The cost of running a bike
rumbataz
PostPosted: 12:31 - 21 Oct 2012    Post subject: The cost of running a bike Reply with quote
I'm interested in how much a motorcycle costs to run. It's more about the costs of maintaining and riding the bike rather than things like insurance that i'm interested in.
For example, what is the typical fuel economy of the different classes of motorbikes? What about servicing and servicing intervals. I understand that this depends on many factors but just a typical set of running costs over a 12-month period would be useful.
J.M.
PostPosted: 12:49 - 21 Oct 2012    Post subject: Reply with quote
I get a student-research feeling about you...
...and I'm pretty much all of your questions can be answered through research.
It varies between every bike too and how well you take care of it. How hard you ride, how economically you ride, where you ride, etc.
Edit: you don't even state how many miles; the biggest factor arguably.
2004 R1 & 2018 XSR900
neil.
PostPosted: 13:12 - 21 Oct 2012    Post subject: Reply with quote
Go on then, I'll bite.
I ride a CBF125.
Fuel economy is 120mpg. Check my Fuelly link in my signature below for the proof.
Servicing costs are quite low - I would very roughly estimate budgeting an average of about £30 between each service interval, taking into account consumables such as engine oil, air filters, spark plugs, tyres, chain/sprockets, brake pads, tool purchases and other bits I need etc. Of course all those things aren't replaced every service so I've averaged the cost out. I do my own servicing so there is no labour cost involved. I'd expect to pay £100-£150 per service at a dealership, maybe more if lots of work needs doing. My bike's service interval is every 2'500 miles but different things need doing at 5'000 and 7'500 miles respectively.
I ride 300 miles a week commuting with a little bit on top for other stuff, errands etc. That means a service every 8 weeks/2 months-ish and I do everything in the schedule.
.Chris.
PostPosted: 13:13 - 21 Oct 2012    Post subject: Reply with quote
You need to be a bit more specific about what sort of bike you're after. Bikes can be anything from extremely cheap to quite expensive to run.
Fuel consumption can be anything between 120mpg on some 125s, and less than 30mpg on some large V-twins (or bigger 2 strokes).
Tyres can range from £25 for a skinny Chinese crossply to almost £200 for a big fat sports tyre. Tyre life can range from a couple of thousand on the rear of a hard-ridden Hayabusa to 10k+ for hard compound tyres on a 125.
Servicing tends to be required more frequently than on modern cars - many bikes fall within the 2k-6k bracket. Many people save money by doing things like oil changes at home. A major service at a dealer can run to several hundred pounds, particularly if it includes a valve clearance check/adjustment.
It'd really be better to figure out what sort of bike would suit your intended usage, then speak to other owners.
Chris
1985 Kawasaki Z550F
rumbataz
PostPosted: 13:16 - 21 Oct 2012    Post subject: Reply with quote
Apologies, guys. I'm looking to get a 125 bike after I complete my CBT. I am completely new to bikes and just needed to figure out the budget I need per annum to run such a bike.
rumbataz
PostPosted: 13:18 - 21 Oct 2012    Post subject: Reply with quote
This is very useful info, thanks. I didn't know that bikes needed servicing so frequently! So 6 services per year at £150 is quite a bit - it's actually more than my car!
J.M.
PostPosted: 13:23 - 21 Oct 2012    Post subject: Reply with quote
Do the servicing yourself. Bikes are easy to work on.
My bikes have only ever been in to a garage to get MOT'd/new tyres. Even when I crashed in to a van I rebuilt the bike in my shed. Thumbs Up
andy_uk
PostPosted: 14:25 - 21 Oct 2012    Post subject: Reply with quote
If you're looking for fuel economy then I would advise against a 2stroke...I'm getting around 48mpg with mine... Shocked
A well maintained 4stroke will be a lot better.
Like J.M. wrote, servicing it yourself isn't rocket science and it's certainly a job most people can do themselves.
PostPosted: 17:31 - 21 Oct 2012    Post subject: Reply with quote
Regular servicing on a 125 means changing the oil and occasionally changing or cleaning the oil and air filters and spark plug(s) at about £5 per filter and plug. A 125 will take about a litre of oil @£5 or less, and you'll be changing it every 1000-2500 miles.
Figure on 8000 miles between tyre, chain and sprocket changes, and £60 per tyre or for a set of chain + sprockets.
All of that will vary with bike and usage.
Teflon-Mike
tl;dr
PostPosted: 18:26 - 21 Oct 2012    Post subject: Reply with quote
125's will generally be cheaper to run than a small car; up to a 500 commuter twin, you will tend to start loosing ecconomy for performance & comfort; by the time you start looking at four cylinder bikes, running costs will start rivalling hot-hatch-backs and larger cars; get up to litre bikes and you are into a very expensive legue; BUT, all very circumstantial dependant.
But; starting places:-
I want to Ride a Motorbike - Where Do I start?
Most newbie FAQ's are tackled in there:-
All the things you might ask
This is a good starter for question of costs:-
OK, so how much is it all going to cost me?
But, think inside, outside and all the way around the box; bike is only one small part of the costs; costs associated with running it maintaining it, insuring it, again only small part, and estimates go completely to pot when you fumble putting it on the side stand and loose a pint of petrol out the carburettor over flow, or you tear your jacket on an inconvenient nail in a door and have to replace it or whatever.
There's cost of getting a licence, cost of 'kit', cost of learning by way of repairing mistakes made by damage; cost of security, and much much more.
Read, consider, absorb, lots and lots of stuff to think about..... 100mpg? just one figure, and how you ride how you use it, as said, even on a bike that might offer it, can go 30mpg either way in real world.
symonh2000
PostPosted: 18:41 - 21 Oct 2012    Post subject: Reply with quote
The cheapest bike I had to run was my first RXS100
I paid £300 for it in 1995
Fuel economy was about 80-90mpg,
It did about 700 miles per 1 litre of the cheapest 2 stroke oil I could find.
Gearbox oil (about 600ml) changed every 4000 miles.
Chain, sprockets, tyres and brakes didn't need changing in my ownership and were still good when the bike was sold.
I also sold the bike for £50 more than I paid for it despite adding a few thousand to the mileage and owning it 2 years.
Four strokes is two strokes too many.
.Chris.
PostPosted: 20:05 - 21 Oct 2012    Post subject: Reply with quote
Teflon-Mike wrote:
...by the time you start looking at four cylinder bikes, running costs will start rivalling hot-hatch-backs and larger cars
Not necessarily - my old GT550 was pretty cheap to run - insurance was pennies, did around 60mpg, servicing was a doddle, parts are cheap, etc.
Chris
1985 Kawasaki Z550F
rumbataz
PostPosted: 20:30 - 21 Oct 2012    Post subject: Reply with quote
Thanks for posting those very useful links. A lot to think about!
Ayrton
PostPosted: 20:31 - 21 Oct 2012    Post subject: Reply with quote
Dont mean to hijack the thread, but is it normal that i went through a new rear tyre in 1000 miles?
OP, i found bikes to be really cheap to keep running. My cbr125 will do about 80mpg and servicing it is easy and doesnt cost more than £15-20.
Nick 50
PostPosted: 20:32 - 21 Oct 2012    Post subject: Reply with quote
Teflon-Mike wrote:
...............get up to litre bikes and you are into a very expensive legue;...................
Not sure what you're on about Mike, i've only filled up 3 times in the last 24 hours Laughing
.Chris.
PostPosted: 21:15 - 21 Oct 2012    Post subject: Reply with quote
What tyre? What bike?
That's a pretty damn heavy wear rate!
Chris
1985 Kawasaki Z550F
Teflon-Mike
tl;dr
PostPosted: 21:22 - 21 Oct 2012    Post subject: Reply with quote
Yup, my CB750's not too bad either and I DO like the fact it has hydraulic tappets..... Laughing Bit of a bugger its oil changes are shortened to 125 territory of every 1250 miles, but, I still get a certain bit of schadenfreude at the thought that its SO much better than having to lift cams out! Shaft drive would be nice, but I can live without it for the miles I do!
But the air-cooled fours are legacy of another era, built when bikes had to work for a living, rather than modern times where they are built significantly as life-style accessories.
There's exceptions to prove the rule all ways round; Running Costs of an exotic like a full power Cagiva 125 Mito, if you give it what the service schedule demands can make a 600 sport look pretty reasonable; the big torque-twins aren't exactly light on consumables either...
Ayrton
PostPosted: 21:32 - 21 Oct 2012    Post subject: Reply with quote
Think its a pilot sporty, but not sure. Bike is a cbr125
PostPosted: 21:33 - 21 Oct 2012    Post subject: Reply with quote
Mpg varies. My RS125 averaged 55mpg over a few years when I bothered to keep a close eye on it, managing 74.5mpg on one when ridden VERY gently. However at about 8000km I change the rings, with oil changes twice as often. Brake pads lasted a bit less than rings. Fairly good on 2 stroke oil but still a hefty expense when it is £10 a litre or so
My first bike was a Honda H100S which did 90mpg when thrashed. Cheap to service, tyres, chains, etc.
Going towards bigger bikes, 1200 Bandit does 45mpg average, Bimota YB10 about 35mpg, FZR600 a bit over 45mpg (same for the Diversion I had and the FZ750), ZZR600 about 58mpg in general use (and about 65mpg when sitting at 70 on the motorway), about 60mpg from a GPZ500S.
Tyre life depends a lot on how you ride. Ride smoothly and they will last FAR longer. Chop around with the throttle, carry a pillion, run them under / over inflated, etc and they will likely last quite a bit less.
symonh2000
PostPosted: 22:12 - 21 Oct 2012    Post subject: Reply with quote
Something certainly isn't right there.
Either you are locking it up all of the time (which I doubt) or there is an alignment issue.
J.M.
PostPosted: 22:32 - 21 Oct 2012    Post subject: Reply with quote
+1
I had Pilot Sportys fitted on my CBR125 after my MOT. ~500-1000 miles later they were still like new.
Ayrton
PostPosted: 23:37 - 21 Oct 2012    Post subject: Reply with quote
Thought something wasnt right. Im definitely not locking it up all the time, so il have to check the alignment. Thanks Thumbs Up
symonh2000
PostPosted: 08:18 - 22 Oct 2012    Post subject: Reply with quote
Does the bike ride ok from what you can tell?
No looseness at the back, pulling to one side etc?
The last post was made 13 years, 350 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.47 - MySQL Queries: 13 - Page Size: 129.04 Kb
