Problem with throttle cable
GZXR400
PostPosted: 21:54 - 18 Oct 2012    Post subject: Problem with throttle cable Reply with quote
Hi im having some problems with the throttle on my bike
if the cable is tightend as it should be 2-3mm slack the throttle revs when the handlebars are fully locked one way.
When i first got the bike it would rev like mad when it was tightend up on the touch of the throttle
Is down to poor routing of the cable ?
The bike is a zxr 400 L and i cannot find any info regarding the throttle routing
any help would be greatly appreciated thank you
Islander
PostPosted: 22:09 - 18 Oct 2012    Post subject: Reply with quote
Yep. Check the cable route - it'll be binding somewhere. Thumbs Up
GZXR400
PostPosted: 22:31 - 18 Oct 2012    Post subject: Reply with quote
i dont know what the correct cable route is though
will incorrect cable route cause a sticky throttle ?
Islander
PostPosted: 23:07 - 18 Oct 2012    Post subject: Reply with quote
Yes. If it's being trapped then it will. A manual will show you the correct cable route - have a dig through the sticky posts at the top of the workshop page. Thumbs Up
GZXR400
PostPosted: 06:19 - 19 Oct 2012    Post subject: Reply with quote
looked in the manual cant find anything about it
Islander
PostPosted: 10:07 - 19 Oct 2012    Post subject: Reply with quote
Did you look in the service manual (haynes or similar) rather than the owner's manual?
Srengam
PostPosted: 12:31 - 19 Oct 2012    Post subject: Reply with quote
Also,
check your throttle control hasn't moved down your bar at all. I had this just last week, bike would rev up on full right lock. The whole control part had shifted down the bars by about an inch, pushed it back and it's fine now.
Suzuki GSX600F Katana (1997)
GZXR400
PostPosted: 17:46 - 19 Oct 2012    Post subject: Reply with quote
they dont make a haynes manual for my bike
im pretty sure the throttle control hasent moved as it clicks together and a tab goes into the bars
Islander
PostPosted: 17:59 - 19 Oct 2012    Post subject: Reply with quote
2 minutes of Google searching and:
https://adf.ly/2317382/https://www.blackbears.ru/manual/files/Kawasaki_ZXR400H_Service_Repair_Manual.zip
That's the base manual for the series - there's a supplement out there too.
Failing that, just use your eyes. You should be able to see if it's running freely.
GZXR400
PostPosted: 18:11 - 19 Oct 2012    Post subject: Reply with quote
its not mentioned in the manual so il have to try and see if i can re route it
GZXR400
PostPosted: 11:23 - 25 Oct 2012    Post subject: Reply with quote
Hi took the fuel tank off and have access to the throttle cables, Its 2 cables and they go through a hole at the front to the right of the steering, There are also a few other wires, have tried to seperate the other cables the best i can.
When i turn the handlebars to the right the cables are bending round and hitting the frame where the cable goes back through the frame hole.
The throttle becomes sticky and the engine revs when the handlebars are turned to the right.
Im stuck now with what to do i dont know if the cables are going through the correct frame hole, i have oiled both cables at the carbs,
any help/suggestions would be appreciated thanks
Islander
PostPosted: 13:23 - 25 Oct 2012    Post subject: Reply with quote
The cable routing is in the first section of the manual I linked.
Islander
PostPosted: 15:28 - 25 Oct 2012    Post subject: Reply with quote
lol Thumbs Up
The last post was made 13 years, 361 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.92 - MySQL Queries: 15 - Page Size: 91.94 Kb
