honda h100a
fatjack93
PostPosted: 17:31 - 17 Oct 2012    Post subject: honda h100a Reply with quote
Hi I'm new to this but having problems with my honda h100a the stator generator was producing to much elec and so I bought a new/second hand one and fitted it now it won't start has a weak spark I boughht new spark plug/regulators rectifiers etc and juist a faint spark won't start any ideas???? Ta
cb1rocket
PostPosted: 21:36 - 17 Oct 2012    Post subject: Reply with quote
put the old one back in.
by saying too much electric, i assume you mean over charging?
if so the regulator is shot and you replaced the wrong component, so its not the stator
st3v3
PostPosted: 15:02 - 18 Oct 2012    Post subject: Reply with quote
What about the little woodruff key bit thing?
symonh2000
PostPosted: 15:06 - 18 Oct 2012    Post subject: Reply with quote
If that was missing the flywheel would turn in relation to the crank and the timing would be all to cock.
Although if unless it was hardly spinning then there would still be some output.
Four strokes is two strokes too many.
J.M.
PostPosted: 15:45 - 18 Oct 2012    Post subject: Reply with quote
This.
As a general rule of thumb*, running at ~5k RPM, warm engine:
>14.5v = reg/rec problem
<13v = stator problem
*It's only a rule of thumb. I had <13v but it was a problem of a poor connection between the reg/rec and the electrical system rather than either of the components.
2004 R1 & 2018 XSR900
st3v3
PostPosted: 21:26 - 18 Oct 2012    Post subject: Reply with quote
On my bike one morning it had 'slipped' a tiny bit and the bike 'worked' but wouldn't actually start.
cb1rocket
PostPosted: 22:33 - 18 Oct 2012    Post subject: Reply with quote
This.
you know this bike is 6v Wink
J.M.
PostPosted: 23:14 - 18 Oct 2012    Post subject: Reply with quote
Embarassed
symonh2000
PostPosted: 07:05 - 19 Oct 2012    Post subject: Reply with quote
When my RXS100 had a shot regulator the battery was getting 20V
That was before I did the 12v conversion.
The last post was made 13 years, 142 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 61.47 Kb
