Bike losing power
milesness
PostPosted: 08:23 - 16 Oct 2012    Post subject: Bike losing power Reply with quote
Hi,
On my YBR 125, if I'm going along and it goes above about 7k revs, I just lose power, as if you just suddenly let go of the accelerator.
The revs go down and either go down to 0 RPM and the engine cuts out, or the power comes back at about 3k RPM.
It's a fault put in there by the people down the local bikeshop ¬_¬ as my friend had the same problem when he took it back from them.
Miles
Robby
Dirty Old Man
PostPosted: 08:28 - 16 Oct 2012    Post subject: Reply with quote
If the local bike shop causes the problem, get them to fix it.
It is likely to be electrical, quite possibly a loose connection that is getting shaken off at high rpms. Check the battery terminals, and any point where the wiring loom earths onto the frame.
symonh2000
PostPosted: 09:18 - 16 Oct 2012    Post subject: Reply with quote
What year is your YBR?
Earlier ones have Carbs, later fuel injection.
Sounds more like a fuelling issue to me, if you have an injected bike a fuelling issue is likely to make the fuel injection warning light come on.
Four strokes is two strokes too many.
milesness
PostPosted: 08:50 - 17 Oct 2012    Post subject: Reply with quote
I don't trust them if they make the exact same problem my friend had. I'll check that thanks.
It's a 2005 so has carbs.
covent.gardens
World Clap Champion
PostPosted: 09:10 - 17 Oct 2012    Post subject: Reply with quote
How did your friend fix his?
What was your bike in there for? This may give a clue as to what they touched.
milesness
PostPosted: 12:14 - 17 Oct 2012    Post subject: Reply with quote
He got his fixed at another local place, a genuine one this time, apparently he's retired but still fixes bikes. Sadly I can't get a hold of him as I've called them loads of times but they don't answer.
It was to clean out the carbarettur. I'm pretty sure the guy does tamper with bikes because my friend also said the guy put in a worn out spark plug claiming it was new, and it stopped working a few months after.
flumpy7
PostPosted: 12:50 - 18 Oct 2012    Post subject: Reply with quote
Forget all the he said she said stuff
The carbs were looked at by the garage and now your bike doesnt work.
Demand its sorted pronto.
For what its worth, i,d be looking at float height and manifold leaks.
2012 Sinnis apache
The last post was made 13 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.22 - MySQL Queries: 13 - Page Size: 51.71 Kb
