| tahrey |
 tahrey World Chat Champion
 Posted: 17:39 - 15 Oct 2012 Post subject: where to buy special style bolts? |
Riiight
Taking engine off CG frame, the final rear mount bolt was a complete fecker. Managed to destroy a 12mm socket and a couple adaptors for my torque wrench and breaker bars before it was persuaded to come free with a lot of WD40, application of a 1600w heat gun for 10+ minutes, and a lot of hammering and battering.
Suffice to say it's all chewed up and nut doesn't even really go on any more. I need a new one...
But where the bloody hell do you get them? Anywhere I've tried to look this style up I've got nothing.
M6, 12mm hex-head bolt, 110~120mm long, only has thread on the last 10~15mm or so, fairly close pitch thread (not a coach bolt), and it seems to flare out to about M8 near the head for a similar length as the thread. Plus an M6, 12mm nut to go with.
About to check with my friendly neighbourhood bike dealer/service place and see if they happen to have any generic ones in, I'm hoping it's not Honda stealership only though, as it'll really hold me up getting anything else done. I'm already about to be about twenty quid in the hole for replacement and/or upgraded tooling, because some of the bits that got broken are going to be quite essential for the next stages, never mind putting the bike back together.
Me & mum's partner had a good pore through the Machine Mart, Toolstation, Screwfix etc catalogues he had scattered about and couldn't find anything suitable - any bolt long enough was then too thick. Halfords look pretty useless on this front as well.
Ta for any help  |
| Pete. |
 Pete. Super Spammer
 Posted: 17:43 - 15 Oct 2012 Post subject: |
A 12mm head bolt would be an M8 thread, not M6. Can you check that before continuing? Measure across the thread tops.
Or post a photo of the knackered bolt (so we can all have a laff)  ____________________ a.k.a 'Geri'
| Joenitro |
 Joenitro Spanner Monkey
| Pete. |
 Pete. Super Spammer
 Posted: 17:51 - 15 Oct 2012 Post subject: |
I just checked my stock and the longest M8 I have is 93mm. ____________________ a.k.a 'Geri'
| WillOdling |
 WillOdling Nova Slayer
 Posted: 19:20 - 15 Oct 2012 Post subject: |
| _Iain_ |
 _Iain_ Banned
 Posted: 20:05 - 15 Oct 2012 Post subject: |
Go to honda dealership, ask for bolt. They'll say they havent got it, but will have it in 24hrs. You'll probbably pay about £3.
Have done this many times with YBR bolts & GS bolts. ____________________ Please be aware that the above post may be full of complete nonsense.
| Raffles |
 Raffles World Chat Champion
| kramdra |
 kramdra World Chat Champion
| Pete. |
 Pete. Super Spammer
 Posted: 07:56 - 16 Oct 2012 Post subject: |
If you can fit it you should fit it. Sure, the engine won't fall out for lack of a single bolt (I've seen several spine frame bikes with the top triangle engine mount totally missing) but it will cause flex in the frame and extra vibration (even if you can't feel it) which will be bad for the engine and other parts of the bike, like the exhaust. ____________________ a.k.a 'Geri'
| tahrey |
 Posted: 13:25 - 16 Oct 2012 Post subject: |
Thanks chaps. I was hoping there was somewhere I could stop in at on the way home, so I could get the job sorted quicker, but it looks like this stuff is rather more specialist than the plain bolts I got hold of to hold the ignition coils onto my old Megane... (the silly sods used spline-heads originally so yeah, chewed to hell getting them out)
I figure I may as well just go order from the dealer at this point, despite them not being my most favourite people owing to their habit of locking up and turning the lights off at about 5.30 despite their opening hours reading as "until 5.45". Anything that could be posted or got off ebay will take even longer to turn up.
And in any case, thanks to having to go replace the broken tools and do a few other errands last night, I didn't then have the time to head across town and attack the business of removing the head and barrel from the old bottom end, so I'm already held up. I guess I won't have it back running on the road before the end of the week at this rate now
For what it's worth, my assumptions of what it is come from direct measurements with a brand-new metal ruler.
Used a 12mm spanner and socket to get it off;
the total length of the thing from top of the hex head to the end of the thread is 115mm;
the thread diameter is exactly 6mm;
there's roughly 13mm (I guess actually a half inch?) of thread at the bottom - of which only half is actually used (the rest is rusted to hell);
and I didn't measure the width or length of the flared bit because I only noticed quite a bit later. Didn't measure the thread pitch either because no bugger ever specifies it and I was going to have to check it visually anyhow.
At a guess, it started life as a 120mm, M8 bolt, but was then machined to be thinner in the middle and at the business end, and had a half centimetre shaved off the total length for good measure? |
| Pete. |
 Pete. Super Spammer
 Posted: 17:35 - 16 Oct 2012 Post subject: |
Very strange. I don't believe I've ever seen a M6 bolt with a 12mm hex head. ____________________ a.k.a 'Geri'
| Raffles |
| tahrey |
 Posted: 17:44 - 16 Oct 2012 Post subject: |
Probably why I need to get it direct from the OEM then!  |
| Pete. |
 Pete. Super Spammer
 Posted: 17:50 - 16 Oct 2012 Post subject: |
I'd still lke to see a picture of the offending item. ____________________ a.k.a 'Geri'
| stavros |
 stavros Borekit Bruiser
| tahrey |
| tahrey |
| kestrel |
 kestrel Nearly there...
| Pete. |
 Pete. Super Spammer
| Raffles |
| tahrey |
 Posted: 10:23 - 22 Oct 2012 Post subject: |
| Raffles wrote: | Decyphering the original post, I concluded that the bolt required would be a M8 x120. I have a number of these bolts and offered to send one to the OP. He didn't respond to my offer. |
Sorry Raffles - nothing personal, I just figured it might be quicker from the dealer (hmm, sort of. just.) and it'd be worth putting a brand new one in anyway. Otherwise I'd have been all over your generosity!
It also appears you were almost bang on the money...
| CHR15 wrote: | its been a while since ive had the engine out my cg, but theres no way its m6.
its more like m10x1.25 |
Aha, now, I have actually taken a load of pics I was going to upload and ask for comments on (as well as others featuring the crankcase / top and bottom of barrel / head, cylinder liner etc), but it does seem to have come out that the closest match is - roughly - m8 x 120mm (I presume the "m" denotes typical "machine screw/bolt" pitch, whatever that is?).
It's rather hard to tell when measuring the thing up with a ruler rather than calipers or the like, mind (note to self: nip into Aldi/Lidl and see if they have any left from the special offer they were doing on various tools*). Depending how I position and look at it, I seem to get anything from just over 6mm to almost 7.5mm wide ... but never 8mm?!
(* their 4-way pick set and 3-way plier set have already done me proud on this job, a fiver or so well spent)
The flared part is closer to 10mm wide.
And the overall length from tip to tip is 115mm. Actual bolt minus the hex-head is a smidge under 110.
Also, the things appear to be made out of depleted friggin' uranium. There's still one that is - bafflingly - stuck in one of the new bottom end's through-holes, and I've destroyed several regular drill and dremel bits trying to get it out, after working my way through about 3 dremel diamond cutting wheels (two shattered from over enthusiasm, one worn down to almost nothing when I learned some self control) chopping the stub flush with the block. Blowtorching it to hell, soaking it with penetrating oil, etc, has done nothing. Luckily it's one of the front-mount bolts, so the engine is held in reasonably firmly with three for now...
Would it be a better idea to get some hardcore bits and try drilling the fecker out myself (with a good quality, borrowed Ryobi mains-powered hammer drill, at low speed, with a water pistol squirting South Staff's finest liquid coolant on it all), or find somewhere (where?) to do it for me after carefully riding over there? |
The last post was made 13 years, 163 days ago. Instead of replying here, would creating a new thread be more useful? |
