A-A, 12N12A-4A-1, CB12AL-A2, CB12A-B, CB12C-A, 12N12C-4A-2, CB12AL-A2. "
Yes, that's a direct equivalent (see the text I've made bold above).
JackDaniels
PostPosted: 07:35 - 17 Oct 2012    Post subject: Reply with quote
Those motobatt batterys are great, i was having problems with my hornet but since fitting a new battery all my troubles have gone.
THEORY TEST - PASSED! - 02-08-11 CBT Passed - 09-08-10 MOD 1 - 09-08-2011 - MOD 2 - 28-09-2011
2006 Yamaha JOGRR>2010 Yamaha Ybr>1995 Honda CB400 Superfour >2005 Honda hornet>1999 Suzuki Bandit 1200 > 2002 BMW R1150GS > 2013 Tiger Sport 1050 > 2007 GSXR 1000 > 2005 GS500E
The last post was made 13 years, 126 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 127.48 Kb
