FZ6 Fork surfaces.
wagontrain
PostPosted: 19:54 - 20 Oct 2012    Post subject: FZ6 Fork surfaces. Reply with quote
My FZ6 [ABS model], has areas of corrosion on both silver finished fork legs.I know yamaha bikes have a track record of these types of problem, but the Bike is a well looked after 2010 model with just 8k on the clock since new.
Spoke to Yamaha about this but they intimated this was to be expected & were not interested as the Bike was now outside the warranty.
The AA agree with me that in these circumstances the corrosion appears to be very premature on a late model Vehicle in its otherwise immaculate condition & low mileage.The AA can prepare a report at a cost but i do of course have the option of removing the front wheel /mud guard & prepping /resurfacing the lower fork legs myself.If i take this option has anyone out there used a Hammerite or other similar product that would do a reasonable fix on it.
It would also be interesting to know if other late model FZ6 owners have had the same problems & how they were resolved. Neutral Neutral
Dave H.
PostPosted: 19:58 - 20 Oct 2012    Post subject: Reply with quote
It is one of the areas exposed to the brunt of rain and road salt.
You can probably get them powder coated, but they are only fork legs. I could photo mine but they might make you cry/break your screen Laughing
wagontrain
PostPosted: 20:23 - 20 Oct 2012    Post subject: Reply with quote
Hi PADDY,
They may only be fork legs but i'm the old fashioned type who thinks it's a good idea to keep on top of corrosion before it takes a hold. I owned an FJ 1200 for 20 years that was sold with the same unmarked fork leg surfaces even though I had ridden in some severe winter conditions on it.
Modern Bikes are more technically sophisticated but are they as well finished ?. Wink
Dave H.
PostPosted: 20:40 - 20 Oct 2012    Post subject: Reply with quote
Newer bikes, some seem to have real cheap paint finishes Sad
temeluchus
PostPosted: 21:53 - 20 Oct 2012    Post subject: Reply with quote
To be fair the FJ1200 was a top of the range model, the FZ6 I suspect is not.
0l0dom0l0
PostPosted: 22:01 - 20 Oct 2012    Post subject: Reply with quote
Best thing, if you're really picky is to remove the forks, take them apart and send the legs off to be powder coated.
Might as well do new seals and oil while you're there too.
I can't say I've suffered corrosion on mine, and thats an 06 with 12k miles now. Although I do cover with WD40 vigorously! (making sure not to get the brake discs of course).
PostPosted: 00:35 - 21 Oct 2012    Post subject: Reply with quote
Are they lacquered? I ask because I was told a lot of the problems with corrosion on engine and other metal surfaces are where moisture seeps under lacquer and sits there.
Triumph Trophy Launch Edition
Bezzer
PostPosted: 11:15 - 21 Oct 2012    Post subject: Reply with quote
Lacquer is only a problem when you apply it to unkeyed bare metal as it won't adhere that good, it's fine on paint.
As said hammerite smooth can give a good finish though it is better from a rattle can, silver car wheel paints are also good, I did mine a darker grey and then lacquered which gives a more durable finish.
https://i561.photobucket.com/albums/ss60/mickcbr1100/bolt%20sizes/HPIM0221.jpg
0l0dom0l0
PostPosted: 12:00 - 21 Oct 2012    Post subject: Reply with quote
That's quite a nice colour above actually, what's that classed as?
Bezzer
PostPosted: 15:29 - 21 Oct 2012    Post subject: Reply with quote
It's Halfords Anthracite wheel paint. Been on about 18 months and holding up well. Took the legs out to do a proper sanding down and prep job.
https://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_764697_langId_-1_categoryId_165495
The last post was made 13 years, 162 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 68.71 Kb
