Brake pad replacement
EazyDuz
PostPosted: 11:24 - 18 Oct 2012    Post subject: Brake pad replacement Reply with quote
Can anyone give any tips on removing the caliper and changing brake pads? Pistons seem fine just the pads are a bit knackered, so i was wondering if i should clean up the caliper as well. How would i go about removing the pistons and cleaning them up, or is that not needed?
janner_10
PostPosted: 11:55 - 18 Oct 2012    Post subject: Reply with quote
On all the bikes I've had - removed pin - take out old pad - push piston back - insert new pad, with a bit of copper grease on the reverse.
Only you can judge if you need to clean anything as we can't see it.
Literally a 20 minute job. Get a manual.
TQ
PostPosted: 12:08 - 18 Oct 2012    Post subject: Reply with quote
If you do decide to clean up the pistons you've got two choice the quick, easy but not that effective way or the harder, slower but much more effective way.
You can take the pads out and clean the outside of the pistons with some solvent then push them back into the caliper and pump them back out using the brake lever (as far as you dare without them popping out!). Repeat process and it'll help if you breaks are sticking (at least it did when mine were before I followed the more in depth procedure below)>
The second method involves taking the caliper off the bike and popping the pistons out. I did this using a compressed air line blown down the hole where the banjo bolt would normally be and a bit of rag stuffed between the pistons so they don't smash into each other. Once you've done that you can give them a proper clean up and replace the seals before re-assembly (at this point I painted mine as well). It's not a hugely hard job as long as you're careful and a haynes manual will certainly help.
First Bike :Gilera DNA 50 | Second: Imported 1989 NSR125
Third: 1998 Yamaha XJ600N | Currently: 1999 Yamaha FZS600
Islander
PostPosted: 12:12 - 18 Oct 2012    Post subject: Reply with quote
Unless you've been having problems, I'd leave the pistons alone. Just remove the old pads, use some brake system cleaner to remove any built up crap on the caliper and fit new pads.
If you're unsure how to change the pads then get a manual for the bike - it'll be an investment anyway. Thumbs Up
Ichy
PostPosted: 12:14 - 18 Oct 2012    Post subject: Reply with quote
If the pistons look fine and the brakes are working ok then just give them a good clean to remove any build up of dirt. Don't take them apart unless you need to, not worth the effort and certainly not worth the risk of getting it wrong.
EDIT: yeah, what Islander wrote Laughing
The last post was made 13 years, 138 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 44.24 Kb
