Any Vauxhall mechanics?
robs321
PostPosted: 14:41 - 20 Oct 2012    Post subject: Any Vauxhall mechanics? Reply with quote
I have an 07 Vivaro 1.9 CDTi. Its just had a service as the spanner symbol came on and started counting down and then the symbol with the car and spanner in it, came on. My trusty mechanic cant reset the lights. His auto data says to turn on ignition to position 2, hold down accelerator pedal and pump the brake fully 3 times. This doesnt work and hes asked about but this seems to be the only advice available. If anyone can help id be greatfull!
cheers
carvell
Scuttler
PostPosted: 15:42 - 20 Oct 2012    Post subject: Reply with quote
That is the correct procedure - try it again, in this order:
Ignition off
Accelerator to the floor
Ignition on
Still holding the accelerator, pump the brake 3 times (try 5 if that fails)
Yamaha TDM 850
robs321
PostPosted: 16:10 - 20 Oct 2012    Post subject: Reply with quote
Ignition off
Ignition on
Nope that dont work! If you hold the button on the right hand stalk in and turn on the ignition that makes the dash change but no one seems to be able to do owt with that either!
carvell
Scuttler
PostPosted: 16:18 - 20 Oct 2012    Post subject: Reply with quote
You are talking about the spanner symbol in the odometer aren't you?
If there is a symbol with a picture of a car with a spanner on it elsewhere on the dash then this (IIRC) is the immobiliser. That should go out when you start the engine. It has always illuminated.
Yamaha TDM 850
carvell
Scuttler
PostPosted: 16:19 - 20 Oct 2012    Post subject: Reply with quote
https://www.askthemechanic.co.uk/images/Vauxhall%20dash.jpg
The symbol that arrow is pointing to is the immobiliser, nothing to do with car servicing.
Yamaha TDM 850
robs321
PostPosted: 16:50 - 20 Oct 2012    Post subject: Reply with quote
after 18k miles as you turned on the ignition a spanner came up and a mileage reading from what i remember 1800 miles, this was counting down to zero each time you turned on the ignition. When it got to zero that light in your pic came on! That is not the dash I have BTW!
[edit] Just looked at the handbook and that light you are pointing at means the service on my van not immobilser
My (dusty) Dash!
https://i8.photobucket.com/albums/a12/robs321/2012-10-20_17-00-37_369_zps92731365.jpg
carvell
Scuttler
PostPosted: 17:10 - 20 Oct 2012    Post subject: Reply with quote
Fair enough! Bit odd that Vauxhall have changed the meaning of that light - doesn't seem like cricket!
Yamaha TDM 850
carvell
Scuttler
PostPosted: 17:17 - 20 Oct 2012    Post subject: Reply with quote
Looks like it still may well be to do with engine electronics.
https://www.vauxhall.co.uk/content/dam/Vauxhall/Europe/united_kingdom/nscwebsite/uk/00_Home/Owner_Services/owners_manuals/vivaro/VivaroOwnersManual_Jan07.pdf
See page 104 in there.
Yamaha TDM 850
robs321
PostPosted: 17:35 - 20 Oct 2012    Post subject: Reply with quote
See page 105!
cheers
bombom
PostPosted: 17:46 - 20 Oct 2012    Post subject: Reply with quote
try holding in that dusty button on your dash, press and hold both clutch and accelerator then turn on ignition, , the mileage bit should go to four lines (----) then relase button.
was like that on my meriva anyways
Current: 97 zx6r f3
Previous: suzuki gsf400 bandit
robs321
PostPosted: 17:47 - 20 Oct 2012    Post subject: Reply with quote
Ill try that!
cheers
bombom
PostPosted: 17:58 - 20 Oct 2012    Post subject: Reply with quote
lol sorry i ment brake and clutch not accelerator
Current: 97 zx6r f3
robs321
PostPosted: 18:20 - 20 Oct 2012    Post subject: Reply with quote
ill try that now Wink
robs321
PostPosted: 18:27 - 20 Oct 2012    Post subject: Reply with quote
no joy there! Sad
Tarmacsurfer
PostPosted: 18:34 - 20 Oct 2012    Post subject: Reply with quote
I had always wondered what became of the generation that grew up with cheat codes on the SNES, it looks like they all started designing electrics for the automotive industry Laughing
I'm immortal. Well, so far.
robs321
PostPosted: 19:09 - 20 Oct 2012    Post subject: Reply with quote
if i hold that black button in the dash starts flashing and goes through a sequence and beeps constantly. if you let go then press the button again it all stops! shall i just stick tape over them! Laughing
nowhere.elysium
The Pork Lord
PostPosted: 19:15 - 20 Oct 2012    Post subject: Reply with quote
https://imgs.xkcd.com/comics/nintendo_surgeon.png
Nb
PostPosted: 20:02 - 20 Oct 2012    Post subject: Reply with quote
The car with the spanner light means it's needs to be plugged into a proper diagnostic machine for a full scan.....there's a problem somewhere.
You won't put the light out by pressing buttons on the dash, although you might by disconnecting the battery for a few mins.
robs321
PostPosted: 22:46 - 20 Oct 2012    Post subject: Reply with quote
You havent really been following the thread have you? These are the service lights, the small spanner comes on to let you know a service is getting near and the other one comes on as a service is needed. The van has been on a snapon and a Launch diagnostic machine and both showed no fault codes in the Ecu! The van does not have a problem, it just needs some buttons pressing which i really dont want to pay a main dealer to do!
Nb
PostPosted: 23:45 - 20 Oct 2012    Post subject: Reply with quote
I read fine, and work on vivaros every fucking day unfortunately.
You have one service light, the spanner in the center display.
The other lights are to do with engine emissions, and engine electronics/immobiliser.
You dont always get codes from these vans or cars using certain diagnostic tools, especially snapon...
Try it on Tech2 or Opcom/vauxcom or even Bosch kts, sometimes it helps to go in under renault trafic or nissan primastar.
There may be an oil quality that needs to be reset.
Im only trying to help and sometimes i wish i didnt bother.
https://img.photobucket.com/albums/v678/blazebrown/Untitled-1.jpg
Manual here if anyone wants one-
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&sqi=2&ved=0CB8QFjAA&url=http%3A%2F%2Fwww.vauxhall.co.uk%2Fcontent%2Fdam%2FVauxhall%2FEurope%2Funited_kingdom%2Fnscwebsite%2Fuk%2F00_Home%2FOwner_Services%2Fowners_manuals%2Fvivaro%2FVivaroOwnersManual_Jul06.pdf&ei=zC2DUMj8A-nJ0AWA64HYBA&usg=AFQjCNFHzcOxPfjCxYamAfwMOSMlvQD__Q&cad=rja
robs321
PostPosted: 07:58 - 21 Oct 2012    Post subject: Reply with quote
Well thats me told Wink
They had tried going the nissan and renault route but still nowt has shown or worked. I was told disconecting the battery maybe the way to go!
drzsta
PostPosted: 09:01 - 21 Oct 2012    Post subject: Reply with quote
Hi I have the same problem on my 08 2.0 vivaro. After it counted down to service date with spanner it then puts up the spanner with car if you havnt got it serviced in time. Personally I just changed the oil myself at 18000 then this came up Neutral
recman
PostPosted: 13:25 - 21 Oct 2012    Post subject: Reply with quote
Me too. Sad
Nb
PostPosted: 14:42 - 21 Oct 2012    Post subject: Reply with quote
qb78 wrote:
Me too. Sad
Unlucky lol Wink
binge
Emo Kiddy
PostPosted: 17:06 - 21 Oct 2012    Post subject: Reply with quote
Not read the thread fully, but just for the record. To reset the service light on these correctly, you need to hold down the accelerator and pump the brake 3 times. But on the third pump, you need to hold it down until the indicator resets. Thumbs Up
The last post was made 13 years, 209 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.30 Sec - Server Load: 2.45 - MySQL Queries: 13 - Page Size: 128.18 Kb
