Can't find me restrictors
numark1
Scared of girls
PostPosted: 15:32 - 29 Oct 2004    Post subject: Can't find me restrictors Reply with quote
Had a look at where i thought the 33bhp restrictors would be just to see what they looked like as my bike is unrideable at the mo. Took some pics
https://picserver.org/view_image.php/H23Z02178E8Y/picserver.jpeg
and
https://picserver.org/view_image.php/95P8N2T6GG79/picserver.jpeg
anyone know where they are??
Thanks
cagiva gezzer
PostPosted: 15:44 - 29 Oct 2004    Post subject: Reply with quote
Would be the other side of the carbs.
numark1
Scared of girls
PostPosted: 15:47 - 29 Oct 2004    Post subject: Reply with quote
so i would have to take the carbs off to reach??
PostPosted: 15:49 - 29 Oct 2004    Post subject: Reply with quote
Yup, take the carbs off and they're right there. Thumbs Up
numark1
Scared of girls
PostPosted: 16:20 - 29 Oct 2004    Post subject: Reply with quote
is it hard?? do i need any special tools??
jay12329
Dr. Evil
PostPosted: 16:42 - 29 Oct 2004    Post subject: Reply with quote
You should have everything you need in the tool kit that came with the bike.
J
numark1
Scared of girls
PostPosted: 17:35 - 29 Oct 2004    Post subject: Reply with quote
Shocked toolkit - bike??? didnt get one with it
PostPosted: 17:38 - 29 Oct 2004    Post subject: Reply with quote
Ah, normally would come with a small tool kit under the seat, basic screw driver, allen key and a couple of spanners. You won't need more than basic tools to take the carbs off and put them on again.
loply
PostPosted: 19:50 - 29 Oct 2004    Post subject: Reply with quote
Get a manual for the bike from ebay, it will explain how to remove the carbs.
Also, check if the throttle bodies rise fully when you open the throttle?
Claud 14.7 to 1
PostPosted: 20:14 - 29 Oct 2004    Post subject: Reply with quote
If you mean the slides, then they wont move unless the bike's engine is running: They are CV-type carbs.
With the tools you have used so far you will be able to take those carbs off. Probably just need a long philips screw driver to get to the underside of the carbs (where they connect to the intake ports), to undo some screws that hold jubilee clips, These clips holding the carbs to the rubber shoots and to the intake ports.
Get a manual, it will make the job easier.
Tip use a bit of lube, on the carb rubber shoots (you will see what I mean when they are off) when you come to putting them back on. It will make them slide easily back into the intake ports. Instead of spending ages trying to push the carbs back on, like I did at first...
Only use a very small amount.
What bike is that mate?
numark1
Scared of girls
PostPosted: 00:08 - 30 Oct 2004    Post subject: Reply with quote
gsxr400 a manual would only be useful if i could read japanese tho Shocked
Claud 14.7 to 1
PostPosted: 00:43 - 30 Oct 2004    Post subject: Reply with quote
www.400greybike.co.uk
The gatekeepers of 400cc knowledge. Thumbs Up
tony532
PostPosted: 21:39 - 30 Oct 2004    Post subject: Reply with quote
why are you removing the restrictors?
has your 2 years cat a2 restriction come to an end?
Laura
Playboy Bunny
PostPosted: 15:37 - 31 Oct 2004    Post subject: Reply with quote
Probably not lol.
Good girls ride motorcycles bad girls thrash them.
numark1
Scared of girls
PostPosted: 18:17 - 31 Oct 2004    Post subject: Reply with quote
sorry 2 year or 2 month?? \0/
I just want to see what they look like Thumbs Up
matthew_gordon
PostPosted: 17:35 - 04 Nov 2004    Post subject: Reply with quote
I have done this to mine, just to see what they look like aswell Smile
Your carbs are connected to your engine by 4 reasonable large rubber tubes.. There will be 4 jubilee clips on the rubber tubes, loosen them (with a screwdriver or allen key) and 'jiggle' your carbs off.. and there you have it.. 4 shiny disks!
If you just want to see them.. Look down one of the carbs, using your finger slide the first cover (about 2 cms down) and accelerate the throttle. You will see them, they will be disks with holes in. Thats what you need to get to if you want them out. Smile
The last post was made 21 years, 359 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.81 - MySQL Queries: 13 - Page Size: 88.29 Kb
